![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 190454
NESIC
Vehicle:2005 wrx stage II white like my bitch |
#2 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
it's going to depend on what wheel (i.e. how thick the wheel flange is)
on my stock 02 wheels 5mm was certainly NOT ok with stock studs |
#3 |
Member#: 190454
NESIC
yea ive got 05 wheels and i just upgraded brakes my other rims are getting powdercoated .. and i was hoping i could run the stock wheels untill they get back from the shop i guess i failed
#4 |
Member#: 21808
E. Canada
generally you want at least one diameter's worth of thread engagement i.e. for M12x1.25 you need 12/1.25 = 10 turns min
looked at the other way you are losing 3/1.25 ~ 2-1/2 turns or 5/1.25 ~ 4 turns with the spacers |
#5 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
yes
#6 |
Member#: 151360
Vehicle:2007 STI RIP 2013 EvoX/2010 GTR |
There is a "certain amount" of thread/turns that the lug nut is supposed to grab onto in order to keep the wheels on. Putting in spacers decreases the total amount of thread/turns that the lug nut is able to grab and you will run the risk of the lugs coming loose when driving.
#7 |
Member#: 151360
Uncle Scotty: "Buying the right wheels isnt a band aid used to patch poor decesion making."
#8 |
Member#: 171448
RMIC
Vehicle:2003 wrx psm |
i have a 03 with 06 07 wrx wheels. i also have brembos with 10 mm spacers in front and 5 in back. oh yeah i have extended studs in the front haha. but i run 5 on stock studs. done many track days with them. never had a problem.
#9 |
Member#: 65623
SCIC
Vehicle:2005 Impreza WRX CGM 95 Black Miata |
5mm is most i would run with oem stud
anything bigger than 5mm i would suggest using extended stud |
#10 |
Member#: 17315
International
Vehicle:MY95 Impreza 207C MY05 Forester 257X |
Good spacer kits will come with extended studs. I've been using the H&R units for my track wheels/R-comps.
| Thread Tools | |
| Display Modes | |
| SE37K wont fit with ichiban V2 15mm spacer, ok to cut stock studs down 3-4mm? | bstoehr83 | Tire & Wheel | 17 | 01-02-2010 12:46 AM |
| not another is it ok to run a 10mm spacer thread | 05ASPINREX | Tire & Wheel | 11 | 04-15-2009 12:35 PM |
| wheel spacer ok to use? | unethikl | Tire & Wheel | 6 | 07-21-2007 08:14 PM |
| Are 5mm spacers enough to clear this wheel size | wrx-sleeper | Tire & Wheel | 4 | 02-01-2007 10:44 AM |
| Is it ok to run without fender liners at the track? Also, how to remove them? | ewright | Motorsports | 9 | 10-29-2005 10:36 PM |
