Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 11-17-2008, 12:49 AM   #1
DubyaSTi
Member#: 86763
2009 STI
Satin White Pearl
Default Tire Pressure Light Flashing
On Friday I noticed that the TPM system light was on our 06, obviously indicating low pressure in one or several of the tires. I topped off each tire to an agreeable pressure and went about my merry way. About 15 minutes into my trip to upstate NY the TPM light started to flash. I checked the manual and it says the light will flash if the TPM isn't working correctly.
Any one have any experience with this? All I did was fill up the tires with air...nothing crazy. Any ideas? Car is out of warranty BTW.
DubyaSTi is offline   Reply With Quote
Old 11-17-2008, 04:36 AM   #2
HB_Dad
Member#: 45190
2014 Impreza Sport L
Not to doubt your abilities, but are you sure the tire just doesn't have a leak? If you are past the 60,000 mile warranty and are still on the original tires, they surely are in need of replacement.
HB_Dad is offline   Reply With Quote
Old 11-17-2008, 10:18 AM   #3
wizzle-stick
Member#: 160534
2002 impreza rs
it is possible that the sensor has an issue but the only way to check it is to take the tire off the rim
secondly did you use the air pressure thing at the air pump or your own
i have a gas station near me that will say the air is at 35 and ill check it with my gauge and its really at 25
wizzle-stick is offline   Reply With Quote
Old 11-17-2008, 10:53 AM   #4
Foxbat
Member#: 654
2003 WRX, Silver
'08 Tribeca, Brown
And the TPMS will also on if your tire pressure is too high! I'd check the tire pressure when tires are cold the compare to what the manual or the stick on the door post says. If it is within spec, you may need to get it fixed. I've read that these sensors in the tire can go bad.
Foxbat is offline   Reply With Quote
Tire Pressure Light RideHolden Tire & Wheel 3 07-27-2009 12:35 PM
08 Spec.b Tire pressure light after putting after maket wheels Taras Tire & Wheel 15 08-14-2008 02:11 PM
Tire pressure light in 2008 WRX Troa Service & Maintenance 9 07-06-2008 07:56 PM
new rims and tire pressure light on ornge04gt Newbies & FAQs 12 04-06-2008 11:33 PM
low tire pressure light wont go off Shootist Tribeca Forum 4 09-10-2006 07:12 PM
