11-11-2008, 11:38 PM | #1 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Another 1990 Legacy wagon conversion
Yep, another one. Replacing the 2.2 NA with an NA 2.5 block, STI crank and rods, 100 mm Mahles, twin turbo heads from the Reddevil that just split the cylinder walls, 550cc injectors, 6 puck and upgraded pressure plate, PP6, yada yada yada
11-11-2008, 11:38 PM | #2 |
Member#: 64673
NWIC
$190 shipped for 6puck and valeo "upgraded" pressure plate. we shall see. Fastest drop in ever for me. Last edited by reddevil; 11-22-2008 at 08:10 PM. |
11-11-2008, 11:38 PM | #3 |
Member#: 64673
NWIC
December 6th, pulled the front end off to swap over painted hood, bumber and fenders. Ghetto, but on its way.
3:30 4:15 Then after dinner I went back in and installed the pre-painted hood, fenders and bumper. Last edited by reddevil; 12-07-2008 at 04:56 PM. |
11-11-2008, 11:39 PM | #4 |
Member#: 64673
NWIC
And once again, Jesus saves me. I keep ****ing up.
11-12-2008, 02:48 AM | #5 |
Member#: 105104
VIC
Vehicle:1979 BRAT / 01 RSTI 99 2.5TS (DEAD) |
haha cool another build from you! is this one going to be N/A? are those the pistons you got from wcss?
11-15-2008, 01:12 AM | #6 |
Member#: 64673
NWIC
Yeah! Best $23 I ever invested!
11-15-2008, 10:51 AM | #7 |
Member#: 152176
Vehicle:2001 2xImpreza 2.5RS BRP/SRP |
there is 97 rhd one for cheap close to me...i should get it.lol.
nice project. |
11-15-2008, 11:13 AM | #8 |
Member#: 137902
Vehicle:---- living life to the least!! |
orly? should be fun deevil!
11-22-2008, 08:11 PM | #9 |
Member#: 64673
NWIC
IN! pictures in post 2
11-23-2008, 12:31 AM | #10 |
Member#: 36333
NESIC
Vehicle:98 RS GT30R, closed deck madnes |
that clutch from Ebay ??
MAN you got a BIG garage...I'm jealous. I can barely SQUEEZE in around the sides of my car to work on it. hey red just curious... have you ever actually owned an Impreza ?? |
11-23-2008, 09:19 PM | #11 |
Member#: 64673
NWIC
Yeah its and Ebay special.
Never owned an Impreza, but I have owned a 1976-78 and 79! So close to turning it over tonight. But the lack of 4.5 quarts of oil slowed me down. |
11-24-2008, 09:16 AM | #12 |
Member#: 36333
NESIC
gotta let me know about that clutch. can't beat the price
11-24-2008, 12:06 PM | #13 |
Member#: 132130
TXIC
Vehicle:2002 Ford F-150 Graphite Gray |
..this is an N/A build in the AFi forum?
11-24-2008, 12:44 PM | #14 |
Member#: 64673
NWIC
No, its a AFI build with no turbo until I have the time to fab that in.
11-24-2008, 05:55 PM | #15 |
Member#: 175483
Vehicle:13 WRX - 03 S10 |
What intake manifold is that? I would guess a 2.5L DOHC
11-24-2008, 07:18 PM | #16 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
There's somethin' not quite right with this here boy. He's clearly a bit touched. I think he's got red mist on the brain or sumthin'...
11-24-2008, 07:22 PM | #17 |
Member#: 64673
NWIC
Yes, 2.5 DOHC intake.
Well... Started it up. Smooth as butter! Backed it up and added water. Sweet! Then added power steering fluid (ATF) as i had swapped pumps..... POW! Off shoots the pressurized side. Tighten it up and POW off it shoots again. Well, there is a reason the pressurized side is a single hard line. I had had to cut and modify the pressure side and "hope" my bandaid held. Not a chance. Have to see what I can do to connect the two metal lines. |
11-24-2008, 11:27 PM | #18 |
Member#: 53595
NWIC
Vehicle:1987 GL Hatch EA81 1.6L + Weber |
nice.
11-28-2008, 04:03 PM | #19 |
Member#: 64673
NWIC
Made it down to Oil Filter Service and they built/adapted my two sections of line together for $44! Thanks guys!
Installed it, filled up the powersteering pump/resevoir and away I went up and down Woodstock to set the rings. And boy am I happy! Runs the best off the bat of ANY of my builds. No weird noises, no weird smells, no obvious leaks. I do need to add some fuel @ idle I think, but I can't find my laptop power cord right now. But its up and running! |
12-07-2008, 05:48 PM | #20 |
Member#: 64673
NWIC
Still running really well.
Weird mystery noise on cold start up. And it is especially annoying because you can hear it IN the car, but as soon as you open the door, it gets drowned out. But it does not seem to have affected anything. And I have done a little body work, look in Post 2 |
12-07-2008, 11:28 PM | #21 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
Hows that ebay clutch feel? Be honest! A few of us have bought it and had the funky pedal feel due to the pressure plate fulcrum being wrong. Does it feel like your pedal goes past the point of max resistance, and gets easier to push that last 1-1.5" to the floor?
Jay |
12-08-2008, 12:03 AM | #22 |
Member#: 64673
NWIC
Its a Valeo brand pressure plate.
I had to adjust the cable, but other than that, it feels perfect. I can't bog it off the line of course because its a 6 puck, but i can put-put around @ 1 mph if I keep the revs up a tad. |
12-08-2008, 01:50 AM | #23 |
Member#: 36333
NESIC
how does the 6 puck differ from those clutches you have used before ? how do you like it ?
12-08-2008, 05:05 PM | #24 |
Member#: 5218
Good to know. The blue paint screams of the infamous "F1" clutch sold by, among other places, Grip_Force on ebay......Mine is also stamped Valeo, but had the funky pedal feel that caused issues with my foot lifting off the pedal during launches. It would hesitate and then "kick" me. It developed shudder as well....even cable actuated. I yanked it for an ACT, but I hope yours holds up better.
On topic....Nice build! You must be having a ton of fun in the "sleeper" cars!!!!! Jay |
12-08-2008, 06:01 PM | #25 |
Member#: 64673
NWIC
Took my 1990 Legacy wagon to 14.9 finally, 10 psi | reddevil | Proven Power Bragging | 12 | 08-14-2006 12:53 AM |
1990 Legacy wagon with a loud, obnoxious rear end | the_legacy | Legacy Forum | 3 | 11-14-2005 01:51 AM |
Thinking of 1990 Legacy Wagon | PETC | Legacy Forum | 14 | 06-16-2005 10:43 PM |
Parting out 1990 Legacy wagon | Legacy777 | Private 'For Sale' Classifieds | 2 | 09-07-2004 08:45 AM |
Comments on a 1990 Legacy wagon | Wheeldog | Legacy Forum | 25 | 09-18-2003 08:52 PM |
