Old 11-18-2008, 01:01 PM   #1
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
Default Mixing oil with a 2000 legacy
My fianceee has a 2000 legacy GT. Here is the sitation.
The car currently has 5w30 oil in it. The car has a small nick in the oil plug due to something small hitting it while driving. Anyways I checked her oil and noticed it was a bit low. I decided to add a half of quart or so of 10w30 oil. Is this a very bad idea or should it be ok?
Thanks for the help
-Daniel
Super_HKS is offline   Reply With Quote
Old 11-18-2008, 01:42 PM   #2
obs2008
Member#: 163068
08 outback sport
its no problem at all. you can mix weights that are close or you can mix synthetic/non synthetic. no worries
obs2008 is offline   Reply With Quote
Old 11-18-2008, 01:47 PM   #3
joecerv
Member#: 110459
2006 Impreza 2.5i
Steel gray metallic
It is not a good idea to mix 5w30 oil with 10w30 oil.
Taken from the owner's manual.
"When adding oil, different brands may be used together as long as they are the same API classification and SAE viscosity as those recommended by SUBARU. "
joecerv is offline   Reply With Quote
Old 11-18-2008, 04:03 PM   #4
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
I know in theory, it could be no good.
My experience is np. I have a 2001 Legacy GT. Since it burns oil a bit. I keep a bottle in the trunk to "fill-up" in between changes. It is not picky on various bottles of oil I topped off with.
Jerry Xu is offline   Reply With Quote
Old 11-18-2008, 05:17 PM   #5
obs2008
Member#: 163068
08 outback sport
it doesnt matter if you mix weights, honestly
Old 11-19-2008, 09:57 AM   #6
Super_HKS
Member#: 154434
Cool. Thanks for everyones help
Old 11-23-2008, 03:50 AM   #7
Ioku
Member#: 164864
95 Impreza coupe
I'd say mixed weight oil is better than no oil, I always keep some extra oil in my trunk thats a mix of various brands and weights.
Ioku is offline   Reply With Quote
Old 11-24-2008, 12:21 AM   #8
JamesWilson
Member#: 124833
2000 Legacy Wagon
Mystic Mountain Blueberry
You will have zero problems mixing weights, you can actually custom-blend your own weight if you would like. Just keep the oil level at full, and you'll be fine.
JamesWilson is offline   Reply With Quote
Can I Mix Regular Oil With Synthetic?!?! Jaren1 North West Impreza Club Forum -- NWIC 10 12-13-2008 06:22 PM
Mixing oem with syntetic transmision oils? vapore0n Transmission (AT/MT) & Driveline 1 07-11-2007 04:24 PM
what exactly changed with the 2000+ legacys spdracr00 Legacy Forum 17 05-31-2007 05:25 PM
Oops, got oil mixed in with power steering popnGEAR Service & Maintenance 2 08-19-2005 09:59 AM
Can you mix synthetic oil with non synthetic? SubaruImpreza_power Newbies & FAQs 6 10-31-2003 08:56 PM
