Old 11-16-2008, 11:04 PM   #1
irish44j
Member#: 191290
09 OPB SM WRXsedan
85 BMW E30 M2 Rallycrossr
Default harness - child seat anchors, or eyebolts into seat belt mounts.
Just looking for some input. In other cars I've bolted eyebolts into the rear seatbelt mount positions, but the WRX has the "latch" system for child seats, with the bars down below the seat (and also on the rear deck). Are the latch mounts strong enough for autocross harness use, or should I just stick with eyebolts in the seatbelt mounts?
irish44j is offline   Reply With Quote
Old 11-17-2008, 04:53 AM   #2
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
I know there's a harness bar that mounts to the tether mounting points, but I can't think of who makes it.
Counterfit is offline   Reply With Quote
Old 11-17-2008, 01:22 PM   #3
deebee8
Member#: 85437
2002 Wrx
Land of the dead
why not get a harness bar?
deebee8 is offline   Reply With Quote
Old 11-17-2008, 01:45 PM   #4
misterwaterfallin
Member#: 101091
If your talking about mounting the shoulder straps, neither. Unless you get a scroth quick fit kit, it's not safe to mount them that far low. If you dont have a cage, or a harness bar if your just using it for auto-x, dont get harnesses
misterwaterfallin is online now   Reply With Quote
Old 11-17-2008, 02:13 PM   #5
fengrr
Member#: 169160
03 WRX
Black on WRB
Use schroth quick fits.
fengrr is offline   Reply With Quote
Old 11-17-2008, 03:14 PM   #6
leecea
Member#: 37359
2003 WRX
I found this info on LATCH...
There is growing interest in using the top tether and lower anchors for children in harnessed forward-facing carseats that have weight limits above 40 pounds. The government safety standards do have a safety margin above that, and were based on a combined child and carseat weight of 65 pounds. It is possible that some automakers added a safety margin above that. Even so, it is best to check with your vehicle's manufacturer and carseat manufacturer if this is an issue, especially if your child exceeds 48 pounds. Unfortunately, some companies may not have this information readily available for consumers.
However, it is not easy to use this info. If LATCH is rated for 65lbs at some impact speed, how does that match against the force exerted by your upper body weight at autox speeds?
FYI, I have my 4-pt mounted to the C-pillar seatbelt mount.
leecea is offline   Reply With Quote
Old 11-17-2008, 06:21 PM   #7
irish44j
Member#: 191290
09 OPB SM WRXsedan
I was under the impression that harness bars are not legal for DS. Forgive me, I've been driving in EP for years, which is more or less anything goes...so I haven't had to pay much attention to the rules details
thanks, that's the informtion I was looking for.
In a technical sense of course I would agree (I've been autocrossing/using harnesses for about 15 years), but I would disagree about the usage. For speed work, no I would definitely never mount that low due to issues of spinal compression in a high-speed collision. For autocross, though, that is "generally" not a concern to me...in autocross the harness is less for safety and more for holding the driving in place. I'm sure we could debate this point forever, but why bother, really...we both know how harnesses are "supposed" to be used correctly.
But again, I'm not asking about which harness mount area is safe, etc....I was just interested in the load ratings of the LATCH tabs....
Old 11-17-2008, 09:04 PM   #8
leecea
Member#: 37359
2003 WRX
FYI, harness bar is OK for DS as long as it doesn't serve any other purpose (like bracing).
I think you've already covered all the reason's why it is not really needed for autox.
Old 11-18-2008, 12:07 AM   #9
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
Yes, most "sliding type" bars are Stock class legal.
bcblues is offline   Reply With Quote
WTB: 02 Wrx front seats only or Rs gray seats JayRObrero Private 'Wanted' Classifieds 1 06-10-2009 12:30 PM
wtb: seat belt anchor bolt, goes into bottom of B pillar fastwrx25 Private 'Wanted' Classifieds 0 03-12-2007 07:29 AM
Child seat anchor thread - 97 Outback iauchinl Outback Forum 1 07-07-2006 03:27 AM
Swap entire WRX harness or splice into 95L harness? Aspen_2.5RS Subaru Conversions 42 11-10-2003 11:08 AM
