Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 11-17-2008, 05:10 PM   #1
rhino6303
Member#: 181314
2005 Impreza OBS SRR
05 Legacy GT RBP
Default 4EAT Filter
Well, it's time to drain/refill my tranny fluid. I noticed that I may have some leakage around the spin-on filter.
1. I was wondering if I have to use a Subaru filter or can I use a WIX filter; i.e. are they any different?
2. Which should I use, the subaru tranny filter, or will an alternate filter work just as well?
I have searched for an answer, but just found answers on drain/refill practices and changing the filter, none on type.
Thanks in advance for any help.
rhino6303 is offline   Reply With Quote
Old 11-17-2008, 06:27 PM   #2
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
The differences are equivalent to the differences between the OEM engine oil filter and aftermarket engine oil filters. IOW, the differences could be all over the map, but you're very, very unlikely to notice unless you're running analysis and trying to watch the differences. Possibly not even then, depending upon what filter you choose.
If you choose to entertain another alternative, the Amsoil EaO12 has served me well this past year-ish. Same filter as the engine on my Baja. I still have a used OEM tranny filter sitting on a shelf. I told myself that one day I'd cut it open and have a look at the insides. That day has not come, and it probably never will.
bulwnkl is offline   Reply With Quote
Old 11-17-2008, 06:53 PM   #3
mikeythejew
Member#: 141672
Unlike some other filter manufactures, Purolator's transmission filter # P1285 is made only for use as an auto tranny filter, and specifically on Subaru's and saabaru's vehicles. A correct auto tranny filter will not have a pressure relief valve as it's not needed.
OEM or Purolator if I owned a slushbox.
mikeythejew is offline   Reply With Quote
Old 11-17-2008, 07:08 PM   #4
rhino6303
Member#: 181314
05 Legacy GT RBP
thank you for the information, looks like I'll go with the purolator.
4EAT filter change interval GLwagon Transmission (AT/MT) & Driveline 2 01-23-2013 10:53 PM
4EAT Filter Hayes Newbies & FAQs 2 12-27-2005 07:41 PM
4eat Filter Hayes Transmission (AT/MT) & Driveline 0 08-05-2004 01:15 PM
4EAT filter...? fastenova Legacy Forum 8 07-10-2004 07:37 AM
4eat filter?? bratmantlz Transmission (AT/MT) & Driveline 27 11-01-2001 09:22 PM
