Old 11-12-2008, 11:06 PM   #1
grafton
Member#: 187936
07 WRB STi
Default anyone every seen a stock pulley like this...
that's the crank pulley after the crankshaft key ground out the center
the crankshaft bolt manged to work itself loose and that happened
i've been without wheels for about two weeks and am really ready to seriously destroy my wife's automatic chevy land boat lumina POS delux car
grafton is offline   Reply With Quote
Old 11-12-2008, 11:55 PM   #2
Miercoles Cansado
Member#: 166820
my ignore list
The adhesive on my crankshaft pulley "let go" and separated a while back. Luckily I had just dropped the car off to have a tune done so it saved me a tow fee.
Miercoles Cansado is offline   Reply With Quote
Old 11-13-2008, 08:57 PM   #3
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
there's adhesive on the crank pully? thats something i would say if i f'ed up someone car while working on it. well not really, im pretty honest. But i could see someone else doing that.
Old 11-13-2008, 09:45 PM   #4
raheezy69
Member#: 163078
MARG BAR DICTATOR
LONG LIVE IRAN!!
wow..
throw a lightweight pulley on there now!!
raheezy69 is offline   Reply With Quote
Old 11-14-2008, 06:56 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'd check the threads inside the snout of the crank to make sure the bolt is actually tightening the pulley instead of just getting tight in it's threads. At 150lbs/ft I would think that bolt would never back out on it's own.....
Jay
Old 11-14-2008, 01:14 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
the important thing is that the key is still good and the crank threads are good. you can prolly find a LW pulley for a decent price, they're worth it.
Old 11-14-2008, 10:46 PM   #7
grafton
Member#: 187936
07 WRB STi
that's the thing the key BENT; so i'll be grinding some of it away to remove the timing sprocket and replace it with a new key from the dealership fun fun.
the bolt seems fine because i can thread it all the way down with out any problems and as for the replacement pulley i have a group a pulley i got new for ~$86 just waiting on it to get here via snail mail and i need to go pick up an outback rear sway bar that i spotted for a cheap upgrade
Old 12-06-2008, 03:10 PM   #8
em1221
Member#: 196771
So I have a 94 Impreza L, and have had a similar "key grinding" issue. I've gotten a hold of a 2000 Impreza RS crank pulley, and it appears to be similar, but with a bit more weight. Will I have issues if I use this seemingly heavier pulley?
em1221 is offline   Reply With Quote
Old 12-06-2008, 08:13 PM   #9
grafton
Member#: 187936
07 WRB STi
be sure to replace the key $2 from the stealership and your golden
Old 12-06-2008, 09:53 PM   #10
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
how you like the new pulley?
watchunglava is offline   Reply With Quote
Old 12-06-2008, 11:10 PM   #11
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Did the keyway get rounded over or misshapen in any way? As long as the keyway (where the moonkey sits) is fine, you should be fine to replace the key and pulley. If the keyway is misshapen, you really ought to replace the crank....not fun.
Stock torque for factory bolt is 101 ft. lbs. Use medium strength locktite this time around.
~Josh~
Old 12-07-2008, 12:01 AM   #12
grafton
Member#: 187936
07 WRB STi
I got a group a pulley from touge tuning in the snowy north
LOVE it works great looks good
~Josh~
keyway was fine as far as i could tell and i torque'd it properly but no locktight
Anyone ever screwed up during sex like this? teesutt Off-Topic 10 08-19-2013 07:42 PM
Anyone seen a Dog Box like this before? Squidz Transmission (AT/MT) & Driveline 30 04-02-2008 01:26 PM
I've never seen a turbo setup like this. JEEENKINNNS Off-Topic 4 02-20-2008 06:27 AM
Anyone elses property taxes go up like this... f4phantomii Off-Topic 28 06-01-2007 01:22 PM
Anyone have a euro front wiper like this? sc00bywagon Interior & Exterior Modification 20 08-08-2005 02:12 AM
