Old 11-17-2008, 08:56 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default turbo upgrade without standalone ecu ?
i have a 94 wrx, td05 turbo.. and stock ECU. (U8)
my turbo is going bad and i want to upgrade a little bit.
or that possible on a stock ECU, or do i just have to replace the turbo with another TD05
what is the biggest turbo i can get without tuning?
i heard the VF22 can go on my car without tuning. is that right?
azn0boi04 is offline   Reply With Quote
Old 11-17-2008, 09:11 PM   #2
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Any of the STi variant factory VF series turbos would be an acceptable replacement. However I wouldn't really call any of them other much of an upgrade. But to really upgrade (like to an 18G) you need bigger injectors, bigger intercooler and new EM.
Old 11-17-2008, 09:14 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
o cool.. i thought i had to tune my car if i got an STI turbo..
why dont u think any of those are an upgrade from a td05.
i dont wanna upgrade Too much, because i dont want to get a new EM, yet...
Old 11-17-2008, 09:51 PM   #4
suberdave
Member#: 101865
88 GL-10 STi
any turbo will work, the ECU dose not know what turbo is on the car. you do not have to tune for a turbo.
what you have to tune for is higher boost...
if you run a TDO5 at 12 PSI it is the same as runing a GT40 at 12 PSI. but most people have to tune due to the fact that people run different turbos for higher boost, and earlier spool.
if this statement is wrong someone correct me...
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 11-17-2008, 10:28 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
what would be the best turbo to put on my car?
VF___?
not sure if i want low end power or high end power...
i will be running about 17 psi boost...
Old 11-17-2008, 10:57 PM   #6
suberdave
Member#: 101865
88 GL-10 STi
for 17 PSI you will most deffantly need larger injectors, bigger intercooler and some serious EM...
to run any front entry "VF" turbo you will need a EJ20K intake or rotated or some different turbo config.
-=Suberdave=-
Old 11-17-2008, 11:32 PM   #7
supasweetr34skyline
Member#: 113060
2000 Built GC8
Aiming for 10's
-=Suberdave=-
not true. you can run a 90inlet pipe.
supasweetr34skyline is offline   Reply With Quote
Old 11-17-2008, 11:35 PM   #8
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
i can? wow my options are just bouncing back and forth..
but i would have to get another intercooler.. cuz my slanty is said to handle only 18 psi or something like that... and 17 is right next to 18.. haha
Old 11-17-2008, 11:46 PM   #9
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
deadbolt will change the housing over to the 90 degree inlet for cheap. good call kevin.
gc8awdsti is offline   Reply With Quote
Old 11-18-2008, 12:00 AM   #10
suberdave
Member#: 101865
88 GL-10 STi
something like this may be an option...
http://www.optionimports.com/90demotituel1.html
Old 11-18-2008, 12:13 AM   #11
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
hahah that looks easy to make.. with some 3 inch tube and a heat gun.... but if something like that will work, then ill have to look into it...
Old 11-18-2008, 12:16 AM   #12
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
wow suberdave that peice is nice. seriously i tried to make a 90 degree one time and it was boost leak from hell.lol
im about to buy that peice right now..lol thanks man.
Old 11-18-2008, 01:48 AM   #13
Super Nintendo
Member#: 73721
2007 STI
PTE 6266
-=Suberdave=-
That's actually wrong. Bigger turbos move more CFM at the same PSI.
-Ty
Super Nintendo is offline   Reply With Quote
Old 11-18-2008, 09:55 AM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
Here's a start for you:
http://www.mrtrally.com.au/performan...turbo-data.pdf
A vf22, which has a very similar sized exhaust wheel to the Td05 that's currently in your car puts out about 450cfm at 1 bar of boost. The Td05 will put out 505cfm at the same pressure. And that's the biggest of those VF series turbos that were found on factory STi's (in reality, the VF22 was found stock on v3&v4 5MT sedans and were an option on the v3&4 STi's). All the others are smaller. The only one I know nothing about is our current vf39 USDM STi turbo. I am sure a quick search will give you some flow numbers or someone else will add in the answers here.
At higher pressures, the vf22 has been shown to outflow the Td05 by about 5 or at most 10% as you approach something like 1.2 bar. But as others have said if you want to push that kind of pressure you will need injectors.
Turbo upgrade without the exhaust swap The Blue Pilot Newbies & FAQs 15 11-03-2009 12:05 PM
FS: CA Autronic SM2 STANDALONE ECU PNP WRX ECU, TURBOXS TUNA my02wrx Engine/Power/Exhaust 0 10-13-2008 12:58 PM
turbo upgrade without a dyno tune? hirevn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 03-18-2005 02:37 PM
FS: GC8 2.5RS Turbo Kit / Front Mount / Standalone ECU / Etc... bigbird Private 'For Sale' Classifieds 16 11-06-2003 03:51 PM
ECU upgrade or Turbo upgrade??? 1Slow///M3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 09-07-2003 12:17 AM
