Old 11-15-2008, 01:13 AM   #1
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
Default anyone ever used passat steelies on there subaru?
I found a set of cheap 16inch passat steelies that are 5x100.
I was curious if anyone has tried fitting these on there car? my friend might need a set of steelies for winter
scobaru is offline   Reply With Quote
Old 11-15-2008, 01:33 AM   #2
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
actually, my brother is currently running VW steelies. Not sure if they're from a passat, but they seem to fit without problems.
sniper1rfa is offline   Reply With Quote
Old 11-15-2008, 04:07 AM   #3
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
that's exactly what I wanna hear! thanks
Old 11-15-2008, 02:01 PM   #4
Back Road Runner
Member#: 60082
2004 Forester STI
As long as the offset near correct. You use relatively narrow tires in the winter, so you do gain a lot of wiggle room between the fender and strut body. This does give you a bit more freedom with wheel choice. It's still preferable to be correct with the offset as it can introduce bumpsteer when not centered to the turning axis.
Old 11-15-2008, 05:50 PM   #5
gf2020
Member#: 77047
2010 Toyota Tundra
Most VW wheels are 5 X 100, with an offset of 35, so they are reasonably close.
gf2020 is offline   Reply With Quote
so has anyone ever used that engine restore stuff on a subaru? Big_Hitter Texas Impreza Club Forum -- TXIC 25 07-26-2014 07:27 PM
Anyone ever used a GPS on an airplane? plunk10 Off-Topic 92 10-05-2008 06:59 PM
Anyone have a boost controller on there subaru? kick_boxur Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-01-2008 07:30 AM
Has anyone ever put HRE wheels on their subaru??? wrxturbo17 Tire & Wheel 7 03-04-2004 12:22 AM
Anyone ever put Whipped Cream on there Sicilian Pizza? Not too bad. Pictures Inside STEALTH-WRX Off-Topic 23 12-05-2003 10:38 AM
