Old 11-17-2008, 11:40 PM   #1
St0k3d
Member#: 48603
2008 STi
Default Oil Pressure problem has me stumped, help!
Im helping my friend out with his car
2005 STi - motor lost cylinder 3, so we yanked out the old and replaced the block with a new oem shortblock with forged pistons, had the heads cleaned up etc
We put everything back together, not cutting any corners, replaced timing belt, water pump, oil pump, all new gaskets, idler, belts etc etc etc
Prime engine via cranking it with ign fuse out for about a minute
Start the motor up and has 80psi of oil pressure, motor runs great, let it idle till the thermostat opened up, but the car needs a tune due to a couple new mods added as well, the ecu was scaled already for new injectors to avoid washing the rings (injectors, turbo, fuel rails, oil pan, oil cooler, oil pickup, all new o-rings & gaskets, 255 fuel pump etc).
So i get a new startup tune from my tuner, flash it on the car, change the oil and filter just because, and start the car up
to my suprise the car now has 0 oil pressure, both in the defi gauge and oil pressure light on, shut the car off immediately
Car goes into the shop and is now on a lift
We have tried
New Oil pump - no difference
checked brand new pickup - great shape
Pick-up O-ring is there and in good condition
oil pan perfect
Oil cooler (thing above oil filter) is in perfect shape
Tried a couple different oil filters - no change
blew compressed air through all pump holes and oil passeges in that area, no problems
Tried cranking the car with the oil filter off, to see if the pump pumps oil out of the filter hole - nothing (even with 2nd used last time working oil pump, and brand new pump)
Im out of ideas, i cannot for the life of me figure out how this car isnt getting oil pressure, the first time it started right up perfect
I really have my doubts theres 2 bad oil pumps, and a 3rd would fix the problem
Any help or suggestions to try?
St0k3d is offline   Reply With Quote
Old 11-18-2008, 12:01 AM   #2
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
CGM
Clogged oil line somewhere maybe, in either the AVCS lines, heads, turbo screen and/or line.
Crystal_Imprezav is offline   Reply With Quote
Old 11-18-2008, 12:24 AM   #3
St0k3d
Member#: 48603
2008 STi
thought about that, but that wouldnt explain the not pumping with no oil filter as that is pre everything else
goes
Oil pickup --- > oil pump ---- > passageway (not blocked) --- > oil filter
Help Low Boost Problem has me stumped! AnthonyA182 Open Source Reflashes 8 03-16-2010 02:25 AM
oil pressure problem please help me. turboboxer80 'Old School' Subaru Forum 10 06-21-2008 09:16 PM
SPT turbo heatshield has me stumped!!! 02blkwagn19 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 08-23-2007 03:29 PM
Drivetrain Clunk- I can't believe this has me stumped MK19_ Transmission (AT/MT) & Driveline 59 03-19-2007 10:58 PM
this has me stumped.. white smoke but only sometimes? my02turboWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 08-24-2004 10:41 AM
