Old 11-12-2008, 08:58 AM   #1
westy4990
Member#: 158488
2007 Impreza 2.5i
Urban Grey Metallic
Default Head Gasket Failure
So, I know there have been countless threads about this already but I can't seem to find the answer I am looking for. My car just had the head gaskets replaced under warranty (2007 2.5i), but why do subaru's seem to always have problems with head gaskets? Is it a design/engineering problem? Cheap parts?
None the less, I am thankful they found out what was wrong with my car and it was covered under warranty. This is the third time my car has been in the shop for overheating and they finally got it diagnosed correctly.
Thanks in advance for your info.
westy4990 is offline   Reply With Quote
Old 11-12-2008, 09:12 AM   #2
Skidd
Member#: 1853
GC6 Supercharged
STM
Wow.. I didn't realize that the 2007 model also had HG issues! I thought it was a problem with the older EJ25? My understanding of the issue was a design flaw in the gasket itself. But, I was also under the impression that Subaru had found and fixed this flaw in there replacement head gaskets? I sure hope that's the case since I just replaced mine last year with an OEM one.
I wonder if the issue with your engine was specific to your vehicle? Or is it the continued subaru HG issue?
Skidd is offline   Reply With Quote
Old 11-12-2008, 09:37 AM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Sounds like a fluke to me. I also thought they'd fixed the gasket issue.
Besides, the standard head gasket failure was at ~80k miles. My '02 went pop at 84k.
sniper1rfa is offline   Reply With Quote
Old 11-12-2008, 06:15 PM   #4
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Originally Posted by westy4990 View Post
....... but why do subaru's seem to always have problems with head gaskets? Is it a design/engineering problem? Cheap parts
Open deck block design, it allows for a lot of distortion and movement at the head gasket mating surface. The more movement, the more wear and tear on the head gasket = more failures.
This is not just a subaru thing any engine with a open deck block will more then likely have a higher rate of HG failures then the same type of engine in a semi closed deck or closed deck block configuration.
flstffxe is offline   Reply With Quote
Old 11-12-2008, 07:14 PM   #5
mdungelman
Member#: 97251
'13 Impreza 2.0i
I just had mine replaced on my 06 just under 60k.
mdungelman is offline   Reply With Quote
2003 Legacy Head Gasket Failure m98cox Service & Maintenance 4 12-06-2006 11:52 AM
When to expect head gasket failure ? G.Subramaniam Normally Aspirated Powertrain 5 09-17-2006 08:48 PM
Preventing Head Gasket Failures chrispy Legacy Forum 1 04-18-2004 09:07 PM
Head gasket failure in 99 Forester oshkasmum Canada Region Forum 9 03-12-2004 03:12 PM
regarding '99-'02 2.5s: With extended warr., do we hope for head gasket failure? dingo dave Warranty Issues & SOA Problems 15 03-09-2004 02:49 PM
