Old 11-16-2008, 04:27 PM   #1
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
Default Ring and Pinion swap directions.
Shops and experienced people please chime in. The process of installing a rear diff I'm understanding is Remove back cover Remove remaining side bolts Mark lash and backlash Press out pinion Press off bearing and shim Press on bearing and shim on new pinion Press in pinion Adjust lash backlash and shim Re assemble Chime in if you can elaborate on those steps or I'm missing something.
smileyou is offline   Reply With Quote
Old 11-16-2008, 07:42 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The best answer is that you DON'T SWAP THE RING AND PINION. Keep them with the matched case and just swap the carrier. 99% of the time you don't even need to adjust the backlash or seals!
http://forums.nasioc.com/forums/show....php?t=1628135
Old 11-16-2008, 09:19 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
^^^I've done it both ways and putting the carrier into the case with the ratio you want is (by far) the easiest way to go.
If you don't have that donor case to put the chunk into, then you have no choice but to swap out the pinion. If that is the situation, there are good instructions in most every edition of the FSM.
Jay Storm
Old 11-17-2008, 02:22 AM   #4
smileyou
Member#: 152045
2003 PIA wrx
What's thr FSM? The service manual or wah?
Old 11-17-2008, 02:30 AM   #5
semaj
I'm sorry for apologizing
Moderatour
Member#: 113533
2006 Pathfinder
Off Road
FSM = Factory Service Manual
semaj is offline   Reply With Quote
Old 11-17-2008, 05:08 AM   #6
smileyou
Member#: 152045
2003 PIA wrx
Where would I aquire the fsm
Old 11-17-2008, 07:20 AM   #7
Storm
Member#: 5218
96L Most Over-
Developed Beater
You can pay for a temporary "subscription" to techdocs.subaru.com, or ask nicely for another member here to forward it to you.
PM me with a good email address and I will send you the required reading. I don't have any of the special tools for setting pinion depth....you'll be on your own with that part.
When I did mine, it took me a long time in assembling, checking, disassembling, adjusting shims, etc.....to get the pinion depth right, close to 6 complete tries anyway(I hate math). Once that was good, the rest was easy.
Jay Storm
Old 11-17-2008, 11:43 AM   #8
smileyou
Member#: 152045
2003 PIA wrx
thanks storm i appreciate it
Old 11-17-2008, 01:25 PM   #9
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
Hey, don't bother with that site, it is a ripoff.
Go to Ebay, and get a FSM on disk for your year of car.
aboothman is offline   Reply With Quote
Ring and Pinion Swap spoolinsuby Transmission (AT/MT) & Driveline 19 06-05-2005 11:55 PM
Rear diff ring and pinion swap... Does it matter if its locking or not? FederalAuditor Transmission (AT/MT) & Driveline 1 02-09-2005 04:09 PM
ring and pinion swap for 92' legacy Turbo swiggy Subaru Conversions 3 02-07-2005 09:20 PM
Ring and pinion swap ebeck Transmission (AT/MT) & Driveline 1 04-12-2004 09:46 PM
Ring and Pinion swap - Do it yourself? fragment Transmission (AT/MT) & Driveline 4 03-22-2004 06:19 AM
