Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 11-12-2008, 08:08 PM   #1
04AZSTI
Member Sales Rating: (1)
Member#: 86836
04 STI/08 R6
Subaru Banner FS: KSPORT GT Pro coilovers
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
These came off of a 2004 STI.
Picture of the ride hight
GT Pro Damper System
Ksport GT Pro Damper System provides the ultimate in suspension technology featuring its inverted monotube design, 36 levels of adjustable dampening, adjustable spring perch, adjustable body and pillow-ball mounts. With the gas/oil chamber farther away from the knuckle and braking system reducing heat transfer. This design also reduces under-sprung weight, which improves handling and responsiveness.
36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. The pillow ball top mounts also allow you a more direct feel for solid driver response. Camber adjustability is included on pillow ball top mounts that allow it for the ability to adjust camber from the actual coilover, instead of a separate camber kit.
Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability.
The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride.
Product may vary depending on vehicle
Inverted steel shock absorber for durability
Lower center of gravity and higher chassis rigidity
Designed to reduce friction for cooler shock oil temperature
Inverted design like vehicles in WRC and all JGTC cars
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
$950.00 obo. shipped. PayPal accepted and will pay the 3%.
Coilovers where on the car for 6 months. all street driving to and from work.
PM me with any questions you may have.
Thanks Ryan.
04AZSTI is offline   Reply With Quote
Old 11-13-2008, 10:27 AM   #2
04AZSTI
Member#: 86836
04 STI/08 R6
Thursday bump
Old 11-14-2008, 04:19 PM   #3
04AZSTI
Member#: 86836
04 STI/08 R6
Give me your best offer and ill see what i can do.
Thanks.
Old 11-18-2008, 10:33 AM   #4
04AZSTI
Member#: 86836
04 STI/08 R6
I need these gone asap.
Old 11-18-2008, 02:34 PM   #5
drunkguy
Member Sales Rating: (24)
Member#: 30594
2008 WRX
pics would be nice.
drunkguy is offline   Reply With Quote
Old 11-22-2008, 08:35 PM   #6
04AZSTI
Member#: 86836
04 STI/08 R6
Bump for sat.
Old 11-24-2008, 04:08 AM   #7
DwagSTI06
Member Sales Rating: (7)
Member#: 170150
2006 WRX STI
pics?
DwagSTI06 is offline   Reply With Quote
Old 11-24-2008, 12:29 PM   #8
04AZSTI
Member#: 86836
04 STI/08 R6
Pics added
Old 01-10-2009, 10:55 AM   #9
don kovy
Member Sales Rating: (27)
Member#: 138373
2006 WRX TR
still waiting on the spanner wrenches, studs and dampening adj. if I dont hear from you by Sunday evening I am moving it to scammer central. You have had since the 5th of December to provide it all.
So all your friends who read this might want to contact you and let you know. I will start my paypal claim by Sunday night.
don kovy is offline   Reply With Quote
JIC FLT-TAR Coilovers 08 WRX/STi /KSport GT Pro Coilovers! 02+ WRX/STi/Tein S-Tech's! ScoobyMods.com Suspension/Brakes/Handling 15 06-23-2008 01:35 PM
05+ STi Ksport GT Pro Coilovers MaxD Suspension/Brakes/Handling 21 09-24-2007 12:55 PM
FS: 02-04 KSport GT Pro Coilovers, SSAC Top Mount, Stock STI DP bpwatts TXIC Private Classifieds 7 01-30-2007 08:03 PM
FS: (Texas) KSport GT Pro Coilovers (or K-Sport) bpwatts Suspension/Brakes/Handling 3 01-26-2007 05:55 PM
Ksport Gt Pro Coilovers 05 sti narenji Car Part Reviews 1 12-16-2006 11:20 AM
