Old 11-19-2008, 06:51 PM   #1
ryan_13
Member#: 191604
2004 STI Stage 2
Default Airbag Light on with no mods???
hey all, my airbag dash light has been on and off for the last two weeks. it goes off every now and then but is on for the most part.
When i searched everyone that had problems had aftermarket things done but I don't have any dash mods or gauges and no aftermarket seats or anything like that.
and ideas ??
ryan_13 is offline   Reply With Quote
Old 11-19-2008, 07:01 PM   #2
px_crstian
Member#: 103332
2004 WRX WAGON
Check under the front seats (driver/passenger) for a yellow connector. If you follow the lines with your hands you'll end up at a connector. Plug/Unplug the connectors and it should fix the problem. Remember to do both sides (driver/passenger) mine did this just yesterday
If that doesn't fix it then check the tension on your seatbelts...if that doesn't do it then you'll have to get serviced.
px_crstian is offline   Reply With Quote
Old 11-19-2008, 07:12 PM   #3
ryan_13
Member#: 191604
2004 STI Stage 2
okay cool. ill check that out tonight when i get out of class...
THAnk YOu!!
Old 11-19-2008, 07:14 PM   #4
Jncominco2
Member#: 170212
could also be the wires in the connectors being kind of loose...should just be the connectors though
Jncominco2 is offline   Reply With Quote
Fog Lights on with Highs Mod for 2000 RS, the right way IowaRS Electrical & Lighting 12 12-03-2010 02:23 AM
AIRBAG light on with sti 2004 seats in wrx 2004 ? WRick Electrical & Lighting 0 03-31-2006 11:11 AM
Will I pass PA inspection with Airbag light on? il96 Tri-State Area Forum 5 09-08-2004 06:46 PM
Airbag light on, no horn? Solomon Electrical & Lighting 3 09-09-2003 09:31 PM
Airbag light on with sti seats? dgp Interior & Exterior Modification 10 11-04-2002 01:48 PM
