#376 |
Member#: 320638
Vehicle:2009 Impreza WRX Subaru Blue |
Excellent post! I was looking around for a thread about this before I checked the sticky section. I'm a new WRX owner and was looking in to a BOV for her, now I kind of know what to look for. Thanks!
#377 |
Member#: 320579
Vehicle:2005 STI ;) Silver |
HOW MUCH HORSEPOWERS DO I GET FROM THE TURBOZ?!?! Just kidding hahaha
Great thread! Glad I stumbled upon this before making other posts and looking like an idiot... I think I'm gonna stick with the stock bov ![]() |
#378 |
Member#: 308816
Vehicle:2012 WRX Obsidian |
2012 WRX
Goal: 280-300 whp on a safe conservative tune. Location: Cedar Grove NJ; 300 Ft Shop: EFI Logics - mustang dyno i believe Fuel: 93 Octane FMIC?: Not anytime soon. all i really want to know is: is a tbe exhaust and a conservative "stage 2" tune enough? rather not run into any boost creep problems; if im most likely going to run into them, would it be smart to invest in an ewg before the tune and tune it accordingly? only got one tune so i want to make the most out of it. |
#379 |
Member#: 178426
Vehicle:2010 Evo X MRt Silver |
You don't need an ewg. You'll be fine. You should be pretty close to the numbers you want on the dyno. EFI seems to be an excellent shop (I've never dealt with them, but get high praise on the forums), if you have questions, give them a call.
#380 |
Member#: 322449
Excellent write up! Will follow on my posts.
#381 |
Member#: 306659
TXIC
Vehicle:2012 Impreza WRX Obsidean Black Pearl |
I want 300whp
2012wrx hatch Whatever dyno is at cobb tuning austin Fmic is ok ![]() 93pump |
#382 |
Member#: 172635
SCIC
Vehicle:2003 WRX Wagon PSM |
what would it take for that on 91 pump too, please! ^^^^^^^
#383 |
Member#: 306659
TXIC
Anyone??
#384 |
Member#: 183480
South East
Vehicle:2011 Audi A3 Quattro 2009 Forester XT |
honestly, a turboback exhaust and a tune should put you pretty close on a 2012 WRX. you should have no problem reaching your goals with one of the nicer aftermarket tmic and an upgraded boost control solenoid. the stock bcs and intercooler do okay, but the nicer aftermarket ones are so much better in terms of performance its not even funny.
here's a video to give you an idea... |
#385 | |
Member#: 288037
NWIC
Vehicle:2013 Orange XV 11' WRX *sold* |
These numbers are kind of a joke. Everywhere you go your going to get different numbers every single time. If you want to say you have a 300HP car with just a DP and tune then find the highest reading dyno around. As for me I dont car what the numbers are as long as the AFR, boost, no knock, ect are all good. Then go run your car on the drag strip and let the car do the talking not the dyno number. |
#386 |
Member#: 183480
South East
well, fortunately, you weren't the one who asked the question, and with requirements like your's you probably save quite a bit of money because ZERO aftermarket parts or tunes are required to achieve those things.
getting ballpark numbers from a similar dyno to what you will be using isn't a bad idea. it kind of gives you an idea of what parts you need to accomplish the goal of how you want the car to drive. maybe he rode in a wrx that had 300whp, and that is exactly how he wants his car to drive. just modding pointlessly with no goal to work towards is kinda dumb and can be very expensive. it may work for some people, but some people like to plan things out, make checklists for parts they want/need to buy, and work towards a specific goal. fyi, the cobb tuning facility in plano, tx vs. the cobb tuning facility in austin, tx is going to have almost ZERO changes to atmospheric conditions (obviously your conditions from day to day will move around based on the weather but you get what i am saying), dyno type, dyno calibration, tuner, etc...so, for him, that video is VERY informative (that is alot of the reason that i posted THAT SPECIFIC video). another thing is that cobb tuning DEFINITELY doesn't have what is considered a high reading dyno. |
#387 |
Member#: 76673
Vehicle:2006 Impreza WRX STi Crystal Grey Metallic |
Ok guys, what do you think I will make once I'm am off my break in tune. I have an 06 STi and will have maps for 93 pump gas and E85. I will be tuned on a mustang dyno. Here are my current mods. I will post my dyno sheet once I get my protune.
KS Tech 83mm Type 2 Perrin 3in Turbo Inlet FP Green HTA Turbo Process West Intercooler w/splitter TGV Deletes GrimmSpeed Phenolic Spacers 8mm DW300 Fuel Pump Aeromotive Fuel Pressure Regular Stainless Steel Fuel lines w/-6 AN Fittings ID 1000cc Fuel Injector Kit (Top Feed Conversion) Wiseco Forged Pistons 99.5mm Gates Timing Kit Group N Mounts (ENG/TRANS) GrimmSpeed Up-Pipe Tial 38mm External Wastegate Turbo XS Turbo Back Exhaust Stainless Steel Clutch and Brake Lines GrimmSpeed EBC ACT StreetLite Clutch/Flywheel |
#388 |
Member#: 183480
South East
just a ballpark guess, but i would say 350-375whp on 93oct and 375-425whp on e85...
#389 | |
Member#: 306659
TXIC
all great info |
#390 | |
Member#: 325499
#391 | |
Member#: 76673
#392 | |
Member#: 325499
In terms of the benefits and which cam to select, your best bet is to talk with your tuner/engine builder or post a question in the built motor area. Typically, cams will affect either top end or mid range depending on what cams you get. It generally is a good idea to run different cams if you have a bigger turbo though. You may also have to run a higher idle and driveability will be reduced a bit with cams that produce more power at the top of the range. Here's a link with info on the cams I have: http://www.tomei-p.co.jp/inf/pdf/110-English.pdf |
#393 |
Member#: 326636
this is all good information, but is there anyone who has but on various mods and tested them on engine dynos? this would eliminate variations on wheel dynos and give a better answer as to what mods people might want to do first.
#394 |
Member#: 183480
South East
i think that you are asking for too much here ^
...you are talking about a tuner using hours upon hours and days upon days of their free time (since they wouldn't be getting ANY money whatsoever) to test certain setups on their dyno for no reason other than to help you pick parts. thing is, even if you took the same car on the same dyno on the same day and swapped out the engine with an exact same engine, the dyno numbers will more than likely change. this is because every machine is going to be a little bit different. so even if one tuner did this, it wouldn't really help you much. |
#395 |
Member#: 325499
Tomei, and other cam manufacturers, have tested all of the cams they produce and have .pdfs available that show the differences the cams will produce. Google will help you find that info, but once again, your best bet is to talk with your tuner. Chances are, they have built several cars to various levels, so they can tell you roughly what to expect from a certain set of modifications.
#396 |
Member#: 327692
Great info!
#397 |
Member#: 243008
SCIC
Vehicle:2012 STi Limited SWP |
2012 STi Limited
1. HP at the WHEELS? - 320-340WHP 2. What type of dyno are you going to be shooting for this number on? - Mustang 3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads. - COBB TUNING SoCal 4. Where do you live? If not a well known city, what is the elevation? - 20FT (twenty feet above sea level) 5. What kind of gas will you be using? - 91 6. Are you opposed to a FMIC? Nope I am currently deployed to Afghanistan right now. When i get home im planning on modding my car for a little more fun. I have owned a 07 WRX an 06 STi and now my 12 STi. Ive looked at lots of posts to see what i should do first. To start i was thinking of getting... -Perrin Downpipe -Catback Quad tip Exhaust -Perrin Turbo Inlet Tube -Perrin CAI -TVG Deletes -Tomei Unequal Length Headers -Tomei uppipe -Accessport -Protune from COBB Last edited by iRaWr; 08-11-2012 at 03:02 AM. |
#398 |
Member#: 298472
NESIC
Vehicle:2003 Bugeye |
2003 WRX
1. HP at the WHEELS? - 250-280whp 2. What type of dyno are you going to be shooting for this number on? - Mustang 3. If possible, tell us what shop it is. Someone may know how high or low that particular dyno reads. - EFI - Connecticut 4. Where do you live? If not a well known city, what is the elevation? - Hartford , CT 5. What kind of gas will you be using? - 93 6. Are you opposed to a FMIC? rather stick to tmic |
#399 |
Member#: 296248
RMIC
Vehicle:2005 wrx wrb |
2005 WRX
Goal: 300 whp on a conservative tune. Location: poplar bluff, mo 361 Ft Shop: Et tuning- dyno jet Fuel: 93 Octane FMIC?: Not anytime soon but later yes |
#400 |
Member#: 331469
Since dyno numbers are so variant, I would rather ask what I would need to do to gain ~25% engine output. I have a 2004 wrx and, i woukd like it to feel a little more powerful in 1-3 gear and at possibly lower rpms.
93octane fuel, 2000ft elevation. Staying tmic, since im not looking for anything extreme. Looking for 50-80 hp increase, so the car has that punch when the turbo spools up. Thanks! |
| Thread Tools | |
| Display Modes | |
| I’m flying to Orlando. What do I need to do in the airport and what to bring home? | KingGalantVr4 | Off-Topic | 37 | 01-14-2010 11:49 PM |
| what do I need to hit 250whp? | juvenescence | Newbies & FAQs | 27 | 10-07-2009 10:47 PM |
| What do I need to hit 350-375 HP? | pipchick | Newbies & FAQs | 49 | 08-15-2009 04:04 PM |
| I want to do my own 30,000 mile service, what do I need to do? | Drav | Service & Maintenance | 12 | 06-20-2005 06:43 AM |
| ('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! | SuBaRu-ImPrEzA_RS | Impreza Forum | 2 | 06-03-2001 10:11 PM |
