Old 07-21-2009, 04:16 PM   #151
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
I know Valet mode disables this, but I am still pretty confused..
What is pragmatic about the alarm going off when you unlock you car with the key? (Not in Valet mode obviously)
NorthBayResident is offline   Reply With Quote
Old 07-26-2009, 02:06 PM   #152
eastcoastinvest
Member#: 218416
Unhappy Please Help!
I have a 2000 Impreza and lost my remote. My alarm inadvertantly went off and now I can start my car.
I have tried turning the key on and off 4x but that did not help.
Any thoughts?
eastcoastinvest is offline   Reply With Quote
Old 07-26-2009, 02:26 PM   #153
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Any thoughts?
Ia it a factory or aftermarket alarm?
RexyGirl is offline   Reply With Quote
Old 07-28-2009, 11:25 AM   #154
Mark T. Byrne
Member#: 201279
Default Keyless entry/no alarm
Hi, I have looked for answers in the forums and haven't found it yet. I recently purchased a 2000 Impreza Outback Sport and trying to program remote. I don't have the tophat under dash, but do have a balck box with red light. I have tried several times to hold the red button on black box (red light comes on and flashes 2 times). I push the lock button on remote, lock are supposed to cycle, yet nothing has worked yet. Do I need to key the ignition several times? Any help? Thanks, Mark
Mark T. Byrne is offline   Reply With Quote
Old 07-29-2009, 12:28 PM   #155
RexyGirl
Member#: 63616
with mods :)
It almost sounds as if you have an aftermarket alarm...Can you read anything off of the box?
Old 08-18-2009, 11:04 AM   #156
kwat
Member#: 220811
Hi. I have a recently purchased 2004 WRX (bought from an individual). Recently the panic alarm started going off by itself in the middle of the night. Sometimes it even goes off while I'm driving. Is there an easy way to disable the panic alarm and still leave the horn functional? Thank you.
Edited: Actually, I don't care if it's easy or not, what would I have to do to disable the panic alarm?
kwat is offline   Reply With Quote
Old 08-27-2009, 04:25 PM   #157
RexyGirl
Member#: 63616
with mods :)
Are you sure it is a factory alarm? If not, you need to find out what kind of system it is.
It is possible that the sensitivity is set too high or it was installed properly.
What does your remote look like? Does it look like the ones in this thread?
Old 08-29-2009, 10:47 AM   #158
jml2009
Member#: 221986
Default alarm flashes 4 times
I have a 2008 impreza with a factory alarm and it flashes 4 times pauses and repeats over and over all the time. any ideas of what can be done. I have seen advice on 1,2 3 and 5 flashes but not 4.
jml2009 is offline   Reply With Quote
Old 08-30-2009, 12:26 AM   #159
RexyGirl
Member#: 63616
with mods :)
Per your owners manual:
Tripped sensor identification:
The security indicator light flashes when the alarm system has been triggered. Also, the number of flashes indicates the location of unauthorized intrusion or the severity of impact on the vehicle.
When the ignition switch is turned to the “ON” position, the indicator light will light for 1 second and then flash as follows:
. When a door or rear gate (5-door) was opened: 5 times
. When a door or the trunk (4-door) was opened: 4 times
. When the ignition switch was turned to the “ON” position: 3 times
. When a strong impact or multiple impacts were sensed: twice (only vehicles
with shock sensors (dealer option))
. When a light impact was sensed: once (only vehicles with shock sensors (dealer option))
NOTE
Any of the above indicator light flashings will recur each time the ignition
switch is turned to the “ON” position. Rearming the alarm system cancels the
flashing.
Old 08-30-2009, 10:31 AM   #160
jml2009
Member#: 221986
Thanks for the reply, but,I have a 5door and this light flashes all the time, with the key in the ignition or not. All doors and rear gate are closed properly atleast the light in the dash for doors open is not lit. I've set the alarm on and off still these 4 flashes alll the time.
Old 09-01-2009, 02:05 PM   #161
kwat
Member#: 220811
Thanks for the reply. I have the new style with orange and blue buttons. Does the panic alarm have sensitivity? I thought it just goes off when you push the panic button on the remote. As far as I know, the regular alarm is in Valet mode. I can shake the car all day long and it won't go off. But the panic alarm just goes off when it feels like it - usually at 3:00 am
Old 09-06-2009, 11:11 PM   #162
Mekks
Member#: 219749
quick question, my 02 wrx has the factory alarm and keyless entry.
but when i unlock the car via the remote it only does the driver door. is there a way to get all four doors to unlock? its really annoying to have to walk all the way around the car to unlock the back doors.
Mekks is offline   Reply With Quote
Old 09-06-2009, 11:32 PM   #163
Hotsho111
Member#: 199136
2007 Impreza
2005 ZX-6R
Press the button twice in quick succession. The first unlocks the drivers door, the second unlocks the rest
Hotsho111 is offline   Reply With Quote
Old 09-07-2009, 12:58 AM   #164
Mekks
Member#: 219749
awesome thanks!
Old 09-08-2009, 02:27 PM   #165
Type R powR
Member#: 171016
05 STI
RALLY BL00
ok. its setup.
Type R powR is offline   Reply With Quote
Old 09-10-2009, 01:10 AM   #166
Kiyoshi_STi
Member#: 154474
2007 STi Stage 2
Urban Gray Metallic
So i fixed my buddies STi, but cant get mine. I have an 07 when i lock it , light blinks, click sound, but no chirp. Also the light blinks like a strobe light is that right?
Kiyoshi_STi is offline   Reply With Quote
Old 09-10-2009, 03:18 AM   #167
dem1k
Member#: 146186
2002 wrx
psm
Any ideas for me? I have an 02 wrx and I have the stock remote and keyless entry but it doesn't work the remote has a red light that blinks when I press a button but no chirp, doesn't unlock the doors, lights on the car don't flash or anything as if I didn't even press the button. I have tried to reprogramming thing but still no beep or nothing. Any ideas?
dem1k is offline   Reply With Quote
Old 09-11-2009, 05:22 PM   #168
RexyGirl
Member#: 63616
with mods :)
Sounds like you have a bad remote or you programmed it incorrectly.
The light on the remote basically tells you the battery is good and it is sending signal.
I would try programming it again and see what happens. Disconnect the battery first to reset everything. (instructions are in this thread)
Old 09-16-2009, 02:45 AM   #169
dem1k
Member#: 146186
2002 wrx
psm
I have tried disconnecting the battery, everytime I follow the instructions I don't get a beep or honk after the 10 times within 15 seconds. Perhaps the previous owner messed something up when he installed his stereo?
Old 09-22-2009, 03:20 AM   #170
vroom...psshh
Member#: 118351
2002 wrx wagon
I have an 02 wrx wagon and I have a factory keyless entry alarm, just wondering if I can use the factory alarm from an 04-05 wrx or at least the horn of the alarm? I kina don't like the horn of my factory alarm. thanks in advance.
vroom...psshh is offline   Reply With Quote
Old 09-22-2009, 03:22 AM   #171
Mekks
Member#: 219749
would also like to know this, the 02 alarm sounds like a kids toy.
Old 09-22-2009, 04:23 AM   #172
Tubbs540
Member#: 197216
2006 STI
06 Range Rover Sport SC
+1 to that
Tubbs540 is offline   Reply With Quote
Old 09-24-2009, 03:41 AM   #173
vroom...psshh
Member#: 118351
2002 wrx wagon
no answer still?
Old 09-24-2009, 09:34 AM   #174
RexyGirl
Member#: 63616
with mods :)
I'm sure you probably could, or buy an aftermarket addition to the siren, but I don't know of anyone that has done it.
Old 09-25-2009, 12:32 AM   #175
Mekks
Member#: 219749
could try and hookup a hella super tone to it? might even bolt on the stock bracket
Factory Alarm + Keyless entry from 04 FXT Skidd Interior/Dressup/Audio & Security 0 01-22-2009 08:26 PM
Factory alarm/keyless entry install - Anyone want to help?! NickWRX Tri-State Area Forum 3 07-06-2008 09:22 PM
All you need to know about ass hair. WRick Off-Topic 22 01-23-2006 07:22 PM
Factory Alarm / Keyless entry Woody Vancouver Impreza Club Forum -- VIC 3 04-21-2002 11:51 PM
Factory alarm/keyless entry on MY01 Safir Car Audio, Video & Security 1 02-08-2001 01:01 PM
