Old 11-17-2008, 06:03 PM   #1
kidjnco23
Member#: 147862
2005 wrx sti
aspen white
Unhappy Check engine code!!!
I just got the code p0420 on my bone stock sti does any one know wat it is??
kidjnco23 is offline   Reply With Quote
Old 11-17-2008, 06:22 PM   #2
GDArex003
Member#: 122924
2011 sti
spark silver
P0420 Catalyst system efficiency below threshold
hope it helps
GDArex003 is offline   Reply With Quote
Old 11-17-2008, 06:28 PM   #3
kidjnco23
Member#: 147862
2005 wrx sti
aspen white
does that mean my cat is no good or its my o2 sensor??
Old 11-17-2008, 06:57 PM   #4
06WRXturbo
Member#: 157987
2006 TR Sedan
black
it means the cat is bad. how many miles? you should have an 8yr/80K mile on ur cats. if ur at 80K+ just upgrade to an aftermarket downpipe. OEM cats are generally $800-$1200 or even more sometimes.
06WRXturbo is offline   Reply With Quote
Old 11-17-2008, 07:02 PM   #5
rkramer
Member#: 118209
2015 WRX Limitec
if that cat is bad it is under warranty yet. To the OP, take it to the dealer, Emissions equipment is covered outside of the normal powertrain warranty.
Old 11-17-2008, 07:05 PM   #6
kidjnco23
Member#: 147862
2005 wrx sti
aspen white
well there no way to find out if it is the cat before i bring it in rite??
Old 11-17-2008, 07:23 PM   #7
kidjnco23
Member#: 147862
2005 wrx sti
aspen white
and yea i have like 50, 000 miles but are u sure about this warranty
Old 11-17-2008, 07:39 PM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yes
the dealer will likely reset the code and see if it comes back....if it comes back then the cat will be replaced
Old 11-17-2008, 07:42 PM   #9
kidjnco23
Member#: 147862
2005 wrx sti
aspen white
sounds good to me thanks for the info...
Old 11-18-2008, 10:04 PM   #10
hogwild
Member#: 189010
Default 08 same code?
I have an 08 sti stage 2 about 1500 miles and this code popped up and it stopped my traction control from working, stopped my cruise control from working and it flashed on and off, and stopped my S I S# button from working???? The AP cleared the code, but what the ------??
hogwild is offline   Reply With Quote
Old 11-18-2008, 10:52 PM   #11
06WRXturbo
Member#: 157987
2006 TR Sedan
black
when your car throws a check engine light it goes into "limp mode." everything you mentioned above is disabled.
Old 11-19-2008, 08:21 AM   #12
SiGuy
Member#: 194735
2007 Civic Si
Taffeta White
Yes, usually the warranty on Emission related parts are 100,000mi. At least in Pa it is.
SiGuy is offline   Reply With Quote
Old 11-19-2008, 01:25 PM   #13
Cocoa Beach Bum
Member#: 17355
Not true, even in PA.
Cocoa Beach Bum is offline   Reply With Quote
Old 11-19-2008, 03:01 PM   #14
SiGuy
Member#: 194735
2007 Civic Si
Taffeta White
Well guess the state would have nothing to do with it. But most manufactures I've delt with will replace them under 100,000. Except for Mercedes, but they can make exceptions.
Old 11-19-2008, 03:44 PM   #15
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
Federal Warranty for Cat Convertors is 8 years OR 80,000 miles whichever occurs first.
California Emission Warranty for Cat Convertors is 8 years or 100,000 miles for the following:
**Up to model year 2008- California, Maine, Massachusetts, Vermont, New York
**2008 model year add the following: Connecticut, Pennsylvania, Rhode Island,
**2009 model year add the following: New Jersey, Washington , Oregon
Minimum warranty is 8/80, unless you are in one of the above states and have that model year vehicle.
RexyGirl is offline   Reply With Quote
check engine codes gpd323 North West Impreza Club Forum -- NWIC 9 10-17-2001 06:17 PM
Help with check engine code Meche 2.5RS Normally Aspirated Powertrain 1 10-10-2001 06:20 PM
Check engine codes Wildman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-21-2001 07:04 PM
Check Engine Code P0302, "#2 Misfire" hillman Legacy Forum 5 06-26-2001 03:14 PM
Check engine codes Kruf General Forum Archive 1 12-17-2000 05:46 AM
