Old 11-13-2008, 09:52 PM   #1
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Default How to change color of front Subaru badge??
How do I change the color of my subaru badge in my front grill. Right now it is navy blue and I want to paint it WRB. Is it a navy blue sticker?
What I really want is the "i" badge in wrb but they are hard to find.
Thanks for the help
shamrock 05 is offline   Reply With Quote
Old 11-13-2008, 09:56 PM   #2
watson 29
Member#: 175479
00 2.5RS
STM
nail polish remover+quetips+wrb spray paint+lots of time=wrb backed badge
Same can be done with the I badge
watson 29 is offline   Reply With Quote
Old 11-13-2008, 10:04 PM   #3
mygreenbird007
Member#: 154767
2004 PSM WRX ASPL 35
2001 BRP 2.5RS
Brake cleaner works to remove the paint as well - didn't take too much time to clean and paint it. The removal took a little patience. I heated up the glue and pried it very carefully off. There are a couple threads on this - this one was helpful - http://forums.nasioc.com/forums/show....php?t=1134460 Good luck!
Edit: Make sure your emblem is free of any cracks or chips. My first attempt ended up in the front plastic fogging b/c of a small rock chip in it.
mygreenbird007 is offline   Reply With Quote
Old 11-13-2008, 10:11 PM   #4
mikee_7id
Member#: 145490
2007 Impreza 2.5i
Obsidian Black Pearl
I did my rear badge, and I believe I tried Brake-kleen or how ever its spelled for a while and switched to a carb cleaner instead and it worked faster.
I just did mine in a generic krylon black to go with my OBP car.
Worked out well and just seems to fit better with the car. Like everyone says, don't force anything, getting the emblem apart can be a pain sometimes, but once done, its all worth it. just heat and pry gently.
mikee_7id is offline   Reply With Quote
Old 11-13-2008, 10:14 PM   #5
thejordan
Member#: 185374
brake cleaner with a brush. be careful, i painted mine black, but the glue i used to remount them ate the paint. had to get new badges but for the better.
be careful not to remove or scrub off the silver paint.
thejordan is offline   Reply With Quote
Old 11-13-2008, 10:16 PM   #6
Ryanpm939
Member#: 158177
2002 Impreza WRX
World Rally Blue
i wouldnt do it if i were u,
i tried it and it was alot harder than it looks.
maybe its because it was a 2002 badge but it was REALLY hard to remove all the paint
Ryanpm939 is offline   Reply With Quote
Old 11-13-2008, 10:40 PM   #7
shamrock 05
Member#: 120057
So it is paint, I was under the impression that it was a blue sticker
Old 11-13-2008, 11:36 PM   #8
bugman37
Member#: 184979
2002 WRX Wagon
https://www.subarugenuineparts.com/p...roducts_id=639
thats a link to the blue I thing if u want that instead hope it helps
bugman37 is offline   Reply With Quote
Old 11-14-2008, 12:30 PM   #9
suby wrecks
Member#: 177693
2005 WRX
FYI to the OP, you wanted a WRB colored I, this one is navy blue. I dont think they come in WRB
suby wrecks is offline   Reply With Quote
Old 11-14-2008, 01:23 PM   #10
mygreenbird007
Member#: 154767
2001 BRP 2.5RS
I'm confused by the OP's profile - if it is an 04, the hardest part will be the badge removal from the grille (I don't know the logistics of 02-03 removal).
The glue needs to be heated thoroughly - I used a blow dryer. The paint should come off with no problem with the nail polish remover or brake kleen. Literally, I sprayed the brake kleen on a paper towel and was able to wipe off the paint layer-by-layer; you can try applying it directly at your own risk. Others have used sandpaper - I chose not to b/c I thought it might leave marks on the plastic. The stars take more effort to get clear, but I didn't want to change their color, so I left them alone.
For paint, I used nail polish . I wanted pink, but a pearly STI-ish pink. I've heard people going with enamel or rattle-can depending on their needs - there is a duplicolor that is a very close match to WRB, but I can't think of the name atm. I layered a few coats and let it dry completely overnight. I then used 3M heavy-duty double-sided tape - you can get it or something similar from Advanced Auto - to reattach to the grille.
It was worth the patience and time imo. However, in the end, I removed the pillar on an extra grille and put that on the car instead.
Although it's redundant, I hope this helps
VIDEO: How to Change Oil in a Subaru Impreza Unknown_Driver Service & Maintenance 50 01-25-2009 11:08 PM
anyone know how the change color of defi? sum0325 Electrical & Lighting 0 11-28-2008 04:22 AM
hi how to change color to red hvac,cd player subaru222 Interior & Exterior Modification 10 04-23-2006 01:51 AM
How to change color on oem column boost gauge? Senorpablo Interior & Exterior Modification 3 02-01-2006 07:35 PM
How to change rear and front diff. fluids? skyredrex Service & Maintenance 1 01-05-2004 04:30 PM
