Old 11-19-2008, 04:13 PM   #1
sebast120
Member#: 194765
2004 WRX STi
Default Transmission and rear diff fluid
Anyone knows if I really need to use that LSD oil from japan that subaru says I should use on my 2004 STi??? Or can I just use royal purple synth.
And for the transmission, Subaru says I should by their GL-5 synthetic 75W90 at 40$/1L, they sell 4L for that price anywhere else.
sebast120 is offline   Reply With Quote
Old 11-19-2008, 05:36 PM   #2
Engmus
Member#: 115645
Rear diff fluid should be a STRAIGHT 90W. I recommend Motul 90PA or the Subaru 90 weight fluid.
Frontdiff\Transmission any GL-5 75w90 works for the 6mt, its not very picky. I recommend Motul gear 300 75w90
Engmus is offline   Reply With Quote
Old 11-19-2008, 05:42 PM   #3
kidwitdawrx
Member#: 190156
2004 Impreza WRX
Java Black Pearl
Default ditto
im dont know much but im learning a lot now cause i blew my stock wrx up and am putter he back together as we speak. I have spoken to many subie specialists and they all told me the same for all my questions on what fluids to use. The motul is the most recomended and they told me to stay away from royal purple. DS1 motorsports dylan and jeff sell it for $60 for 4 liters. I just bought some trying to get as much life as I can out of my tranny.
kidwitdawrx is offline   Reply With Quote
Old 11-19-2008, 05:48 PM   #4
mikeythejew
Member#: 141672
07' wrx
Uncle Scotty 5W30
BTW, if RP is sooo good, why do they list what tranny fluid to use in what vehicle but not subaru?
http://www.royalpurple.com/transmission-chart.html
mikeythejew is offline   Reply With Quote
Old 11-19-2008, 05:58 PM   #5
Engmus
Member#: 115645
Meh, I know alot of people who swear by Royal Purple. I have more faith in Redline oils and Motul oils for botique, or specialty oils.
Old 11-19-2008, 06:29 PM   #6
satan's sled
Member#: 166281
2006 STI
CGM
is there a magic number when the fluids should be replaced? i have hearded 30k....is that for the normal DD? what about when tracking the car...or is that one of the first things you should do along with oil and brake fluid as well?
satan's sled is offline   Reply With Quote
Old 11-19-2008, 06:54 PM   #7
sebast120
Member#: 194765
2004 WRX STi
thks for the replys guys, Engmus, wath do you mean by straight 90 for the rear diff???
Old 11-19-2008, 10:02 PM   #8
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
He meant to say that the bottle should say SAE90 (rather than 75W90 or 80W90).
OTOH, if an SAE90 meets your needs, Schaeffer's #267 is flatly superior to anything that's been mentioned in this thread for outright strength and durability of the differential. Only question is: Does your STi use a clutch-type LSD, or is it viscous like every other Subaru? If clutch-type, then the 267 may not be suitable; you'd have to ask Schaeffer.
bulwnkl is offline   Reply With Quote
Old 11-20-2008, 12:51 PM   #9
Engmus
Member#: 115645
I like Schaeffers fluid, but I wouldn't say they are clearly superior without evidence to back something like that up. Especially when competing with Motul.
Seeing how he has a 2004 Subaru according to his profile its more then likely a clutch-type LSD.
Satans Sled, I do my trans and diff every 10-15k. Its easy, not very expensive and good preventative maintenance.
Old 11-20-2008, 02:27 PM   #10
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
I don't say Schaeffer is superior in a blanket way. The #267 specifically is absolutely unbelievably tough in terms of film strength and wear control. However, it's only available as an 80W90 or various ISO grades, so there are many reasons why it may not be suitable for a given application. Do NOT use it in the transmission. Also, the moly di-sulfide in it may or may not be a good idea in a clutch-type LSD. That's a question for Schaeffer.
Motul makes some very fine products, but I've never seen anything that shows me something extra-special about their performance compared to other very-high-quality fluids available in the USA. Mostly, what I've seen is that Motul is selling the perception of technical superiority and eurpoean mystique (that tends to try to imply technical superiority). 'Technical superiority' is what got the French overrun on the Maginot line during World War II (and other times & places) by a vastly 'inferior' German army. So, I'll counter by asking to see something about Motul that shows they're any better in real service than a variety of other things I've used or seen in analysis?
Old 11-20-2008, 02:59 PM   #11
sebast120
Member#: 194765
2004 WRX STi
Sooooo, I think I'll just go with the freackin oil from Japan that Subaru says I should use
Old 11-20-2008, 03:04 PM   #12
sebast120
Member#: 194765
2004 WRX STi
Hoo, and I do have the LSD rear differential.
Old 11-20-2008, 06:31 PM   #13
Engmus
Member#: 115645
All STi's have LSD rear ends, its just two different types. The 2004 is equipped with the Suretrac diffs.
bulwnkl; im at work so i cant dig right now, but i'll do what I can when I get home.
Old 11-21-2008, 12:16 PM   #14
savsuby300
Member#: 189232
1995 Nissan 240SX
Dead in the shed.
Hey hold up, what's wrong with the Royal Purple? Is there something I need to know?
savsuby300 is offline   Reply With Quote
Old 11-21-2008, 01:05 PM   #15
Engmus
Member#: 115645
^Nothing is "wrong" with Royal Purple, its a sound, solid lubricant.
Just in the term of good, better, best.
It would be between good and better.
Its perfectly suitable for DD and light track usage.
I wouldn't however run it in something I abused daily.
How difficult to change transmission and rear diff. fluids? big_dog Service & Maintenance 20 01-08-2009 01:53 AM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
Wated: Transmission and rear diff for WRX or Transmission for 2.5RS navpo55 Private 'Wanted' Classifieds 0 03-06-2007 09:14 PM
Tranny Fluid and Rear Diff Fluid? Stellar1 Factory 2.0L Turbo Powertrain 11 03-07-2005 12:22 AM
WTB: Redline Tranny fluid and Rear Diff fluid RimRockaz Bay Area Impreza Club Forum -- BAIC 11 07-16-2002 03:19 PM
Message Board Statistics All times are GMT -4. The time now is 09:06 PM.
