Old 11-18-2008, 01:19 PM   #1
ClayMac
Member#: 194194
2002 WRX Wagon
White/Black
Default Is my fuel pump getting weak or is it the Turbo?
http://forums.nasioc.com/forums/show....php?t=1640982
I started this thread in the Newbees forum and was told to move it here.
The car cuts all boost when boost it spools under a load.
ClayMac is offline   Reply With Quote
Old 11-18-2008, 01:28 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I would change the fuel pump...
wrxdrvr is offline   Reply With Quote
Old 11-18-2008, 03:03 PM   #3
ClayMac
Member#: 194194
2002 WRX Wagon
White/Black
Have you experienced a similar problem? Thank you for your reply. Do you have a recommendation on brand of fuel pump?
Old 11-18-2008, 03:15 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes, A Walbro 255L/Hr worked well for me.
Old 11-18-2008, 03:19 PM   #5
ClayMac
Member#: 194194
2002 WRX Wagon
White/Black
So, you were having this issue and installed the Walbro 255L/Hr and were in the Pink!? I imagine that would be plenty of pump for a turbo upgrade as well? et?
Old 11-18-2008, 03:42 PM   #6
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Yes the exact same issue, did the same as you replaced fuel filter cleaned MAF and then changed to the Walbro and every thing was OK after that...
Old 11-18-2008, 05:53 PM   #7
MrSlowbaru
Member#: 129231
2005 wrx
cgm
what psi are you hitting when you get fuel cutoff?
MrSlowbaru is offline   Reply With Quote
Old 11-18-2008, 06:36 PM   #8
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
He didn't get a Cell so it probably wasn't fuel cut from over boosting...
Old 11-20-2008, 12:31 PM   #9
ClayMac
Member#: 194194
2002 WRX Wagon
White/Black
I do not have any gauges. I don't know fuel pressure or boost.
Old 11-20-2008, 01:31 PM   #10
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
do you have a MBC?
StupidFastWagon is offline   Reply With Quote
Old 11-20-2008, 01:36 PM   #11
ClayMac
Member#: 194194
2002 WRX Wagon
White/Black
Originally Posted by StupidFastWagon View Post
do you have a MBC?
My car is stock as far as I know. I don't know what MBC is. (Boost Control)?
Old 11-20-2008, 03:54 PM   #12
samb
Member#: 177235
2012 Mustang
Manual Boost Controller
samb is offline   Reply With Quote
Old 11-20-2008, 03:59 PM   #13
ClayMac
Member#: 194194
2002 WRX Wagon
White/Black
Stupidfastwagon / Samb - do you guys agree that it is my fuel pump.
I am planning on ordering one this weekend.
Is my fuel pump in my 00 2.5RS adequet for the track? Rallly2000 Normally Aspirated Powertrain 21 07-22-2009 03:13 PM
cranks, no start where the f is my fuel pump relay EntertheWagon Newbies & FAQs 26 07-10-2009 01:48 PM
Is my fuel pump going bad? Or is it worse? NicGordon Service & Maintenance 5 10-15-2002 02:43 PM
1/16" fitting mod: Is my boost solenoid now kaput or is there a fuse/reset? Blitzer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-17-2002 03:13 PM
Is my fuel pump crapping out on me? Jewbaru Normally Aspirated with bolt-on Forced Induction Powertrain 9 04-18-2002 10:43 PM
