Old 11-19-2008, 03:03 PM   #1
redsubbiewagon
Member#: 89491
1995 Impreza WAGON
Red
Default Need help locating!
I drive a 2002 Impreza 2.5 RS. I threw codes p0030, p0031, and p0171. The first two point to the bank 1 sensor 1 and the third is a precaution for running to lean, which is intertwined with the performance of bank 1. I need help locating the bank1 sensor 1. I am very new to working on this car and any help would be appreciated. thank you all
redsubbiewagon is offline   Reply With Quote
Old 11-19-2008, 05:36 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
I'm pretty sure bank 1 sensor 1 is your front O2 sensor.
as to WHY you're getting these codes....we'll need more info.
Old 11-20-2008, 01:15 PM   #3
redsubbiewagon
Member#: 89491
1995 Impreza WAGON
Red
Default O2 Sensor
i think ur right about the O2! I took a look, the front O2 looks damaged somehow, almost like the top there the wires connect is being corroded and delaminating. I need to replace that for sure. I was also wondering if you think I need to replace the 171 code as well, the lean air code, or if it will take care of itself once I get a new O2. Thanks again
Old 11-20-2008, 03:31 PM   #4
brumby
Member#: 162631
03 subaru wrx
i think the 00-02's had a front 02 sensor recall..it sounds like a 02.
brumby is online now   Reply With Quote
Old 11-20-2008, 08:46 PM   #5
my4isflat
Member#: 120002
2000 2.5 RS, '95
Legacy w/325k mi (RIP)
Replace the O2 sensor, should take care of all your codes. Just for reference sake all knock sensors and O2 sensors will read "bank 1" there is no "bank 2" on a 4 cylinder engine. Its just OBD II standardized language for DTC's.
my4isflat is offline   Reply With Quote
Old 11-24-2008, 10:50 PM   #6
redsubbiewagon
Member#: 89491
1995 Impreza WAGON
Red
I need to know more about this recall.... I just replaced the front O2 and within three hours, the CEL came back on!! Any help would be greatly appreciated!
Old 11-24-2008, 11:46 PM   #7
qualityracer
Member#: 176016
2002 2.5rs impreza
dark blue
after you replaced the sensor, did you unhook the + on the battery, wait like 5 mins, to clear the code? then reconnect to start the car, you shouldn't be getting any code.
qualityracer is offline   Reply With Quote
Old 11-25-2008, 09:26 AM   #8
redsubbiewagon
Member#: 89491
1995 Impreza WAGON
Red
I used a scan tool and had the codes cleared that way. if it is any concern, I also replaced this same sensor in April of 07! Only lasted about a year and a half
Old 11-25-2008, 09:42 AM   #9
suzuki4life
Member#: 72706
2002 RS 2.5
RBP
I have the same condition..
I am betting its the iac.
suzuki4life is offline   Reply With Quote
Need help locating parts! Rojorex Car Audio, Video & Security 1 12-14-2002 11:13 PM
Need help locating 22b pic going sideways in higher resolution latinskllz General Community 20 10-24-2002 09:01 AM
I need help locating connector (B58) Greg555 General Community 4 03-18-2002 11:29 AM
Need Help locating stumpz New England Impreza Club Forum -- NESIC 8 08-28-2001 10:42 AM
