Old 11-18-2008, 03:11 PM   #1
greg86jgl
Member#: 191510
2003 wrx
blue
Default very big problem...suggestions?
my 03 wrx is consuming a very high amounts of oil(about 2quarts in 1500miles). no leaks noticed. the car smokes from the exhaust after running hard. only hits about 10psi and set at 15psi in 1st. 2nd hits 15psi then drops off and boost back up. car feels week at peek boost. "3 turboback divorced 1 highflow cat, cobb intake and box, cobb ap. i am instaling sti pinks vf30 sti uppipe hyperflow topmount on sat. please let me know your thoughts...if this is just the turbo or if it is something else if so how do i find out besides going to the dealer..
greg86jgl is offline   Reply With Quote
Old 11-18-2008, 04:24 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
blown piston mebbee
check compression
be prepared to $pend $$$$
Old 11-19-2008, 08:18 AM   #3
SiGuy
Member#: 194735
2007 Civic Si
Taffeta White
First and easiest thing to do is a compression test. Once you get those results post back. Don't get ahead of your self thinking about cost and such, one thing at a time. If you need new rings and don't feel confident I live in the area and have the means to do the job. First things first get that compression test.
SiGuy is offline   Reply With Quote
Old 11-19-2008, 09:58 AM   #4
surowrxa
Member#: 102895
'12 Forester
'08 Legacy
Originally Posted by Uncle Scotty View Post
check compression
I agree as well. If everything is good, turbo is next on the checklist.
What color is the smoke? Bad trubo or so much oil is getting to the turbo it's getting past the seals = blue smoke.
You will find out some more info when you pull your intercooler.
surowrxa is offline   Reply With Quote
Old 11-19-2008, 02:01 PM   #5
greg86jgl
Member#: 191510
2003 wrx
blue
when it smokes its a thick lingering whitish color may have a blue tint to it but you can smell it, dosnt smell sweet, smells like burnt oil...there isnt any anti freeze missing and yesterday i filled the oil up and it smoked for about ten mins... by the time i shut the car down there was a good amount of oil at the end of the exhaust. well i have everything for the turbo install so im gona put the new turbo, injectors and uppipe in on fridaynight. ill post pictures of hotside/inside downpipe/uppipe when then come off. sat ill get the compresion test and post that also. ps ive taken the intercooler off before and there was oil in it.
Old 11-19-2008, 02:06 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
if there is THAT much oil
get the compression checked before you do ANYTHING
Old 11-19-2008, 02:35 PM   #7
SiGuy
Member#: 194735
2007 Civic Si
Taffeta White
Agreed do the compression check. And take the intercooler to a parts washer, oil will lower the efficeincy of an intercooler drastically.
Old 11-19-2008, 02:37 PM   #8
unclemat
Member#: 114530
2005 LGT 6MT wagon
If it smokes from the exhaust it's turbo.
If you do compression test do a leak down test as well, much more useful.
unclemat is offline   Reply With Quote
Old 11-19-2008, 02:40 PM   #9
SiGuy
Member#: 194735
2007 Civic Si
Taffeta White
Figured that was a given, but agreed.
Old 11-26-2008, 02:12 PM   #10
greg86jgl
Member#: 191510
2003 wrx
blue
ok so i had the compresion test and leak test done this passed sat. my mic said everything was ok there. so i went alonge with the turbo injector uppipe install. my mic said that while installing the turbo he went over all the vacum lines to make sure everything was ok and found that the line going into my oil catch can was pinched almost shut. believe this was causing my boost problem...maybe unrelived pressure...as for the oil burnning problem, the hot side of my turbo looked like the inside of a fireplace or boiler that was burnning way to rich(caked with soot sorry boiler guy) dont know how to get a pic posted on here(if anyone knows please post). i changed the oil and will keep an eye on it but no more smoke..only one problem ihave a slow anti freeze leak from somewhere in the area of the turbo . cant see it from the top but u can see the anti freeze on the underboody...our turbos have a ati freeze line to them?
Old 11-26-2008, 03:32 PM   #11
jclarkwrx
Member#: 180845
2003 WRX STAGE 2
they're cooled with intercooler, and they use the engines oil to lubricate them.
jclarkwrx is offline   Reply With Quote
Old 11-26-2008, 03:43 PM   #12
greg86jgl
Member#: 191510
2003 wrx
blue
ok i didnt thnk they had any anti freez lines to them\
Old 11-26-2008, 03:46 PM   #13
greg86jgl
Member#: 191510
2003 wrx
blue
so the leak is from somewhere around it when he was doing the install
Old 11-26-2008, 04:08 PM   #14
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
No, they aren't.
DrSaabaru is offline   Reply With Quote
Old 11-26-2008, 04:09 PM   #15
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
Yes, they do.
Old 11-26-2008, 04:10 PM   #16
AndyH
Member#: 2133
2005 STi WRB/Gold
2005 S4 Avant
Correct, they are cooled by the engine coolant (a.k.a., antifreeze) and lubricated with engine oil.
AndyH is offline   Reply With Quote
Old 11-26-2008, 04:50 PM   #17
rick-l
Member#: 33868
2003 wrx
srp
From the information manual
The turbocharger is lubricated by engine oil branched out from the oil pump. To cope with very high speed of the turbocharger turbine and the compressor shaft which may reach a maximum of several hundred thousands of rpm, full-floating type bearings are used which can form adequate oil films on their inside and outside during running.
Further the oil supplied to the turbocharger also plays a role of cooling the turbine so that heat from exhaust gas does not get transmitted to the bearings
The turbocharger unit is cooled by engine coolant, which enhances the reliability and durability of the unit. The engine coolant from the coolant drain hose located under the cylinder head is fed by a pipe to the coolant passage provided in the turbocharger bearing housing. After cooling the bearing housing, the engine coolant is fed into the coolant filler tank through a pipe.
rick-l is offline   Reply With Quote
Old 11-26-2008, 06:48 PM   #18
greg86jgl
Member#: 191510
2003 wrx
blue
yes they are and thats were the leak was coming from...just had to back the clamp up a little....another question while im here. i changed the oil yesterday and checked it today and bairly any was on the dipstick with no oil spots in driveway...went and got somemore oil went to change it and the hole 4.8 quarts came out? filled it agian and it read full..any1 ever here of that or have it happen
Old 12-02-2008, 02:02 PM   #19
Bader86
Member#: 179984
2003 WRX
I seem to be having a similar problem. I would really appreciate it if some of you could take a look at :
http://forums.nasioc.com/forums/show....php?t=1650035
Bader86 is offline   Reply With Quote
small problem or big problem? revenance Transmission (AT/MT) & Driveline 4 06-10-2008 09:04 PM
Subaru paint + Suntan lotion = VERY BAD....any suggestions SubieCubed Interior & Exterior Modification 37 07-11-2007 11:29 AM
Big power....big problem? Breen Subaru Conversions 6 08-29-2004 11:15 PM
Big, big problem. Did I blow the engine? KKoepp31 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-29-2003 01:56 AM
Oil line problem fix....now a BIG BIG problem the spacecowboy Normally Aspirated with bolt-on Forced Induction Powertrain 11 11-26-2002 02:17 AM
