Old 11-17-2008, 01:29 PM   #1
18aspenSTi
Member#: 139419
2005 STi
AW
Default radiator core keeps sepatating from endtank
I replaced my radiator last week due to a leak because the core and endtank were coming apart. Now the new radiator has the same problem, the crimps from the core are coming apart from the endtank. The company is saying that my cooling system could have too much pressure. The radiator cap is stock, anyone know what could be causing this repeated failure?
18aspenSTi is offline   Reply With Quote
Old 11-17-2008, 02:56 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
bad headgaskets can do this
Old 11-17-2008, 05:51 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Have you ever tried to use the stop leak stuff you pore into the coolant?
Old 11-17-2008, 08:04 PM   #4
rkramer
Member#: 118209
2015 WRX Limitec
check the obvious, pressure test the radiator cap!
Old 11-18-2008, 11:22 PM   #5
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
next time get a full aluminum rad replacement. plastic endtanks suck.
fastnoypi is online now   Reply With Quote
Old 11-18-2008, 11:55 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
and just ignore the problem that is CAUSING this???
great
just great
Old 11-19-2008, 01:19 AM   #7
EPskate
Member#: 84800
02 wrx rip / 05
sti
I wouldn't use the leak stop stuff, but you need to get this checked out.
What radiator are you using that this is happening to?
EPskate is offline   Reply With Quote
Old 11-19-2008, 01:44 AM   #8
plode
Member#: 116910
stop leak is meant to what? CLOG UP LEAKS...which also means it'll gum up the coolant passages on the engine. I'll never use it. Ever.
I'd go with bad head gaskets, and pressure from the cylinder(s) is leaking into the cooling system, pressurizing the system to much more than it was intended for.
plode is offline   Reply With Quote
Old 11-19-2008, 02:05 AM   #9
rick-l
Member#: 33868
2003 wrx
srp
Isn't that what this Subaru Coolant Conditioner is?
rick-l is offline   Reply With Quote
Old 11-19-2008, 02:43 AM   #10
plode
Member#: 116910
Essentially, yes. From what I've read, Subaru originally made it to seal up head gaskets that are leaking.
This persons problem seems very excessive(takes a good amount of pressure to blow an end tank off)
Fix the problem right, the first time, if the head gaskets are leaking, replace them, don't put a bandaid on it....
Old 11-19-2008, 11:19 AM   #11
rick-l
Member#: 33868
2003 wrx
srp
Essentially, yes.
Since Subaru recommends you add this when you change coolant never ever is a point in the not too distant future then?
Old 11-19-2008, 12:31 PM   #12
plode
Member#: 116910
Yes, they recently just started recommending it for the turbo cars from what I've read.
I myself, will never use it. I'd rather not gunk up, clog up the engine. I've seen the inside of a 350 Chevy engine that had stop leak in it, and the coolant passages all had crap(goo) in all of them. there is no replacement for good coolant and distilled water. If you're having problems, and the head gaskets are the source, replace them. My friend recently had this same problem on his 2002 wrx. His heads were warped. He said he never even overheated the car, he saw the temp gauge above what it should be and immediately shut the car off. Mechanic tore into it, replaced the rad, blew apart again, and it was the heads.
Old 12-01-2008, 07:35 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
The subaru conditioner is not "stop leak"
Stop leak has large particles to clog up leaks, the conditioner consists of only liquid.
BTW the overflow tank/radiator cap is another leak that "stop leak" stops!
WTB: 2000 2.5rs front bumper, radiator core support, hood, radiator, fenders Cyclops NWIC Private Classifieds 11 02-14-2009 05:08 PM
my radiator core sprung a leak kingsoup85 North West Impreza Club Forum -- NWIC 0 05-23-2007 11:12 PM
looking for radiator core support PowderMan420 North West Impreza Club Forum -- NWIC 5 07-07-2005 03:18 PM
Radiator Core supplier that will export to UK? David_Wallis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-29-2004 07:08 PM
where to get a aluminum radiator core. enough to cool my air to water intercooler STEALTH-WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 06-07-2003 10:14 AM
