Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 07-14-2014, 11:17 AM   #651
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
That information was added to the first page of the sticky a while ago
RexyGirl is offline   Reply With Quote
Old 07-16-2014, 04:44 PM   #652
Forgiven
Member#: 217001
2005 Impreza
Default 2005 and 2006 Impreza wagons
I just got a 2006 wagon and it came without the teardrop key fobs. I do have a matched pair from my previous 2005 model. I put a new battery in one and looked in the manual on how to program it. It said to get the number from inside the fob, this I did. Then it told of the process to program it. Using the 8 digits of that number...The number on my older fobs has one 0 and two letters in it. So it looks like that fob will not work with the newer cars instructions. I then took the instructions for the older fobs and tried doing that with the newer car, no can do. I then saw how I am to reset the fob when a new battery is put in it....click it 6 times, did that and the horn did chirp. So it does talk to the computer. Went through the simple older instructions again and no results. My question is this: Can an older fob a number having 0 and letters in it be used on this newer car that is asking me to hit the lock button the number of times each digit in that code ? Hope this makes enough sense....and Thankyou. Ps. I am having trouble getting any beeps when doing the on/off ignition in less than 15 secs. (thus can not get past that step) I also tried the not going all the way back to Lock position, and that did not work either. Should I take off the battery cable? I am hesitant to do that, don't want other stuff to mess up...does the radio lock if you do that? Thanks again.
Forgiven is offline   Reply With Quote
Old 07-17-2014, 12:50 AM   #653
RexyGirl
Member#: 63616
with mods :)
In order to program a remote into the newer model, it has to have all numbers, no letters (depending on model of vehicle) and vice versa. One will not program to the other. You can't enter a letter when using the 'long' program method.
Old 07-18-2014, 02:31 AM   #654
shane79
Member#: 396607
I am having an issue with my 05 STI. I just bought it. The remote is the tear drop with 2 grey buttons. The car does not lock or unlock. at all. I have tried everything you posted. the lights will flash when I hit the unlock button, they will not however flash when I use the Lock button. The security light is on. blink, pause blink. but again, the car doesn't lock at all, no chirps, nothing. Im getting really irritated with it and im ready to drive it off a damn cliff. Someone help me please lol.
shane79 is offline   Reply With Quote
Old 07-18-2014, 02:01 PM   #655
Forgiven
Member#: 217001
2005 Impreza
Yeah that is what I was thinking Rexy....and I found that the remote I have was talking to my other car in the garage, not the one I was sitting in! Silly me. Anyway thanks for the quick reply, you are great.
Old 07-22-2014, 04:56 PM   #656
adamohurd
Member#: 276227
what about pre 2001 vehicles?
adamohurd is offline   Reply With Quote
Old 07-23-2014, 02:16 AM   #657
bobchees3
Member#: 338521
2002 WRX Wagon
OMGHi2U 2002 wrx remote
My wrx is going through the coding sequence fine but afterwards my remote will only work for about 3 clicks before doing nothing. I'm not sure if it means anything, but the red LED remains lit on the remote. I might just try to get a new one. Should I head to a dealership or get and aftermarket one?
bobchees3 is offline   Reply With Quote
Old 07-23-2014, 01:22 PM   #658
RexyGirl
Member#: 63616
with mods :)
It sounds like your issue is not a remote issue (the lights flash), but a door lock actuator issue.
Old 07-23-2014, 01:26 PM   #659
RexyGirl
Member#: 63616
with mods :)
If you have a factory keyless / alarm, then programming it requires using the button under the dash on the left side (that usually falls into the dash and has to be located by looking under the dash). Your owners manual shows a picture of where it is located.
With the key in the ON position, you press and hold that button until the door locks cycle 3 times. Then press a button on the remote. Remove the key and the remote should be programmed
Old 07-23-2014, 01:27 PM   #660
RexyGirl
Member#: 63616
with mods :)
One of the buttons on your remote is sticking. Try opening it up and cleaning it and see if that helps
Old 07-24-2014, 07:30 PM   #661
Forgiven
Member#: 217001
2005 Impreza
Yesterday I Went to the auto wreckers and got a transmitter from inside a 2006 Impreza, opened it up and made sure it had a all numbers code. I now have gone through the programing over and over with the same result.....after inputing the code two times over as the manual says there is that last one second beep, but the locks do not cycle on and off as the manual says it will do, indicating the acceptance of the code and locking in of the remote. There is a new battery in the remote, that sort of is not the issue as the computer is not finishing off the loading of the code anyway....not sure how to proceed.
Old 07-25-2014, 03:10 PM   #662
RexyGirl
Member#: 63616
with mods :)
What model car do you have?
Check your owners manual and see if you are performing the correct procedure
Old 07-27-2014, 12:33 PM   #663
Forgiven
Member#: 217001
2005 Impreza
Rexy I have an Imprezza 2.5i Wagon. I followed the manual instructions to a tee several times. I get the proper beeps right up to the end where the one second beep happens....but no final on and off of the locks to say the remote is programed (this is supposed to happen next). No matter, I took the remote back. If I keep this car I will get a remote starter for it anyway and will not need the stock remote....Thanks.
Old 07-27-2014, 03:26 PM   #664
Ilovemyboxer
Member#: 379336
08 Wrx
swp
Default Factory Alarm/Keyless Entry...All you need to know!!
can you purchase the remote anywhere other than the dealer? And can the trunk be opened from the remote?
Ilovemyboxer is offline   Reply With Quote
Old 07-27-2014, 06:58 PM   #665
Forgiven
Member#: 217001
2005 Impreza
I found some on Ebay, but sellers I contacted could not assure me I would get one with an all numeric code. As I said I found the one I had at an auto wreckers. Yes I saw remotes on Ebay that had a trunk release button.
Old 07-29-2014, 03:01 PM   #666
RexyGirl
Member#: 63616
with mods :)
Remotes can be purchased elsewhere....but you get what you pay for and sometimes they send you the wrong remote because they look similar.
The new replacement remotes have a trunk button on them, but that's not what its used for. Its used to put the alarm in valet mode. If you didn't have the option to pop the trunk before, you won't now with the updated remote.
Old 07-29-2014, 03:06 PM   #667
RexyGirl
Member#: 63616
with mods :)
What year is your vehicle? Depending on the year/model of car, there are two different ways to program. There is a split with the 2005 MY (according to your profile that is what you have) depending on the model. If you have a regular Impreza (not WRX or STI), the you do the 10 times within 15 seconds, open, close door, press button on remote, etc. If you have one of the other models, then it requires the other method, using the door lock switch.
Old 07-30-2014, 11:27 AM   #668
Forgiven
Member#: 217001
2005 Impreza
It is in the post, 2006 is the year. Yes I did do all that the manual says. Thank you. It really doesn't matter at this point, I gave the transmitter back. I really appreciate your help.
Old 08-01-2014, 06:22 PM   #669
pete68
Member#: 187301
2005 sti
black
Default key fob dealer c'ant program it!!
tried it myself without success !!
any help would be appreciated
2005 sti
thanks
pete
pete68 is offline   Reply With Quote
Old 08-06-2014, 09:51 AM   #670
rebeccahart05
Member#: 398299
I need help! I have a 2001 Subaru Outback that has a factory alarm system. I've had it for a couple years and it's always done this...every time I open the door, the alarm goes off, however I think the previous owner might have disabled the sound. I hear a clicking sound, and the little red light blinks. I cannot start the car until I hit the "unlock" button on the drivers side door or I use the key remote unlock button.
Is there a way to totally disarm this so I don't have to unlock every time I get in the car?
rebeccahart05 is offline   Reply With Quote
Old 08-06-2014, 11:20 AM   #671
Forgiven
Member#: 217001
2005 Impreza
I had a similar problem in the 2006 car I just sold. I found the solution in the manual. I suggest you take a close look at your manual, it probably will be different than the one I had....as best I remember it I was able to cancel the alarm memory by opening and closing the driver's door and hitting the lock button a set number of times.....
Old 08-08-2014, 04:10 PM   #672
pete68
Member#: 187301
2005 sti
black
2005 sti
thanks
pete
anyone !!!!!
Old 08-20-2014, 10:36 PM   #673
Phil Rex
Member#: 395358
2004 wrx
wrb
Did the 04 wrx's come with a remote with buttons? Cuz all I have is a key...for some reason when I disconnected the subaru security unit, and plugged it back in, and then plugged the negative and positive terminals to the junper(batterys dead), the security light blinks twice in 1 second, i cant start my car, and after about 5 seconds my car starts blaring its alarm. So I disconnect the negative to stop it. Idk why it does this, maybe its all cuz I disconnected the unit brain thingy and the system thought I was a thief or something...is there a way to fix this? Again I don't have a remote..for all I care id love to get rid of the whole stupid alarm, but will my car start if I do this? Or is there a special fuse under the steering wheel somewhere? Thanks
Phil Rex is online now   Reply With Quote
Old 08-20-2014, 10:37 PM   #674
Phil Rex
Member#: 395358
2004 wrx
wrb
And also the rear right door lock is jammed amd wont lock.....idk if that would set off the alarm
Old 08-20-2014, 10:43 PM   #675
RexyGirl
Member#: 63616
with mods :)
2005 sti
thanks
pete
What happens when you try to program it? Are you sure it's a factory alarm? Was another alarm added? More info is needed to help you
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 09:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 10:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 08:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-22-2002 12:51 AM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 02:01 PM
