Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 11-17-2008, 07:52 PM   #1
xrobbyx
Member#: 109456
Default help,... wheel and suspension
ok so i keep getting crazy answers to this question maybe some one here with lots of knowlege can help
im wanting to get the enkei nt03 in a 17x9.5 with a 44 offset, i know i will need to roll the fenders but will i need to run spacers in the front and can these be put on using stock suspension, no coilovers
i keep getting a mixed responce from people also will i need to roll front and rear or just the front
thanx for the help
xrobbyx is offline   Reply With Quote
Old 11-17-2008, 08:47 PM   #2
wrxskier18
Member#: 88005
2002 WRX PSM
GS500
What size tires? What are you alignment specs?
wrxskier18 is offline   Reply With Quote
Old 11-17-2008, 10:51 PM   #3
jv01
Member#: 65597
06 sti
white/ #60 bsp
Default fitment
ooooops.
jv01 is offline   Reply With Quote
Old 11-17-2008, 10:54 PM   #4
jv01
Member#: 65597
06 sti
white/ #60 bsp
http://t3hclap.com/archives/11 take a look here pm him he will tell you what is needed and how big a tire you can fit
Old 11-18-2008, 10:21 AM   #5
WRX8XB
Member#: 45323
MY05 Impreza WRX STi
Pastelito Racing & SFSOC
those will clear the brakes without spacers and will work on the stock struts.
will it rub? that's a whole different question.
are you on stock springs as well?
what sort of camber adjustment do you have?
-t3h_Clap
WRX8XB is offline   Reply With Quote
Old 11-18-2008, 12:01 PM   #6
xrobbyx
Member#: 109456
-t3h_Clap
im on totally stock suspension, i have never touched it at all, im gonna run a 245 40 17 tire, and my bubdy is gonna roll the fenders for me.
should i roll front and rear or just the rear?
ok so i wont need spacers, bastards told me i would haha
Old 11-18-2008, 12:52 PM   #7
mav1c
Hoodbridge!
Member#: 560
2006 STi, '11 A4
Crystal Gray, Silver
If you're only going to run a 245/40-17 tire, why bother with a 9.5" wide wheel?
Old 11-18-2008, 03:04 PM   #8
WRX8XB
Member#: 45323
you familiar with the process to "roll" the rear fenders?
http://t3hclap.com/archives/49
you can't simply roll them.
if you're sticking to a 245/40/17 you should be ok on the stock suspension with some extra camber in the front (-1.5 or so).
it may poke a little.
are you going to upgrade the springs?
RCE Blacks would be a good choice if you don't want to lower much but still want to be able to run the 9.5s once you modified the rear fenders.
Old 11-18-2008, 03:17 PM   #9
xrobbyx
Member#: 109456
how can i get it to pull in almost flush?
yeah at some point i will lower my car alittle either the rce or the prodrives, or if my tax return is good enough i will eventually get coilovers, but i just wanted to be sure that i could run these wheels with a stock set up first
yeah im pretty famillure with the process one of my car friends has been doing it for about 5 years now
Old 11-18-2008, 04:09 PM   #10
WRX8XB
Member#: 45323
click the link. the 05-07 fenders are not the same as the others.
you can't do a conventional "roll"
you'll most likely just need to add some camber bolts front and rear to get camber to -1.5 front and matching -1.5 to -1.7 rear.
Old 11-18-2008, 04:14 PM   #11
xrobbyx
Member#: 109456
ok cool, so it is possible for this to be done on stock suspension, and the place i take it to should know what there doing then as far as the whole allignment and camber thing
and i should buy the spacers then right they lied to me haha?
again thanx for all the help
Old 11-18-2008, 04:45 PM   #12
WRX8XB
Member#: 45323
there was a guy running these wheels with 275s on them on the stock struts with RCE blacks.
stock camber cannot get you where you need to be.
but if you're only going for a 245 a 9" +45mm would require less work and be a better match.
Old 11-18-2008, 04:51 PM   #13
xrobbyx
Member#: 109456
thanx man !!!! im excited now for my new wheels!!
how did that guy adjust his camber enought to run a 275 tire
Old 11-18-2008, 04:56 PM   #14
WRX8XB
Member#: 45323
they poked.
he also had front camber plates.
Old 11-18-2008, 07:16 PM   #15
xrobbyx
Member#: 109456
they poked.
all the way around poked or just the front or rear, not that i want to run that huge of a tire but that pretty awsome haha
do you tink i should get camber bolts before i go in or just wait to see if i need them, if so what ones are good
Old 11-19-2008, 10:57 AM   #16
WRX8XB
Member#: 45323
get the ingalls one from summit.
14mm WRX ones
they are only $16 a pair.
Old 12-28-2008, 02:48 AM   #17
xrobbyx
Member#: 109456
hey i changed my mind on wheels will i still be able to fit a 17x9 with a 38 offset with stock suspension
Old 12-28-2008, 11:11 PM   #18
WRX8XB
Member#: 45323
replied to your PM.
Wheel and Suspension Sales Free Ground Shipping MauroMotorsports Wheels/Tires 26 06-03-2005 11:20 PM
Looking for tires and wheels and suspension setup... hanginit Private 'Wanted' Classifieds 2 08-11-2004 05:10 PM
rubbing? stock wheels and suspension... HELP! Black-X Brakes, Steering & Suspension 0 02-04-2003 01:27 PM
better wheels and suspension for a wagon alphabenson Brakes, Steering & Suspension 4 01-12-2002 12:06 AM
Wheel and Suspension setup bikerboy Brakes, Steering & Suspension 2 04-05-2001 07:51 AM
Message Board Statistics All times are GMT -4. The time now is 08:08 AM.
