Old 11-15-2008, 06:25 PM   #1
wrx_gon
Member#: 166233
'12 Legacy 2.5i
Default 255/40/18s on my wagon
I currently run 225s on my 04 wagon on an 8" rim and they fit fine. Can I run 255s on that rim or will my tire rub? Thanks.
wrx_gon is offline   Reply With Quote
Old 11-15-2008, 08:53 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
i dont think so, no
Old 11-16-2008, 12:35 AM   #3
UFOpilot
Member#: 189525
2007 WRX Wagon
Invisible Plain
I believe it to be not very useful to stuff tires onto rims that do not allow the tire to perform at it's optimum level. 255 should be on 9" or wider. You could however mount them on the 8 and I am sure someone will pipe in who has. However, if you get 255's under a wagon without taking an english wheel to the fenders I would be surprised. The wheel bearings would suffer immensely. Not to mention each brand and style has different widths for 255; Toyo r888 245= some street tires 235. To require 255's to shoulder the burden you must be putting out some insane numbers for torque. There is a thread dedicated to wide stock on wagons and the setups that are working, check it out.
UFOpilot is offline   Reply With Quote
Old 11-16-2008, 12:43 AM   #4
wrx_gon
Member#: 166233
'12 Legacy 2.5i
Thank you for the answers. Ill just stick with my 225s
Old 11-16-2008, 05:16 AM   #5
rice h8r
Member#: 94524
Check out tire specs on tirerack, they show the recommended tire sizes for each side.
255/40/18s should fit on an 8" because of the tall sidewall, but you'll most likely rub since it's much taller than the stock size tire.
rice h8r is offline   Reply With Quote
Old 11-16-2008, 05:23 AM   #6
hella_sti
Member#: 139289
2003 WRX Wagon
i got 235/40/18 on my 8 ich prodrives and it pretty snug maybe 245's but not 255/40 they are too tall try 255/35/18
edit:here is a wagon with 255's
http://forums.nasioc.com/forums/show....php?t=1639316
hella_sti is offline   Reply With Quote
255/35/18s on a 18x9.5 wheel? Damon Tire & Wheel 8 12-28-2009 11:48 AM
Test fit request: 5x114.3 - 255/40-17 on 17x8.5 +48 or 255/35-18 on 18x8.5 +48 mav1c Mid Atlantic Impreza Club -- MAIC 10 10-20-2007 12:46 PM
Falken Azenis 245/40/18s on a 18X8 Wheel?! GoRacerXGo Tire & Wheel 5 04-22-2006 01:29 PM
Holy cow!! 265/40/18s on a WRX??? Conduit Brakes, Steering & Suspension 9 01-08-2002 12:00 AM
225/40-18s on Snow Neil Wallerstein Brakes, Steering & Suspension 10 04-10-2001 09:33 PM
