Notices
Old 11-18-2008, 06:57 PM   #1
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Default Waste Heat Recovery System Wins Powertrain Innovation Of The Year Award
Turns your car's exhaust heat into reduced fuel usage...
From Green Car Congress
Waste Heat Recovery System Receives Powertrain Innovation of the Year Award
18 November 2008
The Paris, France-based developer of a waste heat recovery (WHR) system, heat2power, won the Powertrain Innovation of the Year Award at the Professional Motorsport World Expo in Cologne (11-13 November) with its Thermal Energy Recovery System (TERS). heat2power says that its WHR system can provide fuel savings of 15-35% under all driving conditions at a cost of approximately 30% more than a comparable turbocharged gasoline engine.
The heat2power system uses one or more cylinders for the regeneration of waste heat. These cylinders can be in replacement of the combustion cylinders inside an existing engine or as an add-on module that is connected to the engine by means of a gear set or a belt drive. It is also possible to have no mechanical linkage between the combustion engine and the WHR unit in case the power from the regeneration unit is taken off electrically.
The heat2power system, like other thermodynamic cycles, intakes and compresses a gas, heats it and allows it to it expand. The difference between an ICE and the heat2power system is that the heat input is not by a combustion inside the cylinder but by heat exchange external to the cylinder.
The regeneration device comprises:
* One or more piston, cylinder and rod groups, with 4 valves per cylinder, driven by standard camshafts;
* One gas-gas heat exchanger; and
* One dedicated boosting turbocharger.
After the expansion stroke, the air is released at low temperatures (250-300 C instead of 600-950C). The heat exchanger in the exhaust is placed after the catalyst (gasoline vehicles) or after the particle filter (diesel vehicles), allowing the exhaust aftertreatment system to be unaffected. heat2power recommends application of thermal insulation of the exhaust manifold and the first part of the exhaust and catalyst/DPF so that a maximum amount of heat is available for the regeneration process.
The system is compatible with all fuel types (e.g., diesel, gasoline, ethanol, CNG, LPG, etc.) and complementary with hybrid electric powertrain concepts.
heat2power is seeking partners for prototyping and testing of its devices.
Cutaway diagram of the heat2power system mounted on an engine.
System layout of a heat2power add-in configuration and power flows.
Specific fuel consumption for conventional engine (left) and engine with heat2power (right).
Chromer is offline   Reply With Quote
Old 11-18-2008, 07:09 PM   #2
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I thought BMW was also working on a system similar to this?
Stanley is offline   Reply With Quote
Old 11-18-2008, 09:07 PM   #3
controler
Member#: 100271
When I first heard of heat recovery was thinking it worked by having a turbine like device with an alternator instead of a compressor. Granted you might only save 5-10% from removing the belt driven alternator. This describes it in much better detail. I still don't understand how it can save 15-35% fuel.
controler is offline   Reply With Quote
Old 11-18-2008, 09:17 PM   #4
Chromer
Member#: 20325
08 Yamaha WR250R
07 Suzuki DL650
Something something internal combustion 35% thermal efficiency...
IIRC BMW's system was some insanely complicated steam turbine system. Very stereotypically German.
Old 11-18-2008, 09:21 PM   #5
boxerinside
Member#: 191994
I thought they where talking about a turbocharger
like the Saab commercial "we take energy from the exhaust and recycle it"
fancy marketing.
boxerinside is offline   Reply With Quote
Hyund-"eh" Genesis wins Canadian Car of the Year Award AVANTI R5 Non-Subaru News & Rumors 0 02-16-2009 12:47 PM
Hyundai Genesis wins the North American Car of the Year Award Len Non-Subaru News & Rumors 8 01-12-2009 07:32 AM
Prodrive / Xtac Gearbox up for Powertrain Innovation of the Year Award method News & Rumors 12 10-22-2008 07:35 PM
Subaru 2.5-Litre Turbo Boxer Engine wins 2006 International Engine Of The Year Award Paraskass General Community 12 07-30-2006 06:38 PM
2.5 Litre wins 2006 engine of the year award kwycstix News & Rumors 4 06-13-2006 03:16 PM
