Old 11-14-2008, 12:04 PM   #1
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
Default 485whp/497tq 30r STI- 11.2/127/1.60's oe clutch/block
recent pics of the car below this boring mod list, I finally got a new built closed deck shortblock in my sti, motor didnt go, just low compression so I sold it. I have broken it in on all stock parts, even w/ a td04 on wastegate boost cuz I didnt have my old turbo. Its been hard to deal with that power trust me. Im just bumping my old thread, these #'s & times were on the stock clutch/block / no tgv deletes, and so on. New mod list below, SOON TO BE TUNED AT YIMI, once I buy my new turbo <-last part I need
PICS BELOW IN THIS POST
04 sti w 50k mi on chasis (java pearl black/ metallic gold)
Turbo kit (piping/ exhaust)
-Made by my older brother kenny here at our shop in Anaheim, CA (Area P Inc./Alliance Fabrications), Rotated 30r turbo kit, V-band
-Garrett GT30 turbo w/ tial v-band hotside
-Cat-less downpipe, up-pipe w/ HD mount to block, Equal Length Header,
-Tial 44mm External Wastegate w/ dump tube (has perf core w/ muffler packing)
-HKS Carbon fiber/ titanium cat-back (soon to be replaced w/ our own or maybe talk to stromung & get one from him)
-Both a tial & HKS blow off valve, using the hks right now
Under hood
-braille 11.5lb battery
-Cusco motor & tranny mounts
-1 step colder NGK spark plugs
-Grimmspeed boost control solenoid
-ss braided AVCS line (oil-turbo)(Alliance Fab)
-Oil catch can
-TGV deletes (Alliance Fab)
-Intake manifold port matched to TGV's
Drivetrain
-ACPT Carbon Fiber 1 piece drive shaft
-Kartboy shortshifter & bushings on the way
Engine Management/tunes & fuel
-Accessport v2.0 w/ 6 maps (2 for each fuel 91,110 leaded & c-16) 1 cons, 1 aggr for each
-Walbro 255 fuel pump w Power Enterprise 850cc sidefeed injectors
-Aeromotive fuel pressure regulator & fuel rails w custom stainless steel braided lines & upgraded fittings
Cooling
-Front Mount Intercooler w/ reverse intake manifold
-Oil cooler where old tmic used to be
-Cold air intake, right behind fog light cover
-Koyo Aluminum radiator (have aftermarket fans, but stock seem to work better so am running those)
-Zerosports upper/lower radiator silicon hoses
-160 degree thermostat
Looks/Aero components
-Seibon CF oem style hood/ w oem style scoop, & CF wingless trunk,
-Zerosports rear bumper (05-07 sti style)
-Vis/Zerosports 06-07 style replica w/ cf canards & splitters, soon to be whole lip & rear diffuser part of rear bumper
-Darkest tint avail, all the way around (not windshield)
-NRG CF wing for track (APR replica)
-Works red durainium lug nuts
Susp, Wheels, Brakes ,...
-RaceComp Eng Tarmac 2 c/o's (600lb hyperco coils up front/500 rear) w/ Vorshlag Camber plates (all 4)
-Whiteline adj. lateral links, tie rods,Roll center adj., steering rack bushings, 24mm adj front & rear sways w/ endlinks
-swapped new style sti crossmember/ steering rack (quicker ratio) doorcards, center console/dash, hubs/knuckles/rotors/wheels/shocks
-lug pattern changed from 5x100 to 5x114.3 ^^^swapped parts are 05-07 sti style, came off an 06^^^
-Cusco front & rear strut braces
-18" Advan RG 2 wheels in 8.5 wide +31 offset (+53 is stock, 7.5") w/ 20mm F/25mm R spacers (for now/ just for flush look on street)
-all fenders rolled & pulled to the max (aggressive flare)(AWDalbert)
-Corner balanced & alligned at West End (darrin) -3.25 F/-2.0 R camber, caster 0 (no adj) and toe is 1/8th in (front)
-2 piece slotted DBA 5000 rotors F/4000's R w/ hawk HPS pads, ss braided brake lines
-245/40/18's (stock 08 sti tires), have a set of Hoosier R6's in 245/35/18(r-comps)
Engine specs (2500k on motor, installed about a month ago)
Closed deck shortblock w H Beam rods & JE forged pistons (99.5mm/ stock size)
ACL Race bearings
1/2" ARP headstuds
11mm oil pump
Valve Job
Race timing belt
ACT HD street clutch
Supertech Ti retainers & dual valve springs
Got 2 back to back 11.2's but got kicked out fo no cage here in socal (fontana) got a bunch of 1.60's, best trap was 127, best 1/8 was 99.49mph
rt --- .655
60'---1.676
330'--4.736
1/8---7.258
mph---99.05
1000'--9.441
1/4---11.255
mph---124.80
On the stock Motor
Car made 484.7whp/ 496.6 tq on C-16 w 27psi, on an aggressive pump map/91oct (23psi) it made bout 400whp, also ran an [email protected] on my 27psi map, & an 11.9 @ 127 on a 24psi map <-(phatron for saying inconsistant driving, it was 2 diff mapsw/ those diff times) w/ 1.60, 60's (stock clutch on street tires w/ 18's, camber was -3.25/-2.0) no launch control
Mainly set-up to road race & compete in Time Attack, not too much a 1/4 fan with my own car, but love to watch
Thinking about running aquamist meth injection sometime down the line
YouTube- GT30R STI c16 launch
KB'izzle is offline   Reply With Quote
Old 11-14-2008, 12:10 PM   #2
KB'izzle
Member#: 169955
30R BUILT STI /AREA
Very Very fast on c-16, I plan only use 110 leaded when road racing tho, love to race older style porsche turbo's/Z06's, w/ any race gas its a good race w the new porsche turbo's/Z06's
Old 11-14-2008, 12:52 PM   #3
AaronWRX
Member#: 7194
2011 997.2 Turbo
23psi on 91 octane? I hate to neigh say but... smells like
AaronWRX is offline   Reply With Quote
Old 11-14-2008, 12:54 PM   #4
AaronWRX
Member#: 7194
2011 997.2 Turbo
I guess anything is possible ... and the posts I've read from HB Speed seem reputable ... but...
Old 11-14-2008, 01:11 PM   #5
GroupN
Member#: 181924
2006 Subaru STi
Or a high reading dyno. I don't think I've seen a 91 octane 30R make over 400whp but whatever. Congrats on your new power.
GroupN is offline   Reply With Quote
Old 11-14-2008, 01:14 PM   #6
KB'izzle
Member#: 169955
30R BUILT STI /AREA
Its definetely true and its not a high reading dyno, The map is not conservative obviously, and wont be used all the time, I have 3 pump gas maps to choose from so, this is only on rare occasion. This dyno reads imbetween a dynojet and a mustang dyno. Thanks for the support
Old 11-14-2008, 01:17 PM   #7
exodus st
Member#: 130602
2004 Meth Addict wrx
Java Blaque'
someone drank their hater-ade this morning..
exodus st is offline   Reply With Quote
Old 11-14-2008, 01:53 PM   #8
jbpsti
Member#: 192057
04 WRX STI
JBP
I think you need to reread the first post. That was on C-16. You do know what C-16 is right?
jbpsti is offline   Reply With Quote
Old 11-14-2008, 01:55 PM   #9
verc
Member#: 41754
03 wrx
gt35r, 2.5L, meth
really? It seems a lot of people not only in the Subaru world, but the EVO and DSM world do 23+ psi on 91 pump on the bigger turbos and with fmic, the OP already mentioned he has a more conservative tune that makes 30 less whp.
I mean let's not forget that on 91+meth most of us do 23-25 psi while some crazy evo guys do 30 psi
verc is offline   Reply With Quote
Old 11-14-2008, 01:59 PM   #10
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Why do people insist on comparing 4g63's to ej20/25?
wrxwhat is offline   Reply With Quote
Old 11-14-2008, 02:00 PM   #11
gr8r rex
Member#: 155652
2002 PSM WRX
www.forced4s.com
Nice numbers! That clutch is going to get pissed at you reallly fast! lol
gr8r rex is offline   Reply With Quote
Old 11-14-2008, 02:06 PM   #12
KB'izzle
Member#: 169955
30R BUILT STI /AREA
yea I think he didnt get that part either, C-16 = 117 oct, 13.50 per gallon
I have a map for:
C-16 @ 27psi makes 484/496
110 leaded @ 27 makes 450
C-16-110 conservative @ 24 (c-16 made 425/397
91 oct @ 23psi made 394/374
91 oct (safer map made 365whp
91 oct old super safe map @ 19psi made 340/354
so again I have a few to choose from, and I know people are going to ask, Im not sure why or how I can safely run 110 leaded or C-16 on the same 24 psi map, I was just told it will be fine.
Old 11-14-2008, 02:15 PM   #13
AaronWRX
Member#: 7194
2011 997.2 Turbo
ehhhh... no I wouldnt say that's right. There are not a lot of people running 23psi on these size turbos in a subaru with just 91 octane.
Is it possible? maybe with very low timing and drownding in fuel. .. but that's not going to make 400whp.
Old 11-14-2008, 02:15 PM   #14
KB'izzle
Member#: 169955
30R BUILT STI /AREA
This sounds like you thought the 91 was that high. No No, 91 was at 394.1whp/374.1tq, please finish reading before posting something everyones going to correct you on. thanks
Old 11-14-2008, 02:15 PM   #15
AaronWRX
Member#: 7194
2011 997.2 Turbo
I have a map for:
What engine management?
Old 11-14-2008, 02:24 PM   #16
KB'izzle
Member#: 169955
30R BUILT STI /AREA
Cobb AP v2.0
Old 11-14-2008, 02:38 PM   #17
Clark_Kent
Member#: 114299
Fine and safe? Very aggressive? That doesn't begin to make sense.
Clark_Kent is offline   Reply With Quote
Old 11-14-2008, 03:16 PM   #18
KB'izzle
Member#: 169955
30R BUILT STI /AREA
You also see where it says used on very rare occasion, Do you not consider few amount of times with an aggressive tune, safe if I dont use it hard all the time or very often, I stand by Jon, he's taking care of me since I first met him, the tune's fine
Old 11-14-2008, 03:35 PM   #19
maramaralula
Member#: 96050
2005 EP Hatch Rrraw!
World Rally Blue
u have dyno graph??
maramaralula is offline   Reply With Quote
Old 11-14-2008, 03:36 PM   #20
KB'izzle
Member#: 169955
30R BUILT STI /AREA
Below & above
Old 11-14-2008, 04:51 PM   #21
HB Speed
Member#: 160911
2008 GT33R Evo X
560+ whp GG
and his 3076 rotated vs TMIC 3071 Stock location turbo @19 psi
wheres the bs again?
HB Speed is offline   Reply With Quote
Old 11-14-2008, 05:05 PM   #22
KB'izzle
Member#: 169955
30R BUILT STI /AREA
Thanks
Old 11-14-2008, 06:38 PM   #23
AaronWRX
Member#: 7194
2011 997.2 Turbo
What's a stock STI do on your dyno? If this is corrected, can we see uncorrected?
Old 11-14-2008, 06:48 PM   #24
jbpsti
Member#: 192057
04 WRX STI
JBP
Why are you arguing with what numbers he got. He posted the dyno numbers and the tune. Who cares what dyno and what other cars posted. He made good numbers. You can't argue with it.
OP, just take it to the track and prove these bitches wrong.
Old 11-14-2008, 07:01 PM   #25
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Yeah op that graph is sweet alot of people are jealous...I love when that happens. Get it to the track and surprise some people there have fun... Yes it can be aggressive and safe. It won't be conservative, but if its aggressive and it's not knocking and serving its purpose I would call it aggressive but safe....Right on.
TDagen is offline   Reply With Quote
GT3076r on a sti stock block and stock clutch, Will I be okay? KB'izzle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 42 05-17-2013 07:38 PM
03 wrx with sti short block and sti 6 speed tranny and 06 gsxr600 motorcycle platinum03wrx/sti Private Vehicle 'For Sale' Classifieds 4 02-16-2008 10:03 AM
2.5 STi short block and 6 new pistons ,rings and wrist pins LiquidForce Private 'For Sale' Classifieds 6 07-13-2006 07:44 PM
What are the big differences between a JDM V8 STI short block and a USDM STI nos Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-09-2005 09:25 AM
