Old 11-19-2008, 09:21 AM   #1
Odyknuck
Member#: 192866
2006 Impreza
Default Innercooler tubing size
I have used the search feature and can not find any info on Innercooler tubing size. I would be using an innercooler that mounts in front. What diameter is typically used?
Odyknuck is offline   Reply With Quote
Old 11-19-2008, 04:17 PM   #2
bugeyes
Member#: 64494
2001 V7 sti
Typical diameter is 2.5 inches.
bugeyes is offline   Reply With Quote
Old 11-19-2008, 08:32 PM   #3
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
3 inches on the hotside, 2.5 on the cold side IIRC is what most kits use...
2.5 should be fine for anything a piggybacked N/A ecu can generate (400whp @ the most id say)
mxpunk is offline   Reply With Quote
Old 11-19-2008, 09:17 PM   #4
Odyknuck
Member#: 192866
2006 Impreza
I have a 26" long by 6" tall by 3" thick Innercooler setup from another application that I was thinking of using. Would it be too restrictive? I am looking at running 6 to 7 PSI Boost.
Old 11-19-2008, 09:40 PM   #5
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
more details about your build would help but im gonna have to go with a big no unless you're running 7 lbs through a T-88..
Old 11-20-2008, 04:02 PM   #6
Odyknuck
Member#: 192866
2006 Impreza
Actually I have two Projects I am looking at Turbo charging. One is my 2006 Impreza. It will end up being a complete STI 2.5 motor swap. The other one is a 2000 RS N/A 2.5 motor going into an offroad car. This is the one that I am refering to in regards to the Innercooler. The motor will be replacing a Turbo charged 2332 VW motor. My intensions are to reuse as many parts I can. That would include the Innercooler, BOV. T3 60 trim Turbo, Exhaust system with blastgate and Dry Sump oil system. I will be mating the motor to a VW 4 speed 6 rib trans via a Kennady Engineering adapter plate. I will be using an OEM Subaru ECU and wiring Harness along with a GReddy Ultimate EMU, MAP sensor and Boost control solinoid. Hope thats enough Info. I also hope I dont offend any one here with this application.
Old 11-20-2008, 04:48 PM   #7
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
i would avoid a fmic in any off-road situation unless you know its only gonna be smooth gravel roads..fmics are 100% better then tmics, but they are alot more vulnerable to damage.
i watched a truck tire asplode on the nj turnpike and it came down just in time for me to smash into it going 70 mph..left a few bent fins on my fmic
Old 11-20-2008, 07:22 PM   #8
Odyknuck
Member#: 192866
2006 Impreza
The innercooler is currently mounted up high behind the seats. The car is an open tube frame Woods Buggy. Here is a link to some pics of it: http://woodsbuggy.com/ody.html
Old 11-21-2008, 09:49 AM   #9
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
bad ass. can't wait to see it SUBARU powered
IllNastyImpreza is offline   Reply With Quote
Old 11-21-2008, 11:18 AM   #10
Odyknuck
Member#: 192866
2006 Impreza
Thank you much. It was a lot of work. I just built it this year. Several of my buddies are running Subie motors in there cars. The Subie motor has great low end torque for this application.
Old 11-22-2008, 08:44 AM   #11
VIsubi
Member#: 187834
06 2.5i impreza
Red
why is it every time someone post a thread in N/A forceinduction...seems like the moderators take it down instead of leaving it in the forum...which ends up having people go to N/A to ask a question.....moderators it might be a good idea to leave posts alone when up in the right forum...just my 2 cents. Then you wouldn't have to cry about it in N/A build up forums.
VIsubi is offline   Reply With Quote
Old 11-22-2008, 08:48 AM   #12
VIsubi
Member#: 187834
06 2.5i impreza
Red
I to want to swap a EJ257 in my 06 impreza but Idon't think the tranny can handle alot of hard driving or launch's which is why I'm going with the EJ255 and maybe a cobb tune see where I'm at...I'm sure it will work and I know it'll bolt right up to it but...hard take offs not even launch's on the 2nd gear...only a matter of time. If you find out anything post it I might just go with the sti seeing as its only a grand more than the wrx 4500 over 5400...well worth it seeing as thats how much you'll have to spend to get sti power out of it.
Old 11-22-2008, 05:44 PM   #13
Odyknuck
Member#: 192866
2006 Impreza
Mine has an Auto trans in it. I would need to replace it with a manual trans so I would get one to handel the motor.
GM BCS tube size? Superorb Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-13-2007 06:24 PM
Vacuum tube size? gregsatt Texas Impreza Club Forum -- TXIC 10 12-02-2005 09:28 AM
MAF tube size recommendations...Ecutek Tuners chime in Physics Junkie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 01-28-2005 11:14 PM
Okay I give up, header tube sizes hotrod Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 07-26-2003 03:14 PM
Oil catch tank tubing size? blitzpb Normally Aspirated Powertrain 3 03-10-2001 10:32 AM
