Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 11-19-2008, 11:28 AM   #1
Member#: 143125
02 Sport Wagon
Default Blizzak LM 22 RFT
What are the down sides of a Run flat tire???
I can get a SWEET deal on some Blizzak LM 22 run flats as someone ordered them at my local expert tire and did not pick them up or puchase them or whatever..... its not a tire they stock and they don't want them in their storage any longer!
I just wanted opinions on Run Flat Tires before i i get them for about 50% off
BoGWAgon is offline   Reply With Quote
Old 11-19-2008, 12:10 PM   #2
Member#: 8365
2013 Ford Focus SE
Since you cannot tell if they are flat or not you need TPMS.
They are also heavier than regular tires.
krzyss is offline   Reply With Quote
Old 11-19-2008, 12:19 PM   #3
Member#: 137398
2004 Impreza 2.5RS
Like krzyss said, they are heavier tires. Check Tire Rack for the weight difference, IIRC it was about 4-5 lbs heavier than the non-RFT
EdHilario is offline   Reply With Quote
Old 11-19-2008, 01:51 PM   #4
Tire Rack Moderator
Member#: 1215
800 -428-8355
ext. 4362
you will need to install a tire pressure monitoring system to run those tires which will most liekly eat up any discount you are getting
4 New blizzak Lm-22 205-55-16 RFT Westbrook ct BoGWAgon NESIC Private Classifieds 3 10-06-2009 11:47 PM
FS: Blizzak LM-22 RFT Snow Tires BAC5.2 MAIC Private Classifieds 6 12-11-2006 09:41 AM
F/S Blizzak LM-22 RFT 225/45/17 3BadHabbits Tri-State Area Forum 14 11-26-2005 03:56 PM
Blizzak LM-22-best place MB Scoobie Newbie Canada Region Forum 0 10-05-2001 06:03 PM
Blizzak LM-22 first impressions Jon Bogert Brakes, Steering & Suspension 16 11-30-2000 01:56 PM
