Old 11-19-2008, 11:16 PM   #1
Jncominco2
Member#: 170212
Default Test for trunk leak
ok first off, mods i know this probably isnt in the right section
i just dont know where to put it
anywho, my car was in a wreck, but its fixed now
only problem is the trunk has a small leak
i poured water in it and can see where its coming from on the bottom side, but i cant tell where its at on the top side, like where its falling through
i got hit on the driver quarterpanel, and its leaking into the trunk right under the back left side of the trunk jam
i tried looking for holes and shining a light and everything through, cant find where its falling through at
any suggestions on a way to find the spot?
Jncominco2 is offline   Reply With Quote
Old 11-19-2008, 11:21 PM   #2
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
did you try looking from the inside? get in the backseat and shine a big flashlight through the pass thru while a buddy sprays water on the trunk?
edit: you might have to remove some of the trunk panels to find the source of the leak.
bugeye829 is offline   Reply With Quote
Old 11-19-2008, 11:24 PM   #3
Jncominco2
Member#: 170212
yes i got in the trunk while it was closed, had him pour water, and i had a light
i can see where its dripping from the bottom, but its just dripping off a plate and i cant tell where its coming from above that
tried shining a light through it
so idk
Old 11-20-2008, 02:37 AM   #4
Skoloseven
Member#: 190226
i'd use compressed air and follow it with your hand as you trace spray the entire trunk line... then you can pin point it...
Skoloseven is offline   Reply With Quote
Old 11-20-2008, 03:51 AM   #5
truenosan
Member#: 78893
2013 Scion
FRS
Easy steps to figure out the source of a leak. I used to do this when I was working in a body shop.
Step 1
Find small friend (it helps if they aren't too bright as well )
Step 2
Give friend portable light
Step 3
Get hose out and start hosing the car
Step 4
Open a beer and enjoy refreshing beverage
Step 5
Pretend not to hear your friend screaming inside
Step 6
Open trunk to find friend soaked and then ask him/her where the leak was comming from
truenosan is offline   Reply With Quote
Old 11-20-2008, 08:17 AM   #6
Jncominco2
Member#: 170212
Good idea
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Although that sounds very fun, I'm tryingto find out where it's coming in from on the outside
Old 11-20-2008, 10:18 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
use blue washer fluid and see where it leaves blue residue
Bad Idea? testing for boost leak The Satch Newbies & FAQs 7 04-23-2009 06:10 PM
how to test for boost leaks? subylove8 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 07-17-2007 04:21 PM
Need help testing for FMIC leak... az03wrx South West Impreza Club Forum -- SWIC 6 02-02-2007 10:02 AM
How to test for boost leak? trex1200r Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 04-13-2005 03:46 AM
Testing for air leaks Aaron'z 2.5RS Technical Forum Archive 2 05-21-2000 06:55 PM
