Old 11-15-2008, 03:12 PM   #1
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Cool Ej22t vs ej22 n/a pistons
So i have an ej22t that broke some ring lands so i pulled the pistons out and i have a ej22 n/a block siting around i was wondering if the pistons are the same like interchangeable?? like i know they will fit because there both ej 2.2L engines however are they the same pistons or not?
91turbosedaan is offline   Reply With Quote
Old 11-15-2008, 03:20 PM   #2
Arctic Assassian
Member#: 91875
91 legacy TD04
04 WRB/carbon fibre STI
Not the same. The 2.2 N/A had higher compression. Stock is 8:1 I think that will bump you to somewhere around 9:1
Arctic Assassian is offline   Reply With Quote
Old 11-15-2008, 08:40 PM   #3
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Not the same but a good option if you are switching to DOHC heads...
Old 11-16-2008, 03:32 AM   #4
91turbosedaan
Member#: 135144
1991 legacy turbo
white
Unhappy
Ok so it looks like ill drop in some n/a pistons than and get that 9:1 compression however i am planning on installing a wrx turbo and inter cooler onto this engine as well and Im going to be using the ej22t heads with it will i have any problems with this higher compression ratio?
Also now that i have the block down this far and it has over 200k origenal miles on it and it ran out of oil for apx 5 seconds w/ 2 busted ringlands im thinking of spliting the block and inspecting components and replacing all the bearings main and rod bearings so im wondering is there a tork spec for mainand rod bearings and should i use plastic gauge or is there a special way of installing new bearings? or can i just replace them and trok them down or what thank you.
Old 11-25-2008, 02:16 AM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
IIRC, the EJ22T heads have the same comb. chamber volume as the N/A heads.
So if you throw in N/A EJ22 pistons into an EJ22T block, you get the stock 9.7:1 compression ratio. Stock EJ22T piston dish is 28cc's, 12cc's for the N/A pistons.
Once you look at the condition of the block, and see the damage, you will be able to make an informed descision on what to do next. You have to torque the block down a certain way. It isnt hard, basically start in the middle, and work your way out. I have the specs in my chiltons manual. But of course, I dont have it within 20 miles of me.
~Josh~
Old 11-27-2008, 10:33 AM   #6
iluvdrt
Member#: 46248
82 Brat
Tan
New EJ22T pistons can be bought for around $400 from Weisco and they are forged. Being that you are going to be running boost, I wouldnt cheap out or you will be doing this build again in the future. Just get the forged pistopns and be done with it. Do it right the first time, or youll be doing it again later IMO.
iluvdrt is offline   Reply With Quote
Old 12-13-2008, 01:26 PM   #7
GeneralTJI
Member#: 152680
Has anyone seen EJ22 forged pistons (high compression)?? those paired with an EJ22T block / 205 WRX heads would keep the compression up a little higher- be just about right for E85 Some good rods etc.... hmmm....
GeneralTJI is offline   Reply With Quote
Old 12-13-2008, 06:15 PM   #8
Matt Monson
Member#: 832
99 2.5RS, '85 911
Ron at Raw Performance (formerly of Axis Power) has built a bunch of Ej22T bottom ends with custome pistons mated to Ej205 heads. Because core Ej22T's aren't readily available anymore he doesn't list Ej22 parts on his website, but if you contact him, I am sure he can still get the pistons. IIRC, they were made by Wiseco and you may also be able to order them directly from them...
Old 12-15-2008, 07:06 AM   #9
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
I'm sure that Ron can offer you a set of custom made CP pistons for this application.
Marnix is offline   Reply With Quote
Old 12-26-2008, 04:38 PM   #10
gtiglock
Member#: 197987
2002 wrx
white
Default question
i have the same question 2002 wrx 2.0 t heads onto a 2.2 n/a block what is the compression ratio? with what head gasket and what other mods are need?
gtiglock is offline   Reply With Quote
Old 02-22-2009, 07:54 AM   #11
gtiglock
Member#: 197987
2002 wrx
white
Old 02-22-2009, 10:30 AM   #12
Matt Monson
Member#: 832
99 2.5RS, '85 911
It makes me chuckle when someone is trying to put together a custom engine configuration and they aren't able to do the most basic engine builder's math of computing a compression ratio.
Old 02-24-2009, 02:39 PM   #13
gtiglock
Member#: 197987
2002 wrx
white
Thanks for the help Mat. Good info I will try that
Old 03-11-2009, 09:39 AM   #14
leftho0k
Member#: 177589
yeah if you cant figure out the basics just go buy an automatic wrx and quit asking unintelligent questions.
leftho0k is offline   Reply With Quote
Old 03-11-2009, 09:42 AM   #15
leftho0k
Member#: 177589
and anyway there is a "compression calc." thing someone made and posted on here.
you have quit wanting things to be handed to you and look to find the answer yerself!
Old 04-05-2013, 03:13 PM   #16
harringtonj88
Member#: 345177
I have noticed that there are a lot of pricks on this site. Just because you have a lot of experience doesn't give you the right to be a jerk. People want to learn about subarus and its people like the ones on this site that give subaru owners a bad name. People come here for answers. Not to get made fun of. Thanks for being a prick leftho0k. Much appreciated!
harringtonj88 is offline   Reply With Quote
Old 04-05-2013, 04:21 PM   #17
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Cool story bro. I've just dumped 20H heads on an n/a 22E. I didn't go crying for help. I researched the **** out of it.
i_c_the_light is offline   Reply With Quote
Old 05-01-2013, 12:34 AM   #18
digemz
Member#: 284404
i am about to purchase a 93 legacy ss and i learned alot from this thread.. this is exactly why i peruse the forums.. to make informed decisions
digemz is offline   Reply With Quote
FS N. VA: Wiseco EJ22T/EJ22E Forged Stroker Piston Kit soobaviator Engine/Power/Exhaust 2 05-17-2010 02:05 AM
EJ22T vs. EJ20 Block, Piston Compatability with EJ20X Blocks, and Max Stock Power Audioexcels Built Motor Discussion 12 12-16-2009 10:52 AM
WTB WISECO EJ22/25 hybrid pistons and EJ25 STI rods(5.181") col5555 Private 'Wanted' Classifieds 1 12-31-2008 08:35 AM
Subaru EJ22 block, forged pistons, 2.2L, closed deck! Needs work. Si2WRX Private 'For Sale' Classifieds 6 11-24-2004 12:39 PM
EJ22T vs EJ22 intake manifold ChicksDigWagons Normally Aspirated with bolt-on Forced Induction Powertrain 4 11-09-2002 06:50 AM
