Old 11-14-2008, 02:14 PM   #1
twiSTies
Member#: 98689
2005 Impreza WRX STi
Crystal Gray Metallic
Default Dom 2.5R Owners: What are you running?
I haven't seen many 2.5R Polka Pickle owners on here through searching, so I was wondering what everyone is running and putting down with this turbo. I'm interested in sticking with 93 pump on my STi and IWG specifically.
thanks!
twiSTies is offline   Reply With Quote
Old 11-14-2008, 06:06 PM   #2
treystoys
Member#: 97436
03 toyota tundra
gray..missing my WRX's :(
I run one on my jdm ver 8 sti motor in my 05 wrx...I have a ppg 1-4 tranny, so its a bit tricky at the track trying to get it hooked up. My best run to date has been [email protected]..that was with a 1.9 60' and a tune that was not totally complete and weather was in the low 80s. I run straight 93 octane and between 22 and 23 psi. I think the car will go 11.8 or so with a few more mph soon, I have been working on a solid street set up, and am now just starting to tweak the map with a little more timing and a tad leaner...still right at 11:1 afr. I too run the internal gate with the 15psi actuator.
Its been a pretty cool turbo, I do think it would be a bit better suited to the usdm sti motor...I'm seeing peak boost in 3rd gear at about 4k, and thats with the very tall ppg 3rd gear.
I really don't know what it puts down, Clark turner did the initial tuning for me and has been helping me throughout the tuning process...he had figured it should be good for 350whp on a low reading dyno.
ttyl
Trey
treystoys is offline   Reply With Quote
Old 11-15-2008, 03:38 PM   #3
twiSTies
Member#: 98689
cool...i guess no one else has any numbers with this turbo on here?
Old 11-15-2008, 03:55 PM   #4
wrxsubaruwrx
Member#: 60415
1973 Gran Torino
Green w rust coloration
I'm running the dom 1 .It spools fast and makes good power . I know you asked about the 2.5 but the dom 1 is a great turbo .My car put down 377 and 350 trq on dyno dynamics dyno .
wrxsubaruwrx is offline   Reply With Quote
Old 01-18-2009, 10:07 PM   #5
jpwrxtr06
Member#: 187052
2006 Wrxtr 6-spd
DOM3backoff i'mascientist
I'm interested to know this also. trying to decide between the 2.5r polka, td06-20g w/8cm and the dom-3. All look good but i searched and not much info on the 2.5r
jpwrxtr06 is offline   Reply With Quote
Old 01-18-2009, 11:34 PM   #6
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
i have a dom 2.5 on a crawford s2 block running around 19 psi on a ecutek tune. waiting to get retuned with new injectors so i am looking at HOPEFULLY more power, but on 91 cali gas i had 307hp/320tq.
surfer5567 is offline   Reply With Quote
Old 01-19-2009, 12:05 PM   #7
klattery
Member#: 48503
2004 STi ATP3071
Dom 2.5 has the same CHRA as the ATP 3071. The housings are different, but most think the ATP housing looks better. There are quite a few posts on the ATP 3071. That should give you an idea what the Dom 2.5 can do, but remember that housings do matter.
klattery is offline   Reply With Quote
Old 01-22-2009, 05:36 PM   #8
jutes85
Member#: 127232
E92 M3
98' Foz
RONIN on iwsti is running it. Great numbers.
jutes85 is offline   Reply With Quote
Old 01-22-2009, 08:51 PM   #9
northmiler89
Member#: 157163
2008 STI
Silvarrrrrrrr!
QFE. Joes setup is sick. Along the lines of 389whp and 390wtq on EFI Logics Mustang Dyno.
RI 93 Pump with 50:50 alky. IWG, perrin headers, grimmspeed uppipe, cobb tbe, aps FMIC. Something along those lines
northmiler89 is offline   Reply With Quote
Old 01-22-2009, 09:49 PM   #10
EFI Logics
Vendor
Member#: 193180
Joe's car is nice..
EFI Logics is offline   Reply With Quote
Old 01-23-2009, 01:54 AM   #11
ChuiSTi
Member#: 61212
2005 STi
CGM
ChuiSTi is offline   Reply With Quote
Old 01-23-2009, 10:22 AM   #12
crand002
Member#: 129765
2006 EVO
439whp/412wtq (MD)
^What are your mods? Those are good numbers for the Harman dyno.
crand002 is offline   Reply With Quote
Old 01-23-2009, 11:16 AM   #13
Mooneyes13
Member#: 113666
60' all over you
werd I am interested in seeing results with the 2.5 vs td06 20g 8cm, fpgreen
Mooneyes13 is offline   Reply With Quote
Old 01-23-2009, 12:02 PM   #14
IMPORTIMAGE
NASIOC Storefront Vendor
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
yeah ronin on iwsti...great #'s
IMPORTIMAGE is online now   Reply With Quote
Old 01-23-2009, 05:25 PM   #15
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
Originally Posted by EFI Logics View Post
This car is rice and sexy at the same time! I am so because I like it. What body kit is on that thing?
Stames_wiltz is offline   Reply With Quote
Old 01-23-2009, 05:33 PM   #16
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
Those tails are quite unique, I like them
Str8Gone is offline   Reply With Quote
Old 01-26-2009, 04:38 PM   #17
ChuiSTi
Member#: 61212
2005 STi
CGM
My mods relevant to power are:
PE 850cc injectors
APS TMIC
Cobb Legacy Intake (67 or 68 mm bigmaf) with cold air box
Perrin After MAF hose, perrin turbo inlet
Prodrive BCS
Helix Catted DP
Borla Hush with 3" Adapter
oh yea and 2.5" inlet Blouch 2.5r polka pickle 8cm2
Solid line is on CA 91pump
Dotted line is 3 gallons CA91 pump with 5 gallons 100oct mixed in
Old 02-07-2009, 01:07 PM   #18
surfer5567
Member#: 61199
2002 wrx wagon
on a mustang dyno just got my polka pickle tuned. ended up with 289hp and 302tq. turbo ends up not being able to hold boost up top for some reason. its 21psi tapering down to 17psi. dont know if thatis right or not?????
Old 02-07-2009, 03:49 PM   #19
jpwrxtr06
Member#: 187052
2006 Wrxtr 6-spd
Thumbs up
What are your mods? Maybe it doesn't hold boost as well cause of the 2.0 but those are still good numbers. What's the spool like?
Old 02-07-2009, 04:07 PM   #20
zeropsi
Member#: 175453
AE86 GT-S coupe
i <3 alqonquin homosauce
If anything it'd hold boost better on a 2.0
zeropsi is offline   Reply With Quote
Old 02-07-2009, 04:38 PM   #21
DuCash
Member#: 198714
04' JDM STi EJ207
437whp/357wtrq Dom3 24psi
Why?
DuCash is offline   Reply With Quote
Old 02-07-2009, 05:21 PM   #22
jutes85
Member#: 127232
E92 M3
98' Foz
I'll post results once I get around to installing all these parts.
DOM2.5R
Tomei Expreme UEL Header /w Custom 44mm Tial EWG
DW 740cc Injectors
APS 70mm Intake
Prodrive EBCS
NGK One step colder plugs.
Already have the Walbro and aps tmic installed. I don't care about numbers, just a smooth, linear powerband.
Old 02-08-2009, 02:47 AM   #23
zeropsi
Member#: 175453
AE86 GT-S coupe
Originally Posted by DuCash View Post
Why?
Because it's a smaller motor....
Old 02-08-2009, 03:04 AM   #24
androofoo
Member#: 130312
2007 Legacy GT
on a mustang dyno?
androofoo is offline   Reply With Quote
Old 02-08-2009, 03:28 AM   #25
bettyblue
Member#: 90920
2005 2.0FPGREEN 6SPD
2002 bugeye Vf39
werd my 2.0 holds boost nasty up high, but im externally gated
bettyblue is offline   Reply With Quote
17 or 18 on my wrx what are you running drkelly Tire & Wheel 10 11-18-2011 12:00 AM
Auto-x Suspension set-up? What are you running? joshmeduri Brakes, Steering & Suspension 2 01-07-2004 05:58 PM
Plugs for RS-T? What are you running? jeff22 Normally Aspirated with bolt-on Forced Induction Powertrain 1 06-10-2003 02:18 AM
Turbo Poll: What Are You Running? MagicMT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-06-2001 12:12 AM
