Welcome to the North American Subaru Impreza Owners Club Tuesday July 7, 2015
Old 01-28-2009, 01:15 AM   #51
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
I have a 04 STI, does my upgraded alarm have a starter cut if the alarm goes off? Where is the module, my alarm is not sensitive at all, takes me three or four hard bump to get it to go off. Interested since i just bought it and if not i might put a kill switch in.
I know the 05 come stock with a immobilizer. Im so afraid someone will steal my new baby.
KillerRabbit is offline   Reply With Quote
Old 01-28-2009, 02:33 AM   #52
d0ugch0i
Member#: 198861
2004 WRX
anyone know where i can get a cheap oem alarm?? i think i might have everything wired up cuz i see the horn but i dont have a remote (i bought the car used).
d0ugch0i is offline   Reply With Quote
Old 01-28-2009, 08:05 AM   #53
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Yes, your car has a starter interupt....the module should be located under the drivers side dash near the fender wall.
RexyGirl is offline   Reply With Quote
Old 01-28-2009, 08:07 AM   #54
RexyGirl
Member#: 63616
with mods :)
The module for the alarm should be under the drivers side dash. Just because you don't have a remoted doesn't mean you have to buy a whole system. If there is already one in the vehicle (I can check and see if it was factory installed) you just need to get a remote and have it programmed. THe horn is also used with the keyless entry system to let you know you have locked the car, it doesn't mean you have an alarm
Old 01-28-2009, 08:32 AM   #55
snorekl
Member#: 78139
2005 Saab 9-2X
Red
Originally Posted by RexyGirl View Post
Are you calling a Subaru or Saab dealership?
I checked both places. I did some research and the FCC ID of some older Subaru models match the SAAB ID. The idea being that the Subaru models are cheaper than the ones at SAAB.
So, need to know if that place is decent (saw some carping online about them) and whether if the FCC ID matches, it will work with my SAAB even though it's a Subaru remote.
snorekl is offline   Reply With Quote
Old 01-28-2009, 11:06 AM   #56
RexyGirl
Member#: 63616
with mods :)
If they look the same, they should work. Do you know anyone that has a Subaru with a remote like yours? You could try theirs to be sure.
Old 01-28-2009, 12:38 PM   #57
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
Ok with my 04 sti if it goes off can some one steal it? I mean if they unplug it then they could steal the car right? I think im getting a better alarm.
Old 01-28-2009, 01:46 PM   #58
RexyGirl
Member#: 63616
with mods :)
If the alarm goes off, the start interupt is enabled
Old 01-28-2009, 02:10 PM   #59
ShaneInHisRoom
Member#: 148737
I have a quick question- my remote's panicking option works from like, 30 feet away. But sometimes, locking and unlocking the car I need to be 10-15 feet away, and sometimes it doesn't respond until I press it like 3-4 times in succession. Faulty remote, bad batteries, need a reprogramming?
ShaneInHisRoom is offline   Reply With Quote
Old 01-28-2009, 02:20 PM   #60
NUNES
Member#: 159835
07 WRX TR
BLACK
I tried to do the " the horn no longer beeps/chirps when i unlock/ lock car" and it didnt work. Anyone else knows how to make it beep again.
NUNES is offline   Reply With Quote
Old 01-28-2009, 05:31 PM   #61
ShaneInHisRoom
Member#: 148737
i just did it...open the door, press both buttons on the remote for 3 seconds.
Old 01-29-2009, 04:35 PM   #62
RexyGirl
Member#: 63616
with mods :)
I would try a battery first, the least inexpensive option. They are available anywhere watch batteries are sold....Walmart is pretty cheap.
Old 01-29-2009, 04:39 PM   #63
RexyGirl
Member#: 63616
with mods :)
Your system does work as described in the very first post. Your owners manual will tell you how to get it out of valet mode. I have not mastered how to do that one yet
Try section 2-8
Old 01-30-2009, 08:41 AM   #64
snorekl
Member#: 78139
2005 Saab 9-2X
Red
I don't think that's correct. I believe the 05 WRX (same car as the SAAB) has teardrop shaped remote (correct)?? While mine is the roundish type of shape.
Also, I figured that FCC ID would be a better indicator of frequency match than shape of the fob.
Old 01-30-2009, 02:34 PM   #65
RexyGirl
Member#: 63616
with mods :)
Correct, the 2005 remote for the WRX is teardrop shaped. If you have an irregular round shape remote, it might be similar to the 2004 WRX remote.
Does your remote look like the one in the first post of this thread? (button colors might be gray)
http://forums.nasioc.com/forums/show...ht=2004+remote
Old 01-31-2009, 08:31 AM   #66
snorekl
Member#: 78139
2005 Saab 9-2X
Red
Yep - it looks like the one in the first pictures EXCEPT that the buttons are not colored -the buttons and the whole unit are 100% black. I think it's the Forester/WRX remote from 2004.
Can someone give me the FCC ID off the back of one of the 2004 WRX remotes that look like this one:
Old 01-31-2009, 01:06 PM   #67
snorekl
Member#: 78139
2005 Saab 9-2X
Red
One more question regarding the programming instructions:
For 2001-2006 Models:
(the oblong remote with either 2 grey buttons or a blue and orange button)
**Make sure all windows, doors, hood and trunk are closed.
**Get in and close the door.
**Turn the key in the ignition to the 'ON" position 10 times within 15 seconds
**You should hear the horn/chirp
**Open and close the drivers side door.
**Press one button on the remote
**Open and close the drives side door
**If you have other remotes, repeat the last 2 steps for all remotes
**Remove key from the ignition
**The horn should beep/chirp again
**Check remote(s)
My horn works, but my beeper stopped working a long time ago (the electronic lock/unlock beeper behind the grille). Am I still going to be able to program the remote without being able to hear that little chirper???
I'm sure the instructions don't really mean that the HORN is going to sound (maybe I'm wrong).
Old 01-31-2009, 05:51 PM   #68
RexyGirl
Member#: 63616
with mods :)
You should not have a problem, it is the horn that beeps.
Old 02-01-2009, 09:28 AM   #69
snorekl
Member#: 78139
2005 Saab 9-2X
Red
Thanks for all the help. I think I need to order it and get it done.
Old 02-02-2009, 10:24 PM   #70
SonicAZ
Member#: 200408
08 STI
Anyone had any problems with thier 08 alarm/security?
SonicAZ is offline   Reply With Quote
Old 02-09-2009, 10:54 PM   #71
Rykenma
Member#: 179845
.... Hello?
Yes, this is dog.
I bought a factory keyless from eBay and it works perfectly! Thanks for the info! Only $25 shipped! To be honest...I don't think I opened my door after turning the key to the on position and pushing the unlock/lock button lol. But it still works! All I believe I did was, got in my car, had all doors unlocked, turned key 10 times, horn, pushed the unlock button, I think horn went off after this?, then took my key out, went outside, and boom! Now I can lock/unlock my doors
Rykenma is offline   Reply With Quote
Old 02-11-2009, 12:44 AM   #72
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
I got a question. I recently had someone break into my car and someone tried stealing it. I know i just asked all these questions but in the area i live in i guess i was right. Well the steering column was busted up and the ignition cylinder was hanging down....so my guess is they got into the car tried starting it after they got the cylinder off but failed since the alarm went off and the starter cut activated. I woke up the next morning to see this and my heart just sank if you know what i mean.
Well i went part searching and asked on some local forums and i got a cylinder+switch all of it for like 120 bucks. Of course it dont come with a key so i had to call and make one. Well after i thought about it....i think i set myself up. If the part i bought was out of another stolen sti could they trace it back to me and try getting me for it??? maybe im over-reacting, but im just worried about that now. The guy seemed real skittish and wanted me to get and go, no questions.
What do you guys think, any advice?
Old 02-12-2009, 08:27 AM   #73
snorekl
Member#: 78139
2005 Saab 9-2X
Red
I just wanted to confirm for all my homies out there with Saab 9-2X vehicles that the following Subaru remote keyless entry works with our cars (in case you're stupid like me and lost a remote).
FCC ID : - A269ZUA111
Subaru Part # 88036ae060
TRANSMITTER KEY LESS $50.25
The only difference is the button color and of course it says Subaru. I ordered mine from http://www.subaruparts.com Beats the $160 price at the stealership.
Old 02-13-2009, 09:53 PM   #74
dwmoss_68
Member#: 6030
04 Gold FXT
07 WRB FXT Sport
rexygirl,
great job with your thread....
one thought for you though, there have been a large number of "chirpers" that have failed in a number of models.. you might want to at least make that as an option for your faq answers....
here's a thread regarding it... (it's for the 04's but our 07 fxt had this same problem, fixed under warranty)
dm
dwmoss_68 is offline   Reply With Quote
Old 02-13-2009, 10:48 PM   #75
RexyGirl
Member#: 63616
with mods :)
Originally Posted by dwmoss_68 View Post
rexygirl,
dm
Thanks for the idea....
I thought about that when I wrote this, and hopefully addressed it when I mentioned valet mode. If there is a mechanical issue with the chirper then that is a different topic, but at least I can cross reference that thread. (which I am very familiar with....)
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
