Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 11-16-2008, 11:26 PM   #1
Member#: 134657
Default how to check timing?
I have a 93 Impreza and I want to check the timing on the car. I have never done this before on any car. Where do I start How would I go about it on this particular car?
omeskcus is offline   Reply With Quote
Old 11-17-2008, 06:57 AM   #2
Member#: 5218
96L Most Over-
Developed Beater
The ignition timing is controlled by the ECU. You can check it by putting a timing light on it, as in any other car....there are graduated tickmarks on the timing cover near the crank pulley. It may be hard to see the timing mark on the crank pulley, so you'll probably have to make one for #1 TDC. It will vary as the ECU does it's thing at idle.
If you are talking about static timing of the motor, you'll have to pull the timing covers off and put the crank timing gear on it's timing hashmark (not the arrow). The cams pulleys should line up with corresponding notches in the cover(s) and/or parting line on the left (as looking at it) head. If neither cam lines up, bring it around one more revolution to get to the compression stroke for #1. They should all line up then.
It would help to know what motor you're working with.
how to check if timing belt has skipped Serkan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-24-2010 08:54 PM
How to check timing? lagodcm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 12-28-2008 04:23 PM
How to check for broken timing belt ? Legacy Normally Aspirated Powertrain 4 07-10-2006 10:20 PM
How to check timing on 94 L ai42 Newbies & FAQs 0 10-01-2005 08:41 PM
How to check timing with the light gun on a coil on pack wrx? bigbird Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-01-2004 07:00 PM
