Welcome to the North American Subaru Impreza Owners Club Monday May 4, 2015
Old 12-14-2013, 03:55 PM   #601
ImBenDood
Member#: 227634
2006 Impreza 2.5i
SGM - 26D
We'll I finally figured out a sequence that works... And I'm getting the feedback noises now.. But I don't get a lock/unlock confirmation after I enter the code twice... Doesn't matter which fob I do, even the original...grrr
ImBenDood is offline   Reply With Quote
Old 12-15-2013, 10:18 PM   #602
stragen
Member#: 218682
2006 WRX Stage 9001
DrunkMann'd @ GCM
Same problem I'm having with my 2006! +1 for a solution.
stragen is offline   Reply With Quote
Old 12-26-2013, 07:24 PM   #603
subyrooo
Member#: 360527
07 STI
I read through every post in this thread and I still can't seem to program my extra key fob.
Does anyone know if the electronic chirp module has to be installed in order for this programming method to work?
I bought my car used and I believe the previous owner removed it (i.e. there's no sounds after cycling the key 10 times).
Edit: No matter what I do, the dome light doesn't flash, which I guess means I am not in programming mode.
Can anyone chime in?
subyrooo is offline   Reply With Quote
Old 01-15-2014, 02:48 PM   #604
Dahmenator
Member#: 378824
I was never able to get mine to work i just accept it now lol
Dahmenator is offline   Reply With Quote
Old 01-15-2014, 06:28 PM   #605
waltee1
Member#: 378726
Default reset alarm 05 baja that has no key fob
i have an 05 baja that has no key fob. the alternator belt broke and had to unhook battery. since then i cant get horn to stop and lights to quit blinking when iunlock doors with key
waltee1 is offline   Reply With Quote
Old 01-16-2014, 10:57 PM   #606
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
The dome light has nothing to do with programming a remote.
Are you using the second method to program it?
Do you have the correct remote for the car? There are a few different ones, and although they look the same, they're not.
RexyGirl is offline   Reply With Quote
Old 01-16-2014, 10:58 PM   #607
RexyGirl
Member#: 63616
with mods :)
You wont be able to until you get a remote. THe only way to put it back in valet mode is with a remote.
Old 01-16-2014, 10:59 PM   #608
RexyGirl
Member#: 63616
with mods :)
Make sure you have the right remote for the car. There are at least 3 different teardrop remotes and not all of them will program to your car.
Old 01-19-2014, 04:36 PM   #609
daninski
Member#: 270767
04 Impressa WRX
RexyGirl
I've read through most of this thread and I have yet to find anyone with this style of remote (see link).
http://i62.photobucket.com/albums/h1...s/IMAG0129.jpg
Part number is SCI600125C. It's for the Alpine Alarm in my 04 WRX. So far I can program the orange/purple button remotes but the two 4 button remotes in the linked picture won't program. The crappy one in the picture (rh) was working until I tried to program a new SCI600125C now neither of them work but the orange/purple two button remotes work fine. Suggestions????
As a side note, the new one I got from the Dealership came in simulated carbon fiber. Looks kinda cool.
daninski is offline   Reply With Quote
Old 01-20-2014, 09:27 PM   #610
RexyGirl
Member#: 63616
with mods :)
Neither one of those remotes are factory remotes...You will have to find an Alpine forum to see if someone can help you. I have no idea how to program non- factory remotes....most of them have different programming methods and the info in this thread is for factory remotes with factory installed alarm systems.
Sorry
Old 01-20-2014, 11:50 PM   #611
daninski
Member#: 270767
04 Impressa WRX
I should of pointed out these are Canadian only Subaru remotes for Subaru installed Alpine systems. I just thought you might have heard of them. Thanks
Old 01-21-2014, 11:31 PM   #612
RexyGirl
Member#: 63616
with mods :)
From the research I found, it seems the alarm system you have was installed after, possibly at the dealer. According to the owners manual I found online, you should have the same remote as a US spec vehicle.
Check out an Alpine website and see if there is info on how to program them.
Old 01-22-2014, 05:59 PM   #613
daninski
Member#: 270767
04 Impressa WRX
Thanks for the suggestion. These were the standard alarm installed by Subaru in Canada from like 2002-2004/5 I believe.
Not sure if this was already posted here or not but for peoples general knowledge here's a link to different years of Subaru's alarms.
http://www.cars101.com/subaru/keyless.html#alpine
Old 01-23-2014, 09:09 PM   #614
Rev8ra
Member#: 379612
2006 Wrx wagonator
Hi... My first post here haha... So heres the story, i bought a 2006 wrx wagon ((friggin love the thing)) but it had no alarm (or so i thought) one day i locked it and when i unlocked it the alarm went of, waited a couple mins and started the car. So because the dealership gave me no fobs i bought two teardrop fobs from ebay... Little i know that they were different kinds so i got the model with the trunk release... Two of them for a fairly good price.
I tried the difficult way to program them but get this... After the 10 key turns (or more) i cant listen to the chime, but if i open and close the door right after turning the key i would, weird huh.... So i proceeded with the lock/unlock combos... I think that worked because when i press lock or unlock the locks wont move. So i input the codes twice and wait... But nothing happens... Can someone point me in the right direction?? What am i doing wrong?? I tried different speeds, different amount of key turns... But nothing. I will appreciate it, oh!!! And if i have the wrong fobs which ones should i buy?? Thanks
Rev8ra is offline   Reply With Quote
Old 01-24-2014, 08:48 AM   #615
daninski
Member#: 270767
04 Impressa WRX
Click on the link just above your post, all the models are covered in that link.
Old 01-24-2014, 09:16 AM   #616
Rev8ra
Member#: 379612
2006 Wrx wagonator
Thanks!!! No i know i have the wrong fob... Ill buy the correct one and update you guys how everything worked...
Old 01-24-2014, 12:55 PM   #617
subyrooo
Member#: 360527
07 STI
Yes I am using the second method to program my remote. (I have an 07 STI)
As far as I know, I have the correct teardrop remote
It looks just like this:
It's 100% identical, inside and out, compared to my current (working) remote.
I know my chirp module is missing/broken so I would never hear the chirp (signifying entering programming mode) but does this affect whether or not I can program it?
Everytime I try to enter programming mode (by turning the key), the lock/unlock button starts locking/unlocking the doors after entering 2-3 numbers.
Maybe I should try finding someone with a good chirp module to mount on my car.
Old 01-24-2014, 01:15 PM   #618
Rev8ra
Member#: 379612
2006 Wrx wagonator
Subyroo.... Try opening and closing the driver door right after you turn the key 10 times, i cant hear the chirp either but my locks wont unlock/lock after i open the door and close it (which prob means that programing is working)
Old 01-28-2014, 02:03 PM   #619
V8sPFFF06sti
Member#: 236314
2006 Forester XT
Default new model fob
i can't find if this has been asked or answered yet
can you use a 2013 factory subaru key and program it to a 2006 model?
i hate having key and a fob now that i switched back to a older model car.
V8sPFFF06sti is offline   Reply With Quote
Old 01-28-2014, 04:03 PM   #620
RexyGirl
Member#: 63616
with mods :)
I think this has been done.....but the info is in another thread
Old 01-28-2014, 04:30 PM   #621
V8sPFFF06sti
Member#: 236314
2006 Forester XT
thanks, ill do some more searching
Old 02-09-2014, 10:20 PM   #622
MkeSubie
Member#: 379667
2002 wrx
Midnight Blue
Default alarm system burning
Just bought my 02 bugeye about a month ago, amongst all the other problems I had to fix my security system started smoking and eventually burned a whole through the casing and cup holder. As soon as I noticed the smoke I unplugged it immediately. Any suggestions on how to replace it?
MkeSubie is offline   Reply With Quote
Old 02-09-2014, 10:50 PM   #623
MkeSubie
Member#: 379667
2002 wrx
Midnight Blue
Old 02-24-2014, 09:00 PM   #624
schufflerbot
Member#: 377552
2002 impreza WRX
blue
Dear God,
Thank you for RexyGirl and thank you for this thread.
Amen.
schufflerbot is offline   Reply With Quote
Old 03-19-2014, 04:09 PM   #625
PinchePandy
Member#: 383574
2006 WRX Wagon Limit
Steel Gray Metalic
2006 WRX Wagon
Tear drop remote
I have tried, and had two others try to program and am unable to complete the first step. i.e, i do not get the chirp after turning the key 10 times in 15 seconds.
I have tried fast, slow, timing everything.
Is there any mistakes any of you have made that you have later identified as the problem?
-I've tried with the alarm disabled (hold the lock button until 1 honk)
-I've tried with the alarm activated (hold the lock button until 2 honks)
-I've tried every door to make sure its close
I'm hoping there is something small and silly i've missed. Again, if anyone remembers any other causes for this please fill me in.
PinchePandy is offline   Reply With Quote
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
