Old 11-18-2008, 04:48 PM   #1
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
Default 05RS Intake Manifold on 98 Legacy EJ22
So I heard that he intake manifold from a 2005 RS is the best flowing one. Will it bolt up to my EJ22?
Zac86 is offline   Reply With Quote
Old 11-18-2008, 04:51 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
Not if it's a 1998 EJ22.
Jay
Old 11-18-2008, 04:55 PM   #3
Zac86
Member#: 136919
ABP
oh whats wrong with the 98 ej22?
Old 11-18-2008, 08:33 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
It's a phase I motor and has a different bolt pattern for the intake manifold.
Also, the 05 is drive by wire, so you'll have to fabricate a cable stop for the throttle.
Other than that....it's a great manifold.
Jay
Old 11-18-2008, 08:55 PM   #5
Zac86
Member#: 136919
ABP
So which intake manifold could I bolt on that I would benefit from?
Also is the intake manifold and throttlebody from a 96 legacy EJ22 the same as my 98 legacy ej22? As I know where I can get them for cheap and i'll port them myself.
Old 11-19-2008, 07:12 AM   #6
Storm
Member#: 5218
96L Most Over-
Developed Beater
There isn't anything currently out there that will be of measurable difference. It would be different if the motor were a 99+ EJ22. At that point, you can use many different manifolds.
I suppose if you found a spare manifold, you could have it extrudehoned for some help.
Jay
Old 11-19-2008, 11:42 AM   #7
Zac86
Member#: 136919
ABP
is the 96 ej22 intake and throttle body the same as mine?
Old 11-19-2008, 11:42 AM   #8
Qman
Member#: 964
'95 work in
progress
The porting in the '05+ manifold is indeed huge. There is a problem that I see though. Because the ports are so much larger that the transition area is mismatched too much. There is not any way to get the port sizes close enough to get good transitional flow between a newer manifold and an older set of heads. Just my opinion here. Also, we put one on a flow bench. It did flow more air but did not have any more velocity. Which is crucial to a N/A application. Has anyone gotten hard dyno data from adding one of these manifolds yet?
Qman is offline   Reply With Quote
Old 11-19-2008, 11:43 AM   #9
Qman
Member#: 964
'95 work in
progress
I believe it is.
The Sti intake manifold or the Legacy intake manifold Robson Texas Impreza Club Forum -- TXIC 3 07-12-2009 01:12 PM
Who is using Legacy GT intake manifold on their STi? PA04STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 09-10-2006 10:29 AM
JDM STI Intake Manifold on Legacy GT monstergremlin16 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-22-2006 05:47 PM
Anyone painted the 05rs Intake Manifold? Honkey3k Normally Aspirated Powertrain 1 09-01-2005 02:05 AM
STI Intake Manifold on 98. Fitting? Befits? awd4ever Normally Aspirated with bolt-on Forced Induction Powertrain 1 09-20-2003 03:06 PM
