Old 04-17-2009, 02:47 AM   #101
norbeaster
Member#: 192206
2004 WRX
JBP
...Anybody?
norbeaster is offline   Reply With Quote
Old 04-18-2009, 09:20 PM   #102
davros
Member#: 208945
97 Impreza OBS
sparkly blue ;)
hmmm only newr suby info even i all my searching so.......
davros is offline   Reply With Quote
Old 04-20-2009, 05:03 PM   #103
xilles
Member#: 147056
the tear drop remote works with 2004 wrx, oblong shaped ones. i just programmed all 4 of my remotes .
http://cgi.ebay.com/ebaymotors/ws/eB...1295&viewitem=
xilles is offline   Reply With Quote
Old 04-20-2009, 10:19 PM   #104
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
What kind of info are you looking for?
RexyGirl is offline   Reply With Quote
Old 04-22-2009, 12:23 PM   #105
ikellen
Member#: 91642
1999 Impreza OBS
Acadia Green
--URGENT--
I have a '99 Impreza Outback Sport with keyless entry but no factory alarm, however I no longer have the remotes. Recently I replaced my battery and now have my parking lights flashing and the relay click. I've looked for the valet button but can't seem to find anything. I've tried unhooking the battery over night to reset the computer but that did no good.
Am I stuck buying a new remote or is there some other way to fix this?
ikellen is offline   Reply With Quote
Old 04-22-2009, 10:56 PM   #106
RexyGirl
Member#: 63616
with mods :)
Originally Posted by ikellen View Post
--URGENT--
The reset button is under the dash somewhere, it may have fallen in behind the lower dash. (If it is an OEM setup) Do you have an owners manual? THere is a picture there that shows where it is located and what it looks like. It kinda looks like a wire with a small top hat at the end (when not secured in the dash) See if you can find the hole where it is supposed to go and look for the wires right behind the dash there.
I forget whether you can turn the key 3 times to reset it on your model or not.....
Old 04-24-2009, 10:04 PM   #107
Jonnywrx
Member#: 207782
2006 WRX TR
SGM
My car randomly will stop beep/chirping. It will either lock or unlock with no sound. Or will lock with a the car horn. its very random and does go back to normal. any reason?
Jonnywrx is offline   Reply With Quote
Old 04-28-2009, 10:29 AM   #108
trehlo
Member#: 16700
Anyone ever heard of two remotes dying at the same time?
Walked out to the car this morning and the remote was dead. Went back in and grabbed the brand new spare - I had to actually take it out of the bag that it was wrapped in - and that one didn't work either. I opened the door with the key and the alarm turned on, but when I hopped in and started the car it turned off.
It's an 09 model with only about 1k miles on it. Is it even possible for a 2025 battery to die that quickly? Do the sensors inside the car ever go bad or do the key fob frequencies ever get lost?
trehlo is offline   Reply With Quote
Old 06-04-2009, 05:37 PM   #109
STIstg3
Member#: 193395
04 subaru wrx sti
blue
someone please help i have the upgraded alarm package yet randomly the other day my lights just stopped flashing when i locked the car.. any idea's?
STIstg3 is offline   Reply With Quote
Old 06-09-2009, 11:55 PM   #110
WRBPHXSTI
Member#: 199530
2005 Impreza WRX STi
Question, I have an '05 STi, and I do not have the horn on the strut tower, so I'm gathering that means I only have Keyless on my car. When I lock the car the security light does the blink, pause, blink, etc, but even after I unlock the car the security light turns off for a few seconds then resumes the blink, pause, blink again. It does this whether I open the door or not. Is this normal?
Also pressing the lock button once locks the car, chirps and lights flash. Pressing it again repeats everything, but if I lock it a third time the chirp is replaced with the horn beeping. Is this normal as well?
I read the last 5 pages but didn't see anything regarding these questions.
WRBPHXSTI is offline   Reply With Quote
Old 06-10-2009, 12:17 AM   #111
RexyGirl
Member#: 63616
with mods :)
Open the drivers side door and press and hold unlock on the remote for about 3 seconds.
Old 06-10-2009, 12:21 AM   #112
RexyGirl
Member#: 63616
with mods :)
IIRC, the Sti's all had a security alarm, but not all of them had the shock sensor. (that was an upgrade)
To check to see if you have an alarm, lock the car and wait about a minute. Then open the door with the KEY. If the horn goes off, then you have an alarm. (to stop the alarm, press unlock on the remote)
Depending on how long you wait to start the car, the alarm could reactivate. (Will it start after the light starts blinking again?)
Also....when you lock the car with the remote the first and second time, the lights will flash and it will beep. If you hit it again, the horn will go off...just to let you know it DID lock and arm. This is normal
Old 06-10-2009, 12:29 AM   #113
WRBPHXSTI
Member#: 199530
Well I just tried opening the door with the key and nothing happened, the security light kept blinking at the same rate. I put the key in the ignition and the car started right up. I also tried opening the pass. side door and nothing happened their either.
Old 06-10-2009, 08:46 AM   #114
RexyGirl
Member#: 63616
with mods :)
Is your alarm in valet mode?
Old 06-10-2009, 01:22 PM   #115
WRBPHXSTI
Member#: 199530
According to the blinking light it isn't, it does the blink, pause, blink, pause etc. I will see if I can put it in valet mode to make it blink, blink, pause, blink, blink, etc.
Edit: I tried to put it in valet mode using the instructions in the first post and the security light just keeps blinking the same rate, blink, pause, blink, pause, etc. Nothing changes.
I'm not sure if this is related, but when I first bought the car it only came with one remote. I took it to the dealer to have another remote programmed (didn't know about this thread at the time) and they had a hard time getting it to program because of the turbo timer. The tech said the timer was wired in wrong and he had to make some changes to it. The turbo timer was installed by a previous owner.
I'm gonna disconnect the battery for a few and see if that will reset the alarm or change anything at all.
Old 06-12-2009, 08:10 PM   #116
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
EJ25 Hybrid, 314HP- 280tq
I had to do a battery Re-relocation back to original spot from the PO putting it in the back. When I connect the Pos. back the alarm goes off and I cant stop it with my key fob. THe key fob actually never worked before this either. Any Ideas? I found no reset button and I dotn wanna piss off my neighbors trying all these different reset methods.
BugeyedWREX is offline   Reply With Quote
Old 06-12-2009, 09:41 PM   #117
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
I believe the manual override is to put the key in the ignition and turn the key from off to lock (or on) 3 times quickly.
Have you tried programming the key fob?
Hotsho111 is offline   Reply With Quote
Old 06-12-2009, 10:04 PM   #118
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
Many times. Im guessing either the alarm going offwhile doing it, or my TT is messing with reprograming. Security light is blinking super fast if that means anything..
Old 06-12-2009, 10:05 PM   #119
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Have you been able to get the car into programming mode?
Old 06-12-2009, 10:08 PM   #120
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
Im not sure. I did the 10x, open/close door, click button, open close thing..but its not working. I unplugged my horns cause it was P-n off the neighbors so I cant hear the audible beep.
Old 06-12-2009, 10:11 PM   #121
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
The audible beep isn't from the horn it's from a little electronic thing at the front of the car. Does the electronic chirp ever make noise? If the chirp is broken you can't enter programming mode and it is a fairly common thing to fail.
I spent 2 straight days trying to figure it out and came across that as the problem. I had it replaced (there was a great thread about how to fix it which is just soldering the connection back on) and was then able to program the remotes on the first try
Old 06-12-2009, 10:17 PM   #122
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
Happen to have a link or what I can type in on the search button. I never hear a chirp. Btw my alarm is armed this whole time and going off. Make any differnce?
Old 06-12-2009, 10:18 PM   #123
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
http://forums.nasioc.com/forums/show...608657&page=17
About half way down is how to fix it
Old 06-12-2009, 10:25 PM   #124
BugeyedWREX
Member#: 141734
02 BUG-I WAGON
Yea...so I just looked and I dont have one of those...like at all...
Old 06-12-2009, 10:27 PM   #125
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
I'd try asking a dealer how much it would be to get one
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
