Old 11-17-2008, 06:55 PM   #1
Delsole
Member#: 166144
Default no awd?
Ok guys i have been searching for a while now and still haven't gotten a good answer. i recently bought 1995 subaru legacy lsi. it has about 300k on it but still runs like a top. i noticed on the drive home after i bought it the front wheels seemed to be spin happy. then i soon realized that the tires in the front were 195 60 15 and the ones in the back were 185 65 15. now im about 90% sure that i have no awd right now. Also my check engine is on for the speed sensor im not sure if that because of the tires or not. From what i herd awd subbys need all four matching tires. But either way i have no awd and im thinking maybe its the clutch pack. the rear diff is still together and there is a drive shaft so i dont know what else it could be. If it is the clutch pack does anyone know were i could get one and how hard of a job is it to change. Any answers would be greatly appreciated.
Delsole is offline   Reply With Quote
Old 11-17-2008, 07:26 PM   #2
Back Road Runner
Member#: 60082
2004 Forester STI
185/65/R15 = 195/60/R15
At least within 0.3 inches. You really would prefer them to be equal, and this is above the suggested 1/4" difference limit Subaru suggests, i.e. there will be some binding. You won't specifically damage things driving like this, but it's not good practice and will induce some excess wear on parts over time.
Old 11-17-2008, 09:54 PM   #3
Subyroo2.5
Member#: 168129
2013 WRX
WRBP
What if you have 3 worn tires, and one new tire of the same size, would that mess things up?
Subyroo2.5 is offline   Reply With Quote
Old 11-17-2008, 09:56 PM   #4
codesoccer
Member#: 179573
2002 MBP Bugeye
Flip Flop Tuned on corn
correct me if i'm wrong but didn't subaru only start making all their usdm vehicles awd in 1997?
codesoccer is offline   Reply With Quote
Old 11-17-2008, 10:10 PM   #5
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
Yes. You have to either replace all four tires or find a place to shave the new one down to the others' size
chazly413 is offline   Reply With Quote
Old 11-18-2008, 01:27 AM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Delsole : You really should ask a moderator to move this post into the transmission forum as it has nothing to do with the engine and there would be more experts there to help. Also you forgot to mention what transmission type you have.
You shouldn't have bought the car in its current shape unless it was a very good deal. I will assume you have an automatic based on the trim level and symptoms.The mismatched tires could have damaged the center clutch pack.
1. Put the matched set of tires on one side of the car. Meaning both left tires will be 195 60 15 both right tires are 185 65 15
2. Fix the speed sensor issue
Once you have done this it will be easier to determine the next step in fixing your AWD
That is correct but irrelevant. The MY90 Legacy has the same AWD system as his car.
Old 11-18-2008, 12:09 PM   #7
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
if you are lacking the AWD then perhaps somebody has pulled the AWD fuse located in the engine bay. In the automatics you can actually turn off the AWD for whatever reason. THIS IS ONLY ON AUTOS!!!
do a search to find out where this fuse actually is...
Zefy is offline   Reply With Quote
Old 11-18-2008, 09:59 PM   #8
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
It may be relevent if the OP's car is FWD. He wouldn't be the first Subaru owner to find out their recently purchased car wasn't AWD.
Bort is offline   Reply With Quote
Old 12-01-2008, 06:33 PM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
Delsole: Any news?
I guess that is possible! The LSi definitely came with AWD from the factory but it could be possible someone installed a FWD tranny.
Old 12-01-2008, 07:30 PM   #10
Bort
Member#: 27075
09 WRX, 03 WRX,
98 OBS
Delsole: Any news?
oops, I missed the LSi part. It should have factory AWD fer sher.
Old 12-02-2008, 10:02 AM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
That's backwards. Under the hood by the right front strut is a fuse holder that will say "FWD" on the cover. There should NOT be a fuse in there, if somebody put one in, the car is running in front wheel drive.
Old 12-03-2008, 12:30 AM   #12
alejo
Member#: 170081
2004 2.5RS
blue
check your instrument cluster. If the fuse is on you might get a red light saying "FWD" like the 1999 models, but I'm not sure if yours has it. But htat is most likely to be the problem. good luck, cheers
alejo is offline   Reply With Quote
no awd Illshou Legacy Forum 5 11-05-2006 07:22 PM
Smart ppl with no AWD video helpermonkey77 Member's Car Gallery 31 01-31-2005 02:54 PM
Poor Bug - No AWD capecod_wrx New England Impreza Club Forum -- NESIC 8 01-26-2005 06:19 PM
No AWD? xcntrk75 Legacy Forum 6 10-15-2004 03:16 AM
Why is there no AWD dynos in Ohio ashden_wrx Mid West Subaru Owners Club Forum -- MWSOC 2 02-19-2003 12:03 AM
