Welcome to the North American Subaru Impreza Owners Club Monday August 31, 2015
South East Region Club
Go Back   NASIOC > NASIOC Regional Areas > South East Region Forum
Old 11-18-2008, 03:46 PM   #1
thrdeye
Member#: 24569
2011 Impreza WRX
Default Steering wheel hard to turn at idle - powers steering pump?
I have noticed recently that when I am about to pull out of a parking space (low RPM), it feels like I have no power steering. Driving normally, no problems.
Is my pump on it's way out?
thrdeye is offline   Reply With Quote
Old 11-18-2008, 03:59 PM   #2
dstan
Member#: 120386
2000 BRP 2.5RS Coupe
Wow the 89 Civic is fast
Have you ever flushed the system?
Mine was acting funny so I took a turkey baster and sucked all of the old fluid I could,then filled it with new, cycled the steering lock to lock a few times. repeated 4 or 5 times. it seems to have done the trick
dstan is offline   Reply With Quote
Old 11-18-2008, 04:00 PM   #3
thrdeye
Member#: 24569
2011 Impreza WRX
Nope, not done that yet. What fluid did you use? ATF right?
Old 11-18-2008, 04:24 PM   #4
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
dexron..or mercron..
you might have a small leak..
but you are definitely low on fluid.
Old 11-18-2008, 05:24 PM   #5
Ken-Ohki
Member#: 11222
2015 Chevy Volt
mine has been doing the same thing and making alot of noise too, seems to go away when the car is rolling for some reason. fluid is definately not low
Ken-Ohki is offline   Reply With Quote
Old 11-18-2008, 05:31 PM   #6
thrdeye
Member#: 24569
2011 Impreza WRX
Same here. Fluid level good.
Old 11-18-2008, 08:40 PM   #7
dstan
Member#: 120386
Flush the System, Do it, do it.
I used Castrol ATF dexron 6 a synthetic blend
Old 11-19-2008, 12:38 PM   #8
pleiades
Member#: 2491
06 Miata
81 Fiat Spider
Use Motul Synthetic ATF!
And check the hose connections down at the rack (two fittings that are right at where the lines go through the engine crossmember) they've been known to loosen up and leak.
pleiades is offline   Reply With Quote
Old 11-19-2008, 06:38 PM   #9
Ken-Ohki
Member#: 11222
2015 Chevy Volt
well, i did mine today. turns our the reservoir was stained on the sides and only looked to be full. it was low, very low.
used the baster to removed rest of fluid. refilled with dex3. operating very smoothly now
Old 11-19-2008, 07:21 PM   #10
dstan
Member#: 120386
subie n00b to the rescue
Old 11-19-2008, 10:56 PM   #11
thrdeye
Member#: 24569
2011 Impreza WRX
well god dang better check my fluid for realsies then.
Old 11-19-2008, 11:13 PM   #12
dstan
Member#: 120386
Chris the flush is not bad either
Old 11-20-2008, 12:23 AM   #13
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
ding..ding..
Old 11-20-2008, 06:52 PM   #14
Ken-Ohki
Member#: 11222
2015 Chevy Volt
actually after driving to work, i realized the problem is not yet solved
steering actually seems to lock up a bit at idle engine rpm.
i did recently change belts, and the new belts are probably overtight and still seem to slip quite a bit
Old 11-20-2008, 07:52 PM   #15
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
Mine does the same thing at idle.... I turn from lock to lock and near the end it gets bumpy..... I need to figure out how to flush the system.
rek888v2 is offline   Reply With Quote
Old 11-21-2008, 09:06 AM   #16
thrdeye
Member#: 24569
2011 Impreza WRX
My fluid was good. This morning, since it was cold, I heard my belt squeak at startup. I bet this is the problem.
Old 11-21-2008, 01:52 PM   #17
atenzany62
Member#: 163172
add me to the list. been having this problem since i bought the car in june...
atenzany62 is offline   Reply With Quote
Old 11-21-2008, 02:49 PM   #18
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Mine was getting hard and acting strange when the belt was about to break.
hybrid gti 2 is online now   Reply With Quote
Old 11-21-2008, 05:31 PM   #19
rek888v2
Member#: 71287
S202 + 04 STi + 02
WRX
I heard a squeaking belt and tightened it and it actually fixed the issue!!!
TIGHTEN YOUR BELTS PEOPLE!!!
Old 11-22-2008, 12:05 AM   #20
atenzany62
Member#: 163172
+1 tighten your belts it should fix the problem
Old 11-22-2008, 01:18 AM   #21
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
It didn't squeak almost at all
Old 11-23-2008, 01:18 PM   #22
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
so i was thinking that the hard lines take 17mm..
anyone confirm this?
Old 11-23-2008, 03:05 PM   #23
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
well just got done with repairs..
14mm..passenger side..
Old 12-15-2008, 09:07 AM   #24
thrdeye
Member#: 24569
2011 Impreza WRX
Just an update....pleiades Web MD'd that isht....14 mm bolt was loose on the hard line. passenger side.
HELP! Extremely hard to turn steering wheel... Mikeye Brakes, Steering & Suspension 2 05-02-2010 12:21 PM
steering grinding especially when turning at idle Sir Punk Brakes, Steering & Suspension 10 04-13-2010 11:24 AM
Steering doesn't want to turn at idle ? GuitarkidM3 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-14-2009 11:22 PM
why is my steering still hard to turn? IllNastyImpreza Service & Maintenance 4 03-24-2008 11:57 AM
swapping steering wheels ?? hard to do ? IllNastyImpreza Interior & Exterior Modification 1 01-27-2008 10:26 PM
