Old 09-22-2013, 07:51 PM   #501
jumpin-WRX_09
Member#: 368058
2009 Impreza WRX
being new to the subie world this has helped to broaden my thoughts when asking questions... thanks all
jumpin-WRX_09 is offline   Reply With Quote
Old 10-07-2013, 10:47 AM   #502
wrxaddictseba
Member#: 369290
2013 WRX hatch
stage 2
I'm looking to make around 300 whp and tq on 93 Octane and stock turbo. 2013 wrx hatch, In Richmond, VA. i don't want to risk reliability or add turbo lag
wrxaddictseba is offline   Reply With Quote
Old 11-01-2013, 12:50 PM   #503
Mdsiman
Member#: 360019
2013 Wrx
Downpipe and tune
Mdsiman is offline   Reply With Quote
Old 11-17-2013, 11:56 PM   #504
XT Geezer
Member#: 371087
2005 Forester XT
Aspen white
First Suby. Not WHP focused. Initially! Reliability and longevity, with a touch of mpg.
"05 FXT with 111k Seemingly well taken care of.
Charlotte 700' - Elkin 1100' Up to 6000' on the BRP. (45 mph limit)
Shell 91; damned ethanol, 10-15%
I just want to make sure I'm headed in the right direction.
Timing belt with everything changed. A turbine water pump.
Does the debate over K&N versus paper hold water?
Cobb V2-002
Up pipe/down pipe Any suggestions welcome. All look the same! With reasons, of course.
Borla cat back. 3" and still moderately quiet.
Proper tuning. Probably not dyno tuned at this time.
Boxer4Racing, Marshall, NC Dale Teague tuner.
Under serious consideration:
Air oil separator
Turbo timer
Larger capacity oil pan
Mobil !, old friend. 3500 oil changes; will take some getting used to.
Anything superfluous? Anything overlooked?
Thanks.
XT Geezer is offline   Reply With Quote
Old 11-18-2013, 01:56 AM   #505
Herc6180
Member#: 373905
2002 Bugeye
Black/Green
Outstanding thread, Cant wait to get past my newbie stage and start a thread!!! =)
Herc6180 is offline   Reply With Quote
Old 11-18-2013, 02:01 AM   #506
Herc6180
Member#: 373905
2002 Bugeye
Black/Green
Cobb V2-002
Air oil separator
Turbo timer
Thanks.
I would say you seem to be headed the right direction, although I am no expert.
Old 12-19-2013, 10:43 AM   #507
Awarfield25
Member#: 375836
2015 WRX
I have a 2008 WRX. I would like to hit 300WHP as safe and reliable as possible.
I currently have Cobb SF Intake and Downpipe running OTS Stage 2 map.
Do you think I am even close for a 2008? What else should be done? Thanks!
Awarfield25 is offline   Reply With Quote
Old 12-25-2013, 11:27 PM   #508
Hoon Goon
Member#: 335538
2007 STi - Kornluvr
You will need to upgrade to a vf52 at the least. 260-270 at the wheels is maxed for the td04. 300 is pretty easy with a vf52 and is a straight swap with a tune.
Hoon Goon is offline   Reply With Quote
Old 12-26-2013, 12:11 AM   #509
cplay4me
Member#: 308953
2006 STI
Dark Silver
Default Great stuff
New to the forum - appreciate all the threads covering basics and common questions!!! Thanks for taking the time to do it.
cplay4me is offline   Reply With Quote
Old 12-28-2013, 02:47 PM   #510
lgtwagon05
Member#: 377181
thank you so much for all information
lgtwagon05 is offline   Reply With Quote
Old 01-03-2014, 08:57 PM   #511
jrv2223
Member#: 372963
Thanks for the great information. For the NEWB like me to Tuning this helps dumb it down for us.
jrv2223 is offline   Reply With Quote
Old 01-08-2014, 12:04 PM   #512
aspade17
Member#: 360251
13 WRX
13 wrx sedan, 93 octane 1,300ft of elevation. Looking for 300-350whp
aspade17 is offline   Reply With Quote
Old 01-08-2014, 12:32 PM   #513
bugeye_drew
Member#: 378129
2003 wrx
Td04 ?
bugeye_drew is offline   Reply With Quote
Old 01-08-2014, 01:21 PM   #514
Razgeiz
Member#: 358782
2013 STi
For 300 whp a stage 2 pro tune.
Razgeiz is offline   Reply With Quote
Old 01-09-2014, 01:06 PM   #515
ciege125
Member#: 306475
2012 STI Sedan
Hey guys. So im running cobb stage 2 ots map w/ catless dp and invidia exhaust. Im going to take it in for a protune here in the near future but just want to get a better idea what you high hp guys are running. Im looking to get the most out of this protune so i dont have to keep getting it retuned, what do you guys think i should add on to get the most "bang" for my buck? Currently all i have in mind is the cobb intake, grimmspeed EBCS, NGK sparkplugs and possibly a fuel pump. Any other suggestions would be great. Aiming for hp to be in the 400's
ciege125 is offline   Reply With Quote
Old 01-09-2014, 01:16 PM   #516
savvy
Member#: 127208
2011 STI
^ forged pistons, fuel pump, bigger turbo at the least.
savvy is offline   Reply With Quote
Old 01-09-2014, 01:25 PM   #517
Splatum420
Member#: 264261
2015 STI
Always Changing
Hey guys and gals,
I thought I would share my build to help someone in need.
I am running a 13 DGM STI with the following mods.
AWHP: 417 on a half 91/100 octane tune at Church Automotive.
Mods:
Blouch TDO6 20GXT 8cm
DW 850's (Did not do my research and went to small, go bigger if you have plans for bigger gains or E85 in the future)
DW65 FP
Perrin FMIC
PERRIN CAI
Catless invidia DP
Invidia Dual N1
Don't go cheap on your tune and you will get some good power. I do monthly logs and knock on wood, I have had zero knock and going 6 months strong as a DD with stock internals.
I hope this helps someone.
Splatum420 is offline   Reply With Quote
Old 01-09-2014, 01:26 PM   #518
subawoo77
Member#: 370658
07 Hawkeye STI
power difference between whp and crank hp ??? whats the skinny??
subawoo77 is offline   Reply With Quote
Old 01-10-2014, 10:39 AM   #519
Razgeiz
Member#: 358782
2013 STi
Crank HP is what the motor is making. Whp is what makes it to the ground after valve train and driveline losses
Old 01-10-2014, 04:34 PM   #520
hogdweeb
Member#: 376594
2004 WRX Sedan
Gonna be looking for a ~300WHP. No AWD dynos around me (that i know of), so its gonna be a crap shoot to a degree. IF I did the math right, before a tune I'll be at like 276. Just hard numbers. Factory boost off my td04. I'll be increasing that with a boost controller, and adding an e tune from Eric at Torqued Power, What can I ball park? ~700' elevation. Dont want to getting into playing with turbo's too much, not enough knowledge on aftermarket ones, and not sure I can fork over that much money for a desired amount of power being so "low".
hogdweeb is offline   Reply With Quote
Old 01-10-2014, 06:29 PM   #521
Razgeiz
Member#: 358782
2013 STi
Downpipe and tune is all you need
Old 01-11-2014, 12:52 PM   #522
boardinjorden
Member#: 349610
06 STI
Cool
Originally Posted by TRJ2.5GT View Post
Im looking to get over 300hp to the wheels. Any suggestions on how to get to this mark.
fuel pump 255lph, injectors, bigger turbo ( i like blouch) turboback and a tune
boardinjorden is offline   Reply With Quote
Old 01-15-2014, 03:12 PM   #523
themasimoto
Member#: 345441
2002 Impreza WRX
I have a bugeye with:
Catted Invidia dp
Pink STi injectors
Walbro 255
TurboXs fmic
TurboXs bov
What can I do to reach 300 whp?
themasimoto is offline   Reply With Quote
Old 01-15-2014, 03:26 PM   #524
Razgeiz
Member#: 358782
2013 STi
Catted Invidia dp
Pink STi injectors
Walbro 255
TurboXs fmic
TurboXs bov
E85 pro tune ebcs
Old 01-16-2014, 01:03 PM   #525
ciege125
Member#: 306475
2012 STI Sedan
Thinking about running NGK one step plugs, but have read on a few sites that they arent nesecary and can even be harmful if your motor isnt putting down enough power..? Any truth to this? I was planning on throwing those with a fuel pump and ebcs on my stage 2
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 51 02-04-2016 10:19 AM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 10:47 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
