Old 12-16-2011, 05:31 PM   #301
amalgrover
Member#: 183480
2011 Audi A3 Quattro
2009 Forester XT
Originally Posted by Byzantium View Post
The OP specifically said 93 octane so why even bother with that response? E85 has nothing to do with his post.
And anyone running a Dom 4 on a stock TMIC either likes throwing away money or doesn't know what they are doing. Running that TMIC, even a setup the OP would run would limit the amount of boost and timing they would be able to run to a noticeable degree.
that is why i quoted your post and not his...because, while what you posted may apply to him, your post might be misleading to other people because it was so generalized.
...AND...
while i completely agree that it would be limited even on E85 with the stock TMIC, a TRUE 350wtq is definitely a possible number even with the restriction.
amalgrover is offline   Reply With Quote
Old 12-22-2011, 12:05 PM   #302
git_sum
Member#: 303339
2006 Saab 9-2x
Red
Just wondering what i should expect with these mods.
2006 Saab 9-2x aero. 5speed, older style AVO tmic, ported exhaust manifolds, grimmspeed crossover pipe, godspeed catless up-pipe, godspeed tbe, k&n panel filter, vf39 turbo, grimmspeed ebcs, custom tune with cobb v2 running 93 octane, 1000ft above sea level.
git_sum is offline   Reply With Quote
Old 12-25-2011, 03:18 PM   #303
Johnny Law
Member#: 304915
Thanks for the clear explenation.
Johnny Law is offline   Reply With Quote
Old 12-27-2011, 05:15 PM   #304
ben_art
Member#: 172635
2003 WRX Wagon
Exclamation
Car: 2003 WRX Wagon
WHP Goal: 330-340
Fuel: 91 octane pump gas
Shop: unknown, possibly EDO in Huntington? Shop in Costa Mesa?
Dyno: unknown
I would like to stay TMIC, however, FMIC is acceptable if it helps keep the cost down.
Thanks!!!!
ben_art is offline   Reply With Quote
Old 12-27-2011, 08:04 PM   #305
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
^Not on a stock motor.
Byzantium is offline   Reply With Quote
Old 12-27-2011, 08:06 PM   #306
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Easy. Dynojet with 2.0CF
Jubert69 is offline   Reply With Quote
Old 01-26-2012, 09:50 PM   #307
Tonyturkey716
Member#: 307879
2013 WRX Hatch
Car: 2012 WRX n
WHP Goal: b/w 300-350
Fuel: 91-93 octane pump gas
Shop: Cartek (closest one to me)
Dyno: Dynojet 248C
Power Mods:TBE, CAI, Turbo Inlet, Maybe headers & UP, TMIC or FMIC, AP, (BT 1day )
Other Mods: Full suspension kit with bushings and endlinks, trans mount, turbo blanket and heat shield,
Feel free to make suggestions. Not opposed to a FMIC. THis will be my DD. Thanks in advance all.
Tonyturkey716 is offline   Reply With Quote
Old 01-27-2012, 01:04 AM   #308
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
Car: 2004 STI
WHP Goal: 450-500
Fuel: 90oct w/ 50/50 methanol to water by volume
Shop: N/A
Dyno: None Available
Power Mods: UR Rotated Kit Ceramic Coated, GTSPEC UEL Headers ceramic coated, HTAGT3582r, Deatschwerks 1300's, Aeromotive 340, Perrin V1 Topfeed Rails, Perrin BigMaf Intake, Sleeved EJ22 with CP 99.5 Pistons, Forged Rods, Supertech Stainless Intake/Inconel Exhaust valves (Stock Sized), Head castings cleaned up but not ported, GSC S2 Cams, ARP Headstuds, XS Power FMIC with Rotated piping, Cosworth Intake Manifold, TGV's Deleted, Perrin PWI-1 Methanol Kit with Dual point injection post intercooler and pre-throttle body, Grimmspeed Thermostat, Koyo Radiator, ATI Damper, Eboost 2, Defi Gauges Boost/EGT/Oil Press, Cusco Motor/Trans mounts.
Other Mods: Killer Bee Coilovers, Rear Subframe Lock Bolts, Perrin Differential Bushings.
Any ideas on what I'll make after I'm tuned?
Big-Sexy907 is offline   Reply With Quote
Old 01-27-2012, 01:00 PM   #309
amalgrover
Member#: 183480
2009 Forester XT
my guess would be around 450whp. your turbo is definitely capable of your power goal. the 90oct is the only thing that might hold you back. just have to wait and see if the meth/water mix is enough to make up for it.
Old 01-28-2012, 08:22 AM   #310
Big-Sexy907
Member#: 59057
2004 Impreza, STi.
^That's what I was hoping for. I realize the 90oct was a problem but it's all we have at the moment. I'm keeping my finger crossed that we can get something else available that's better.
Old 01-29-2012, 07:16 AM   #311
stockscooby
Member#: 218151
2005 STi
World Rally Blue
Default Hp?
So, when you ask "what do I need to hit 350ishhp" you need to give us the following information
1. HP at the WHEELS -WHP
2. What type of dyno are you going to be shooting for this number on? Dynojet
3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads. P&L
4. Where do you live? If not a well known city, what is the elevation?
Wisconsin
5. What kind of gas will you be using? (octane level) one map for 91 Oct. and one map for E85
6. Are you opposed to a FMIC? I have a Spearco TMIC
Car-2005 STi
I have; Grimmspeed uppipe 38mm EWG, Warlbro 255, catless DP, Cobb catback, injen CAI, Spearco TMIC, Cobb AP, Perrin turbo inlet working on injectors
stockscooby is offline   Reply With Quote
Old 01-29-2012, 09:25 AM   #312
amalgrover
Member#: 183480
2009 Forester XT
350whp shouldn't be a problem for you on a dynojet...especially with E85...dynojets tend to read pretty high so...my guess would be that you come close to or hit your goal with both the 91oct and E85 maps
Old 01-29-2012, 07:40 PM   #313
rexblake
Member#: 178426
2010 S4
Gray
Wisconsin
Car-2005 STi
You will not hit your goal. You need a bigger turbo and supporting mods. The vf39 is not capable of hitting that.
rexblake is offline   Reply With Quote
Old 02-07-2012, 06:34 PM   #314
02Evoslayer
Member#: 309349
thanks for the post it helps alot
02Evoslayer is offline   Reply With Quote
Old 03-06-2012, 04:05 PM   #315
tjmazz13
Member#: 291681
'04 PSM STi
Rotated Borg Warner s256
1. HP at the WHEELS - 300
2. What type of dyno are you going to be shooting for this number on? Dynojet 424
3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads. - IAG Performance
4. Where do you live? If not a well known city, what is the elevation? - Baltimore, MD
5. What kind of gas will you be using? - 93 octane
6. Are you opposed to a FMIC? - No, but I am probably going to stay with TMIC
Car - 2004 WRX 4eat
Will I reach my goal with:
Cobb AccessPort
torque converter
vf39 or 16g
STi "pinks"
STi TMIC
Walbro fuel pump
Downpipe (catless)
Catback
Equal-length headers
Uppipe
Electronic Boost Controller
AEM cold air intake
Turbo inlet
What do you recommend? Thanks in advance!
TJ
tjmazz13 is offline   Reply With Quote
Old 03-11-2012, 12:02 AM   #316
bamagirl
Member#: 312784
2007 STI
great info. thank for the post!
bamagirl is offline   Reply With Quote
Old 03-11-2012, 12:15 AM   #317
Eric13
Member#: 292611
2008 WRX
Car: 2008 WRX
Fuel: e85 and 93 tunes
Shop: unknown
Dyno: unknown (give me numbers that I might get near for a couple)
Power Mods:TBE, TMIC, EBCS, VF52, ID1000cc or DW1000cc, DW65c, Wideband, and possibly a CAI.
Not wanting a FMIC yet, maybe next year I'll upgrade everything if I get bored with the power for my DD needs.
Eric13 is offline   Reply With Quote
Old 03-11-2012, 02:43 PM   #318
amalgrover
Member#: 183480
2009 Forester XT
^ on E85 you will hit your power goal for sure, but on 93oct you will just barely hit or miss it. most the similar setups to yours i have tuned on 93oct are putting down just under or just over 300whp.
Old 03-11-2012, 04:12 PM   #319
Eric13
Member#: 292611
2008 WRX
Thanks, I've been told that I should hit my goals on e85 but there were a lot of people saying different things. I wanted to try and confirm that it will. I really do not mind what 93 puts down since that will be my tune for long trips. e85 will be for the track, DD, and local meets
Ordered most of my parts for that build, just have to buy injectors, wideband, and TMIC then get everything tuned.
Old 03-12-2012, 12:24 PM   #320
tjmazz13
Member#: 291681
'04 PSM STi
Any input?
Old 03-12-2012, 12:39 PM   #321
Byzantium
Member#: 207826
85k 2002 WRX
You're gonna need something larger. IAG's dyno reads low and 4EAT transmissions make less power.
Old 03-12-2012, 12:44 PM   #322
tjmazz13
Member#: 291681
'04 PSM STi
What if I went with a gt30, maybe some 850cc injectors, and a fmic?
Old 03-12-2012, 12:58 PM   #323
Byzantium
Member#: 207826
85k 2002 WRX
You will considerably overshoot your goal and what your stock motor can handle.
Old 03-12-2012, 04:08 PM   #324
yiannis-20xt
Member#: 313195
2005 f20xt auto,lpg
blue
Hello i had a dyno accident 2 weeks ago(crankshaft and 3rdpiston).I put in my fxt20auto,td04,intercooler sti and cobb exaust.128000km and motul 5-40 engine oil for 7000km(is that the reason?)After that i put a new sti block and i hope i have no more problems.After that an other car like mine had the same problem.(sorry for my english,im from Greece)
yiannis-20xt is offline   Reply With Quote
Old 03-13-2012, 11:08 PM   #325
Eric13
Member#: 292611
2008 WRX
Originally Posted by Eric13 View Post
Car: 2008 WRX
Shop: unknown
Hey guys, I posted this earlier in this thread, but I'm thinking about going FMIC now. The Racer X and FMS FMIC's look good, but I want some other opinions on them with my setup that I mention above.
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 51 02-04-2016 10:19 AM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 10:47 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
