Old 11-13-2008, 10:33 PM   #1
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
Default need stiffer rear suspension- help, need suggestions please!
i have an 02 wrx w/stock suspension. i recently put some 18x8 rims on and the outside of the rear tires rub against the fender on either side when i go over a good size bump, have people sitting in the back, or take a corner too fast. what is a good solution for this problem? i am trying to get some 06 sti rear struts, springs, and tophats to swap out and hopefully stiffen up the rear enough so that this problem goes away. suggestions would be very appreciated. I'm also willing to buy an aftermarket suspension for all four corners, what's my best bet, and can i get away with the 06 sti rears if that opportunity is presented to me? thanks in advance.
theguy is offline   Reply With Quote
Old 11-13-2008, 11:05 PM   #2
subaru3169
Member#: 55252
* pullup bar *
adjust your camber.. get better suspension
subaru3169 is offline   Reply With Quote
Old 11-13-2008, 11:24 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the stock suspension is garbage
all of it
dont try to buy just part of a suspension
that is just ridiculous
pure ridiculous
Old 11-13-2008, 11:30 PM   #4
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
pure ridiculous
thank you, i realize i am an idiot... that is why i ask these dumb questions. i thought i had a solution to the problem, but turns out i don't, who knew. you did, apparently.
On to the other post, if i adjust camber do i want to add negative camber, or reduce negative camber? probably another STUPID question but i don't know the answer
Hence, my request for input and possibly some parts that can fix my problem. Thanks again.
Old 11-13-2008, 11:58 PM   #5
mug23
Member#: 97841
2005 STI Race Ready
OBP/Orange
You can try rolling the fenders a bit to see if that help. If not, you can see if you can add just a small bit of negative camber in the back.
These two things should be able to help you.
mug23 is offline   Reply With Quote
Old 11-14-2008, 12:30 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
d00000000000d
an 02 suspension is likely pretty well done.....the struts are likely done....the stock springs are garbage.....the stock strut tops are garbage and on and on and on
dspec struts
sti take off springs
group n tops
used swaybars f/r and some endlinks
that would be a great start
ya cant just do one end and ya gonna have to replace worn out/junk parts
Old 11-14-2008, 12:30 AM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Well, the best easy solution is to roll the fenders. The next best solution is to find some wheels with the correct offset. If you're rubbing bad at an 8" rim, I'm willing to bet the offset is too low.
You can sometimes stop rubbing the fender by adding negative camber. However, this also can cause the tire to rub the strut. Additionally, extra negative camber in the rear will cause more understeer.
Old 11-14-2008, 01:03 AM   #8
subaru3169
Member#: 55252
* pullup bar *
it really does depend on how your wheels are.. what is the offset?? if it's too much one way or the other, you may rub either on the fender lip or on the strut
when i said adjust camber, it was to increase negative.. such as from -1.0 to -1.5.. also, what is your current camber??
Old 11-14-2008, 01:14 AM   #9
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
What tires, what offset, what alignment...
Old 11-14-2008, 09:23 AM   #10
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
wheels are 18x8 +35offset, here is the thread i purchased from.
http://forums.nasioc.com/forums/show....php?t=1425084
i am pretty sure the tires are BFG g-force sport 235's as i am out of town right now and cannot go look at them to make sure...
i have tried rolling the fender and that did help a little but it wasn't enough. the tire rubs right on the very outside of the wheel, almost on the side. increasing negative camber sounds like it may work with just a very slight adjustment.
and pertaining to me being a noob with the suspension, i am not sure what you are looking for Buttdyno when you ask for the alignment.
thanks for the suggestions and comments.
Old 11-14-2008, 01:59 PM   #11
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
There's your problem.
He wants to know what camber you're running now.
Old 11-14-2008, 10:41 PM   #12
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
what offset do i need?
how do i find out what the camber is?
Old 11-14-2008, 11:14 PM   #13
subaru3169
Member#: 55252
* pullup bar *
if you have ever taken your car for an alignment, they should have given you a printout of the numbers: camber, toe, and cross crosscamber etc.. since you should probably already get an alignment anyway, i guess that's the only way to find out what it is
Old 11-14-2008, 11:33 PM   #14
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
For an 8" wheel, +43 to +47. So at +38, you're 10mm (about 1/2 inch) farther out than you should be. That means your wheel is 10mm more prone to rubbing. If you're barely rubbing now, that means that a correct-offset wheel would keep you from rubbing.
Old 11-14-2008, 11:42 PM   #15
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
thanks will, that is very helpful. i should probably have done more research before i bought the wheels but oh well, my mistake and i have to live with it. i think i have a good idea of what i need to do.
Old 11-15-2008, 10:28 AM   #16
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I agree that your suspension is probably on it's way out.
One simple and relatively inexpensive upgrade would be to get rid of the stock bar mounts and bushings and upgrade to the 2004+ set up. The mounts are much thicker and stronger over the 2003 and earlier versions. You can get a kit from Subaru Genuine Parts for around $50, which is both bar mounts, stock rubber bushings, bushing clamps and two bolts. You will have to supply your own nuts and/or washers.
Old 11-15-2008, 12:01 PM   #17
theguy
Member#: 144244
2006 WRB STi
www.CAMtuning.com
noted! thanks...
Old 11-15-2008, 12:46 PM   #18
Big-E
Member#: 123843
2016 STI LTD CWP
rear suspension noise, need help! bstoehr83 Brakes, Steering & Suspension 0 12-05-2006 12:50 PM
Any help or suggestions please zroom tsuchiya Subaru Conversions 8 06-07-2005 09:20 PM
Need a Rear Diff for my WRX-Please Help Pika's WRX Tri-State Area Forum 6 09-18-2003 01:52 AM
I need a fuel upgrade, give me suggestions please. Blue02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-11-2002 12:26 PM
Legacy rear suspension help needed dvancleve Legacy Forum 1 04-17-2001 11:08 AM
