Old 11-16-2008, 01:48 AM   #1
airgne
Member#: 178235
01 Legacy Gt Ltd.
Titanium Pearl
Default P0341
ok tonight wa on an airport runway racing. we got to the end of the runway and the car died. the code pulled was P0341. it say's the cam angle sensor he car will not start. i reset the ecu, did not work.
01 legacy
2.5 SOHC
116,000Miles+
i resenly had the timing belt changed. should i replace the CAS? should i take off the cover and see if the timing belt sliped? any help would be helpful.
airgne is offline   Reply With Quote
Old 11-16-2008, 10:40 AM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
you can pull it to see if it's really dirty. check the wiring to it. these sensors do fail, albeit not too often. and yes, your car won't start if the crank or cam sensor isn't working.
it might be worth it to check the timing belt just for your peace of mind.
Old 11-16-2008, 02:36 PM   #3
airgne
Member#: 178235
01 Legacy Gt Ltd.
Titanium Pearl
thanx
Old 11-17-2008, 02:08 PM   #4
airgne
Member#: 178235
01 Legacy Gt Ltd.
Titanium Pearl
its the leftside head gasket
P0341 - camshaft position sensor trouble HELP! Danny Boy Service & Maintenance 13 07-21-2013 06:38 PM
Help! Mysterious P0341, Heavy Hesitation Rallycarperson Normally Aspirated Powertrain 7 04-24-2010 06:20 PM
P0341 CEL, help! Cstmboxermotorsports Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-02-2009 07:50 PM
P0341 rebuild - reinstall cel issue. Running very rough 99 forester. samcoinc Normally Aspirated Powertrain 14 04-24-2008 02:36 PM
Random stalling. Code P0341 subix Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-27-2002 07:55 AM
