Welcome to the North American Subaru Impreza Owners Club Thursday September 3, 2015
Old 02-15-2009, 09:19 PM   #76
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
I broke my fob, i dont know if im understanding this right but if i unlock the door and the alarm goes off then i cycle the key 3 times to shut it off. Well after that am i able to drive it?? I got to get up tue and get to the stealership.
KillerRabbit is offline   Reply With Quote
Old 02-15-2009, 09:32 PM   #77
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
After you cycle the key, it should start and is drivable
RexyGirl is offline   Reply With Quote
Old 02-16-2009, 10:41 PM   #78
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
Alright yea, it worked. thanks RexyGirl. got a new fob and programmed for $45!
Old 02-21-2009, 07:04 PM   #79
vvnartvv12
Member#: 103390
i too also have an 06 sti....just purchased yesterday as a matter of fact....the dealer only gave me a key with NO remote....they said thats how THEY got it...anyways, i drove the car home, locked it manually, (from switch on inside of door)....went back out to the car to unlock it MANUALLY with the key, obviously because there is NO remote....i open the door and the alarms starts honking....what do i do?...im not really in the mood to spend MORE money and buy a NEW remote just yet, but is there a way to disarm the ENTIRE system and just use the key to lock and unlock withOUT the alarm going off???....a fuse or relay i can just disconnect temporarily??....thanks.
vvnartvv12 is offline   Reply With Quote
Old 02-21-2009, 07:54 PM   #80
RexyGirl
Member#: 63616
with mods :)
Ask them if they will throw a remote in the deal. Tell them the alarm keeps going off and you need one.
If they won't do it, buy one and program it.
To stop the alarm from going off after you open the door, turn the key in the ignition 3 times. It won't fix the issue, but you won't have to wait for it to stop going off.
Old 03-01-2009, 08:02 PM   #81
blackcompany
Member#: 143158
2007 STI
UGM
Anyone know if the accessport disables the turning on/off of valet modes and chirps. Don't really care about valet but I want my chirps back. 07 sti....
blackcompany is offline   Reply With Quote
Old 03-02-2009, 11:21 AM   #82
glenngw3
Member#: 201965
Default Help programming a 97 Impreza Outback remote.
i just purchased a remote, but cannot program it. I am using valet button under dash, but doesn't seem to be resetting itself so I can program new remote. Please help.
glenngw3 is offline   Reply With Quote
Old 03-02-2009, 08:06 PM   #83
RexyGirl
Member#: 63616
with mods :)
The button under the dash on your vehicle is used to program your remote. I forget exactly, but you need to press and hold that button until the locks start moving, then press and hold a button on the remote. (I forget how to do this one)
Old 03-10-2009, 03:28 PM   #84
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
I have an 07 Impreza but I can't get it to program a remote.
I open the door, get in, close the door, open it and close it again, and turn the key from lock to on 10 times within 15 seconds. It says there should be 1 electronic tone after it, but all I get is the seatbelt alarm chime 6 times then it stops (the seatbelt alarm was programmed to do this). I have no idea why it isn't working and I'm starting to get annoyed.
If I turn the key from lock to on it chimes every time (once again...because theres no seatbelt). Why isn't this working? Should it end on lock or on? Do I need to buckle up? Should there be a beep after every key turn, or only after the 10th time? Should I go as fast as I can?
Hotsho111 is offline   Reply With Quote
Old 03-10-2009, 07:13 PM   #85
RexyGirl
Member#: 63616
with mods :)
1. Make sure your keyless chirp is ON (does it beep when you lock/unlock the doors?)
2. Is it in valet mode? (does the alarm go off if you open the door with the key)
3. Try cycling the key an extra time or two, and make sure you are going to the point just before the engine starts.
Remember to open and close the door between each 'mess up'
Old 03-14-2009, 11:32 AM   #86
4orcefed240
Member#: 99072
2006 STI
SGM
I also found this web page when searching on google when I lost both of my factory key fobs. It has very usefull information on almost all subaru models/remotes...
http://www.cars101.com/subaru/keyles...gram%20remotes
4orcefed240 is offline   Reply With Quote
Old 03-27-2009, 05:52 PM   #87
RSKwannabe
Member#: 15819
2001 LEGACY GT
RexyGirl,
Thanks again for your instructions. Picked up an extra FOB at the local dealer last week and tried to program using the instructions from the cars101 website. Ended up de-programming my own FOB. Used your instructions and was able to reprogram mine and program the extra one in about two minutes. That was great!
RSKwannabe is offline   Reply With Quote
Old 03-27-2009, 06:04 PM   #88
silver arrow
Member#: 25859
1965 MGB yellow
2008 Black Miata
Do you have to stand on one foot and pat your head while performing these steps? Think they could make it any harder?
silver arrow is offline   Reply With Quote
Old 03-28-2009, 07:59 AM   #89
RexyGirl
Member#: 63616
with mods :)
I agree....the process for the new remotes in a pain. But the older remotes are not bad once you have the hang of it. Usually I can program one in 30 seconds or less.
Old 03-28-2009, 09:05 AM   #90
CEGLEX
Member#: 201976
2003 WRX Sedan PSM
Stage 2
RexyGirl and others - thanks so much! I have a (new to me) 03 WRX and this helped me get the remote/alarm straight. Awesome!
CEGLEX is offline   Reply With Quote
Old 03-30-2009, 11:05 PM   #91
migy28
Member#: 206991
migy28 is offline   Reply With Quote
Old 04-02-2009, 09:07 PM   #92
BluSuuB
Member#: 198585
2006 STI
Originally Posted by Demon2003 View Post
Ok so i opened the tear drop remote (07 sti) i assume that the letters in the 8 charter code i just translate to hex? mine is xxxBBxxA so this means when entering B into the door i press 11 times and 10 times for A?
Did you ever find out how many times you have to click the lock switch to decifer letters? I tried your advice and it will only allow you to go to 9 before it gives you a sequence beeps telling you its not a correct transmitter code that you are trying to enter. And then what do you put in for zero???? Even the owner's manual doesn't give you this explanation. Subies are great cars but this is just ridiculous!!
And sorry no one ever replied to your post, and this is supposed to the most knowledgeable of the Subaru forums........
BluSuuB is offline   Reply With Quote
Old 04-02-2009, 11:28 PM   #93
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
The inside of mine had 2 sets of 8 digits. There should be an 8 digit combination that is numbers only. That should be the one you need to program. If it has letters in it it's not the right one
Old 04-03-2009, 08:42 AM   #94
RexyGirl
Member#: 63616
with mods :)
There should not be any '0' in the numbers...
Old 04-06-2009, 12:18 AM   #95
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
How do you unprogram the key fob? Mine is unlocking my car and my wifes
StupidFastWagon is offline   Reply With Quote
Old 04-06-2009, 10:34 AM   #96
RexyGirl
Member#: 63616
with mods :)
You need to program the remote to your vehicle enough times to use up all the 'spaces'. You can program up to 4 remotes per vehicle. If you have 1 remote, program it 4 times. If you have 2 remotes, program them each twice.
It's really weird that your remote opens both vehicle, but it could also be a good thing. No need for extra remotes
Old 04-06-2009, 02:11 PM   #97
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
yeah, but when your trying to leave the house in one car you have to make sure both are locked
Old 04-14-2009, 10:18 AM   #98
xilles
Member#: 147056
hi, i broke my fob on my 04 wrx can i upgrade and get the newer tear drop fobs? and program it to my wrx?
xilles is offline   Reply With Quote
Old 04-14-2009, 12:45 PM   #99
mguyrt69
Member#: 199736
1999 Impreza 2.2,CAI
Green
Unhappy
Does anyone know anything about troubleshooting the remote/keyless system? Mine has developed a short or something and is now posessed. Here's what's going on:
Don't know if it's related, but I went to the DIY carwash and sprayed my 01 Forester down. A couple of minutes later I was driving and the door locks randomly unlocked simultaneously. I pulled over and tried locking the doors with the remote. They all lock but then immediately unlock again, but the alarm stays on thus triggering if I open the door.
I thought maybe there was something wrong with the passenger rear door lock (or actuator I guess) because that door is a bit creased from sideswiping a tree (yeah....). I drove the car home then manually locked that door and closed it. The keyless system seemed to start working fine again (except that door was now staying locked...). Since then, it's now gotten worse, the locks are insistant on staying open. Neither lock switch on the front doors does anything at all, the remote will briefly lock the doors only for them to unlock again and they keep clicking repeatedly.
Sorry about the long post... As the doors repeatedly try to unlock there's also a loud clicking coming from near the fusebox under the dash (relay?). The last tidbit I can think of is recently that rear passenger door actuator has been making a whining sound right after locking the doors. I tried disconnecting the harness and from the actuator using the remote but the symptoms remain the same.
Any help is greatly appreciated! I am now driving with the keyless fuse pulled and have to lock/unlock 5 doors manually
mguyrt69 is offline   Reply With Quote
Old 04-15-2009, 01:51 AM   #100
norbeaster
Member#: 192206
2004 WRX
JBP
I second this one.
norbeaster is offline   Reply With Quote
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
