Old 11-12-2008, 02:18 AM   #1
pio!pio!
Member#: 4190
2008 Impreza WRX STi
Default Good air compressor for working on your racecar?
Is this guy any good for the garage weekend warrior?
http://blackfriday.gottadeal.com/bla...ompressor.html
I was thinking of using it to fill air in the tires as well as using it to loosen bolts all over the place...any good?
pio!pio! is offline   Reply With Quote
Old 11-12-2008, 02:34 AM   #2
grippgoat
Member#: 62182
2005 STI
I'm sure it's do tires just fine. It'd probably have to kick the compressor on pretty often because the tank is so small, though.
-Mike
grippgoat is offline   Reply With Quote
Old 11-12-2008, 07:20 AM   #3
Mike.J
Member#: 174522
08 STI
I have one and don't like it. As the other Mike said, the compressor kicks in real often because of the small tank. Trying to use any tools is an exercise in start-wait for compressor to bring tank back up-start...... I'd recommend getting the largest tank you can afford.
Mke J.
Mike.J is offline   Reply With Quote
Old 11-12-2008, 07:32 AM   #4
KC
Member#: 442
16 SS
00 S2000
Mke J.
Best suggestion I've heard from almost everyone that has a compressor. Go big.
--kC
KC is offline   Reply With Quote
Old 11-12-2008, 07:48 AM   #5
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
Agree with those above, that compressor would be good for filling tires and that's where it would end. I would doubt it would have the umph to break loose things like the lower shock bolts and other suspension components.
If you want to run impacts you want to have a little more than the impact is calling for. Look at the cfm ratings.
I would recommend something with a 25 or 30 gallon tank for a hobby shop/garage. 1.5 hp or so.
Also I would get an oiled unit. The oil-less ones are quiet but they lack longevity under constant use and are generally non-serviceable. That appears to be oil-less but I didn't look it up.
Save up a little and you won't be dissapointed. If your buying new I would spend between $300.00-$600.00. Or find a used one.
Happy owner of a 1.6hp 30 gallon vertical.
My .02
Greg
mccanixx is offline   Reply With Quote
Old 11-12-2008, 08:53 AM   #6
nhsilversti
Member#: 50895
. www.48hrs.info
donation chairman
--kC
agreed, buy one 2X as big as you think you will even need. even at that you, at some point, will find it to be to small.
im now at 60 gallon 5.5hp 2 stage compressor with 15.9cfm at 90psi, yeah i dont run low on air now.
nhsilversti is offline   Reply With Quote
Old 11-12-2008, 09:06 AM   #7
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
I agree with what everyone has said above, you will want a much larger tank. I should also mention though, make sure the outlet it is plugged into is connected to a circuit that can handle it. If not, every time the compressor kicks on it will trip the circuit and it's incredibly annoying to have to stop what you're doing to go reset the circuit breaker.
boost junkie is offline   Reply With Quote
Old 11-12-2008, 09:15 AM   #8
trhoppe
Member#: 7492
No race cars
www.tomhoppe.com
This is one of the better deals for a great compressor out there. Cast Iron, oiled, and way quieter then one of those cheapo oil-less ones.
6CFM at 90psi will also pretty much handle anything.
http://www.homedepot.com/webapp/wcs/...ctId=100063473
-Tom
trhoppe is offline   Reply With Quote
Old 11-12-2008, 09:16 AM   #9
fliz
Member#: 30342
True. I had to add a circuit in my garage right after I bought my compressor. I've got a 30 gallon upright Craftsman. It works, but it's loud as hell. I usually take a break and leave the garage whenever it kicks on.
fliz is offline   Reply With Quote
Old 11-12-2008, 09:12 PM   #10
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
I have a 60 gal., 2 stage and wish I had more (120 gallon, 4 stage w/ 100% Duty Cycle sounds nice).
my4isflat is offline   Reply With Quote
Do you take off your wedding ring when you work on your car/whatever? Kiel Off-Topic 58 06-22-2008 11:22 AM
Good Food For Thought on Your WRX Mods BIG GUN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 05-09-2005 09:59 PM
Air Compressor for auto-x ESPN Tire & Wheel 11 06-02-2004 12:43 AM
Good air compressor? Keith General Forum Archive 5 02-03-2001 12:14 AM
