Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 11-13-2008, 03:41 AM   #1
pulser9
Member#: 143202
2003 wrx
black
Default whats needed to fit these
i have a 03 wrx with bc racing coilovers
i want to run 17x9 +30 with 245/40s
what is needed to get these to fit without rubbing
pulser9 is offline   Reply With Quote
Old 11-13-2008, 03:43 AM   #2
cobbyy
Member#: 134117
05 S2000 Yellow!
07 STi Totalled :(
im not a expert but i think u'll need coilovers with camber plates and bolts, roll and pull ur rear fenders and pull ur front fenders.
cobbyy is offline   Reply With Quote
Old 11-13-2008, 01:29 PM   #3
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
^^ Agreed. Probably get by with rolling. Why do you want to run +30?
bcblues is offline   Reply With Quote
Old 11-13-2008, 01:45 PM   #4
fengrr
Member#: 169160
03 WRX
Black on WRB
+30s make it hard to fit. If it was more like +42 you would just have to roll your rears and the fronts would be fine.
I would guess roll and pull the rears, roll the fronts, and run some decent negative camber.
fengrr is offline   Reply With Quote
Old 11-13-2008, 07:23 PM   #5
bcblues
Member#: 17256
04 STi
Yes, I was assuming you would be running more than -3 degrees camber. I just don't know why you don't go with more standard offset.
Old 11-14-2008, 03:44 AM   #6
pulser9
Member#: 143202
2003 wrx
black
i just want to run somthing difrent.
Old 11-14-2008, 04:04 AM   #7
grippy monkey
Member#: 131067
your "stance"
sucks
Listen to someone who fits wheels on loads of cars. You have coilover so you are set there. A little bit of a gap ( a finger or finger and a half) would make it pretty easy. Roll and pull... the pull may not be necessary... There is two ways to do it. You can pull and roll and do everything to the max all at once. Or do the minimum (rear fender roll) and test it out and see what you need to do from there. You usually don't need to do much to the fronts unless you want to go pretty low. My friend personally runs a similar setup with 255's and -2 camber all around... with a little bit of wheelgap and only has the rears rolled flat.
grippy monkey is offline   Reply With Quote
What do I need to make these wheels fit squidzilla Tire & Wheel 6 06-04-2010 10:46 AM
What needs to be done to fit brembos on 07 WRX wheels? gopsu Newbies & FAQs 1 08-22-2007 11:04 PM
What Y Pipe do I need to fit an STi intercooler to an 06 WRX w/18g Mr Nice Guy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 07-09-2007 02:01 PM
What do I need to mate these up? EROCK Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-14-2005 08:16 PM
what would I need to get these working Boss Car Audio, Video & Security 9 04-13-2002 02:59 PM
