Old 02-03-2010, 10:34 PM   #101
mth4life
Member#: 228506
Thanks for the great info, will help me out in the future.
mth4life is offline   Reply With Quote
Old 02-16-2010, 10:20 AM   #102
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
What would a good mod list look like for making 330 awhp on a version 8 EJ207
Mustang Dyno
93 oct Pump
35-45 degress outside w/centeral connecticut elivation
I am not opposed to a FMIC but would prefer to leave the $$$ in my pocket and the JDM sti tmic I think is able to get me to my goal
Current mods.
Invidia n1 race catback
Custom 3" bellmouth catless downpipe
Ngk irridium 1 colder
Shell 93 oct. Winter gas
Walbro 255lb/hr
JDM Version 8 EJ207
TwinScroll IHI VF37
I was thinking at 22psi 300awhp with this setup. So maybe SMC meth kit, 850cc injectors, and a big MAF/intake will get me to 330awhp???
Voice your opinions all please! Thanks alot
prokaw875 is offline   Reply With Quote
Old 02-19-2010, 07:08 AM   #103
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
No one???
Old 02-25-2010, 12:51 PM   #104
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Its depends. On the Mustang near me you would be looking at somewhere in the 270-280 range, maybe slightly less. Dont be sad, it takes a 20G+FMIC and 22PSI to break 300whp on that dyno, and stock STIs make @210whp.
Most Mustangs read a little higher. The BIGMAF will get you nothing if you arent maxing out your stock MAF, and with that turbo, no headwork or cams there is almost no chance you will.
A TurboXS/Perrin/APS tmic will make a good bit more power than the JDM STI tmic, honestly the JDM STI tmic is barely any better. Its the exact same core with like 3 more rows. That only makes it flow a LITTLE better, not cool any better to speak of. The power difference between that and a USDM sti tmic is pretty close to impossible to measure, and is well within the error of margin of a dyno.
You will make a little more power on that setup than you would a comperable single scroll setup, so compare it that way. You will however, make a lot more low end power and have better throttle response, slightly better than the 2.5L single scroll STI.
22PSI will be ok, but its pushing the limits of that turbo, sort of. At 22PSI I would absolutely recommend the SMC meth kit, but you dont need to spend the money on 850cc injectors, 750s will be plenty. Especially with the meth.
SMC is gone, and the AEM kit is cheaper anyway and has a few more and nicer features (including they VERY cool new pump system)
A FMIC is ALWAYS going to outperform a TMIC, but a quality TMIC will work very nicely with your setup, and is a little more New England winter friendly. TurboXS's tmic is cheap too, while still having a very nice core. Sell the JDM sti tmic and it offsets that cost a LOT.
I would HIGHLY recommend running copper plugs. You will only get say 10-12k out of them, and many people recommend replacing them when you do oil changes (3000-3500) but they are dirt cheap and have a stronger spark, that will hold up to the high boost better. I have yet to see a platinum or iridium plug outperform, or even perform as reliably as a copper plug. Plus you can run a stock heat range copper, which will perform better when warming up and I believe low rpm light throttle and cleaner emissions (dont quote me on that part about low throttle and emissions) Because a copper plug by its very nature will perform like a slightly cooler plug when compared to an iridium or platinum.
I would go with
TurboXS TMIC
AEM alcohol injection kit
750cc injectors
22PSI (Actually, I would do 23)
Replace everything in the intake tract in front of the turbo. You dont need a big maf, but if you can get one cheaper than a normal sized one, go ahead. Its not needed but it wont hurt anything.
I definitely wouldnt count on 330whp, and would place you more in the upper 260s, but trust me, it will be VERY fast, capable of an 11 if you drive it VERY well, especially if you drive to NJ and do it at ATCO. On a dyno like Andrewtech/TurboXS has, plan on 330-340 easily.
Defiant Autospeed is offline   Reply With Quote
Old 03-08-2010, 11:48 AM   #105
joosky
Member#: 240513
2006 WRX, stage 2
BLACK on BLACK
nice this is legit. yo
joosky is offline   Reply With Quote
Old 03-09-2010, 03:07 AM   #106
sierra68
Member#: 204180
08 Subaru STI
Originally Posted by Audiosavvy View Post
You will be lucky to break 330whp realistically on that turbo and 92 octane.
If you want 375 whp on pump gas, you're going to need a 3076 or DomIII at minimum
Audiosavvy:
Same basic setup as above with a few differences. I was hoping to hit 365/375 whp/wtq. . .think it's a possibility or am I pipe dreaming?
1. 365 - whp
2. DynoDynamics
3. Corr Performance in Baton Rouge, La. but Jorge from P&L is flying down to tune my car
4. New Orleans, La - below sea level, lol.
5. 93 Octane
6. P&L FMIC
Current (to be installed next weekend) mods:
FP HTA68 PnP/Coated
P&L FMIC
P&L CAI
P&L catted DP
P&L Fuel Pump Mod (Walboro)
P&L EWG
Forge BOV
APS Turbo Inlet
Blitz midpipe
Blitz Nur SpecR Quad Exhaust
Cobb APv2 w/ProTune
Injector Dynamics 1000cc injectors
Lachute Performance EL headers
GS EBCS
KillerB Oil pan & Pick-up (waiting on back order)
Stock Plugs
Crawford AOS v2
Thanks for the input. . .
sierra68 is offline   Reply With Quote
Old 03-12-2010, 09:31 PM   #107
KPWRX
Member#: 199053
2008 STI
Dark Grey
Amen Brutha! I got 275 whp with stage 2 on one dyno, then went to stage 3 and got 265 whp on a different dyno. But car is a hell of alot faster with stage 3, I dropped 6 seconds off my lap times at Willow Springs. Go figure??? Dyno numbers are just for bragging in the garage. What really counts is results on the track!!!
KPWRX is offline   Reply With Quote
Old 03-17-2010, 10:47 AM   #108
r1ch1e
Member#: 241432
2008 Civic Si
Fiji Blue Pearl
hi guys i will be ordering my sti in a week. i can't wait. i was wondering what do i need to get or do to get atleast 400awhp? The tuning shop that i will be going to is in connecticut. i forgot the name. i'll be going with a buddy with his sti this spring/summer. thank you for the input and help. i've been reading and turbo and subaru is new.
r1ch1e is offline   Reply With Quote
Old 04-14-2010, 08:07 PM   #109
suprboy02
Member#: 155747
2007 Impreza Wrx TR
Black Pearl
found this to be very helpful. thank you.
suprboy02 is offline   Reply With Quote
Old 04-20-2010, 04:18 AM   #110
Buddydawg
Member#: 244557
1991 Impreza L 2.2
**New**
feel free to send me information on mods for a 1998 subaru impreza L. (anyone)
I know its not the fastest subaru but i want to know what options i have to get this thing goin fast i.e. aftermarket parts and specs
Buddydawg is offline   Reply With Quote
Old 04-20-2010, 12:54 PM   #111
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
Originally Posted by sierra68 View Post
Audiosavvy:
1. 365 - whp
2. DynoDynamics
5. 93 Octane
6. P&L FMIC
FP HTA68 PnP/Coated
P&L FMIC
P&L CAI
P&L catted DP
P&L EWG
Forge BOV
APS Turbo Inlet
Blitz midpipe
Cobb APv2 w/ProTune
GS EBCS
Stock Plugs
Crawford AOS v2
You will not make that power with that turbo on pump gas. Also, any turbo with a 7cm hotside on your motor is a mistake. If you want that power on pump, go with a 3076 or equivalent.
Audiosavvy is offline   Reply With Quote
Old 04-26-2010, 02:05 AM   #112
MistaWrx
Member#: 244393
MBP
Great post very imformative
MistaWrx is offline   Reply With Quote
Old 04-26-2010, 07:04 AM   #113
Davenow
Member#: 23676
Audiosavvy:
1. 365 - whp
2. DynoDynamics
5. 93 Octane
6. P&L FMIC
FP HTA68 PnP/Coated
P&L FMIC
P&L CAI
P&L catted DP
P&L EWG
Forge BOV
APS Turbo Inlet
Blitz midpipe
Cobb APv2 w/ProTune
GS EBCS
Stock Plugs
Crawford AOS v2
You definitely want to go with a different turbo on your 2.5L motor. The "body" of the HTA68 simply is too small and will choke off your motor.
Also you want a turbo with an 8cm hot side, and a large compressor housing. The 8cm hot side allows the 2.5 to breath, which not only makes more power up top (which is what people think is the only point) but MAKES MORE POWER DOWN LOW and improves throttle response everywhere, low, mid, and high. Its all about volumetric efficiency. You need a turbo that not only has a compressor wheel big enough to push the amount of air you want (the amount of air you want is directly proportional to the amount of power you want to make) but that the body is large enough to physically allow the volume of air through.
Also, the numbers you are looking to hit, simply are not going to happen unless the dyno you are on is so incredibly high that it is essentiall lying to you. The shop you choose can blow smoke up your ass all day about it being real, but I assure you that if you come up against a car that ACTUALLY makes that much power, you will get pooped on HARD.
Honestly man, TD05-20G 8cm will make you a LOT happier than that HTA68 for your goals. I would also HIGHLY recommend an EWG and maybe even meth injection.
Old 05-01-2010, 04:45 AM   #114
surf_wagon
Member#: 241525
Great thread,
im just about to make a thread along these lines actually due to my little knowledge around the boxer engine.
surf_wagon is offline   Reply With Quote
Old 05-01-2010, 02:54 PM   #115
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
Audiosavvy:
1. 365 - whp
2. DynoDynamics
5. 93 Octane
6. P&L FMIC
FP HTA68 PnP/Coated
P&L FMIC
P&L CAI
P&L catted DP
P&L EWG
Forge BOV
APS Turbo Inlet
Blitz midpipe
Cobb APv2 w/ProTune
GS EBCS
Stock Plugs
Crawford AOS v2
That's a pipe dream. You're looking at slight over 350 on E85. On 93, you won't even come close to your goal. You're looking at an FP Green or larger to get what you want.
Byzantium is offline   Reply With Quote
Old 05-03-2010, 10:22 PM   #116
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
OK, Hi everyone just need advise/suggestions on how to at least reach a hit of 400whp on a dyno dynamics. My goal has always been to see a 400 whp # and so far I have always tried with only 91. I am throwing away my GT14 that only gave me 330 on 91 and changing to smaller TD05 20G 7cm2 which I plan on using higher octane/race gas on. Why, because I miss being able to drive my car on the streets LOL.
My mods are
04 STI swap engine, trans, rearend, axles,
TGV deletes
PE 850 injectors,
TD05 20G 7cm2 PNP/coated
APS 70mm CAI
APS 3 in inlet
Tomei unequal length headers
HKS EVC 6 boost controller
38mm waste gate
walbro 255
electronic 3in cutout
PNP throttle body
PNP intake manifold also Reversed
Custom FMIC for reversed mani
And at least 100 octane more if needed.
I am planning on getting a new block soon but am in no rush to let this one give the ghost. lol
Please let me know what else If anything I need to just see a SPIke of 400.
Thanks
wrxsubiemod is offline   Reply With Quote
Old 05-03-2010, 10:26 PM   #117
Byzantium
Member#: 207826
85k 2002 WRX
That is also a pipe dream. Dyno Dynamics read low. You're gonna need at least a 50-55 lb turbo and higher octane gas to graze the 400 marker.
Old 05-04-2010, 12:00 AM   #118
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
OK, great thing I posted it on here when first thing is to tell me a different turbo.
Lets do this........ Forget the dyno, what else on top of what I have do I need to hit or get even close to 400?
Come on! cams, meth,
Old 05-04-2010, 08:58 PM   #119
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Bump for a good answer?
Old 05-04-2010, 09:49 PM   #120
rexblake
Member#: 178426
2010 S4
Gray
You can't forget the dyno, everything depends on that if you are looking for a specific number of whp. For an example, I made 342whp with 29psi and E85 on a dyno dynamics with a 68hata. My dom 3xt-r is making 392 whp at 27psi, E85 and my 1000cc injectors are maxed, at altitude none the less. You need at least a dom 3, fmic, injectors, fuel pump, high octane, and high boost.
If you want to be over 400whp, I'd say go rotated gt3076 or dom 4 or higher and run E85. Of course to run E85 you'll need huge injectors (might as well go 2000cc), swirl pot, and prolly Bosch inline pump fed by one (preferably two) walboro's, new fuel lines, and a fpr perhaps. 400whp on a dyno dynamics is no joke.
rexblake is offline   Reply With Quote
Old 05-04-2010, 10:28 PM   #121
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
http://forums.nasioc.com/forums/show...light=yimi+20g
OK here is a 20g that made 452WHP with just E85.
So I guess im just asking for too much of Nasioc to give me a good answer on how to make 400 on a 20g?
Seriously guys!
should I just go meth?
cams
NOS LOL
Old 05-04-2010, 11:44 PM   #122
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Bump again for a better answer
Old 05-05-2010, 12:07 AM   #123
rexblake
Member#: 178426
2010 S4
Gray
A better answer? Seriously? Did you read the thread you posted? It was a freak, he's never seen a 20g make that much power before.
I understand this is the newbie section so I'm going to say this in the most non bashing way I possibly can. Since you clearly can't understand common sense, multiple educated answers, or any kind of research, I'd simply say throw a vf39 on there and crank the correction factor to 2 or 3 if you want a "500hp" car.
Old 05-05-2010, 10:02 AM   #124
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
^ LOL OK I give up. 20gs cant make 400. OK better start a new thread in the power braggin section and call out the liars
Old 05-05-2010, 10:03 AM   #125
Byzantium
Member#: 207826
85k 2002 WRX
Seriously guys!
cams
NOS LOL
Ya, on an Dynojet that's reading even too high for a Dynojet. That thing made 377 on 91 octane.
400 is not a number you should set your goal at with a 20G. Why are you actively choosing to restrict your own setup and preventing yourself from using the easiest way to achieve your goal?
What do I need to hit 350-375 HP? pipchick Newbies & FAQs 51 02-04-2016 10:19 AM
Iím flying to Orlando. What do I need to do in the airport and what to bring home? KingGalantVr4 Off-Topic 37 01-14-2010 11:49 PM
what do I need to hit 250whp? juvenescence Newbies & FAQs 27 10-07-2009 10:47 PM
I want to do my own 30,000 mile service, what do I need to do? Drav Service & Maintenance 12 06-20-2005 06:43 AM
('93-'01) what do i need to do to try and get an autocross/Solo2 here...HELP! SuBaRu-ImPrEzA_RS Impreza Forum 2 06-03-2001 10:11 PM
