Old 03-25-2002, 11:22 PM   #1
krave
Member#: 13908
2002 WRX Sedan
296 whp
Default HKS Super SQV BOV
I purchased this with the flange already attached, and it was really easy to install (5 minutes). The kit comes with the bov attatched to the flange, some vacuum hose, and a plug to stop up the bypass hose. You reuse the bolts from removing the factory bypass.
I've heard a lot of good reviews about HKS BOV and I'm pretty satisfied with it. The BOV itself is pretty big and it's loud (almost too loud). I haven't heard any backfires from the computer thinking a bypass is in place yet. I'll update this review once I get the recirculation kit.
NOTE: I felt no improvement performance wise over the stock bypass valve, but maybe this will come in handy when I get rid of the TD04.
Here is a pic of it installed
krave is offline   Reply With Quote
Old 03-26-2002, 11:17 AM   #2
2OHOH2WRX
Member Sales Rating: (7)
Member#: 11888
There is actually a performance loss that comes with installing an atmo-BOV.
It is a very-good sounding valve, and I'm happy with mine. I also have the recirculation kit coming in the mail soon, so I'll have the option of running it either loud or fast as I choose
2OHOH2WRX is offline   Reply With Quote
Old 03-26-2002, 11:30 AM   #3
krave
Member#: 13908
2002 WRX Sedan
296 whp
Can you let me know how the recirculation install goes? I haven't placed an order on mine yet.
Old 03-26-2002, 02:38 PM   #4
2OHOH2WRX
Member#: 11888
Will do. Seems very straight-forward. There's a little extension that mounts inside the BOV opening, which can then be used to connect a hose (any proper-diameter radiator hose would do) back to where the stock return hose goes. I should be getting it any day...
Old 03-28-2002, 10:02 AM   #5
2OHOH2WRX
Member#: 11888
OK, here's info on the recirc adapter:
- I bought it from Tom at Lightning Motorsports in LA, phone #: +1 225 752 2738.
- It requires the removal of 4 allen bolts. That's it.
- since this isn't a _kit_, it does not include the hose. IMHO, this is a good thing, because it allows us to get a piece of hose that fits our particular need, rather than being forced to mount the BOV in a specific location as allowed by a kit hose.
I'll post pics soon.
Old 03-28-2002, 10:35 AM   #6
2OHOH2WRX
Member#: 11888
These are the four screws that have to be removed:
Old 03-28-2002, 10:36 AM   #7
2OHOH2WRX
Member#: 11888
This is recirc tube (spun aluminum) that I bought, along with the rest of the BOV:
Old 03-28-2002, 10:37 AM   #8
2OHOH2WRX
Member#: 11888
...and here is the finished product:
Old 03-29-2002, 05:20 PM   #9
UKS
Member#: 16990
n00b don't hate this
Bimmer...grow up riceb0y
I have a question regarding this BOV: 1. Is there really a performance loss over the stock BOV? 2. Is the recirculation kit recommended? and can you buy it with the BOV?
UKS is offline   Reply With Quote
Old 03-29-2002, 09:06 PM   #10
2OHOH2WRX
Member#: 11888
UKS:
1 - any time air that has already been measured for combustion escapes into the atmosphere rather than back into the intake tract, it throws off the A/F ratio because the ECU thinks the vented air is still available for use
2 - the recirculation kit counteracts 1 above, so it is recommended _if_ you want maximum performance rather than maximum noise
3 - I bought the two items separately, from two different vendors, but it's likely that if a vendor has one, he/she may have the other
A few more points:
- the performance reduction from atmo venting isn't large, so sacrificing that little bit for being able to scare the crap out of people and turn heads is probably worth it to most people
- the stock BOV has been used successfully as high as ~380hp, last I heard, so clearly it does not need to be replaced, unless, again, you want the "cool" sound
- the recirc tubing is easily clamped off, so with 1 minute of work (pop hood, get out, open hood, unscrew hose, screw cap on hose, close hood, get back in car), you can switch between atmo or recirc at will
- if you ever get into higher power levels, ones that require standalone engine management based on MAP (Manifold Absolute Pressure) rather than MAF (Mass Air Flow, what stock Subies have), then there will be no need for recirculation, as the ECU will base its calculations on the air present in the manifold, not what's before it
Old 03-30-2002, 04:55 AM   #11
UKS
Member#: 16990
Default THANKS
To 2OHOH2WRX;
Many thanks for the information. This helps a lot!
Old 03-30-2002, 08:29 AM   #12
2OHOH2WRX
Member#: 11888
No problem. Glad it helped
Old 03-31-2002, 12:24 PM   #13
Leonardo
Consigliere
Super Moderator
Member Sales Rating: (3)
Member#: 185
2009 Civic EX
One would need a different recirculation hose if the BOV is in the stock location.
Leo
Leonardo is offline   Reply With Quote
Old 03-31-2002, 12:53 PM   #14
2OHOH2WRX
Member#: 11888
Right, so it's just as well that HKS sells just the recirc fitting
Old 03-31-2002, 10:09 PM   #15
my WeRX
Member#: 16977
2002 WRX Sedan
WR Blue Pearl
Default where to buy?
can anyone help me out on where to buy the SSQV BOV Kit for WRX *AND* the recirculation kit for the WRX?
i can find the SSQV BOV Kit for WRX for $280, and i can't even find the recirculation kit for WRX.
what exactly does the recirculation kit do?
does it muffle the noise it makes while giving a better performance?
any help would be greatful.
thanks in advance!
my WeRX is offline   Reply With Quote
Old 03-31-2002, 10:20 PM   #16
2OHOH2WRX
Member#: 11888
Read 6 posts up to get most of your answers, and a few above that to the rest of them
Old 04-01-2002, 01:33 AM   #17
AK_2002_WRX
Member#: 10591
2004 Silverado SS
Victory Red
Talking
so how about some sound clips.
i have a Forge BOV, but i like how distinct the HKS sounds.
AK_2002_WRX is offline   Reply With Quote
Old 04-04-2002, 12:03 AM   #18
View Askew
Member#: 14714
'15 WRX
Crystal Black
I just installed the kit about 20 min ago. Just gotta say that it kicks a$$!!! The sound is awesome and the install was a piece of cake. I LOVE THIS BOV!!
Here is a site that has the sound clips for alot of BOV's. Enjoy.
http://www.alltrac.net/tuning/blowoffvalve.html
View Askew is offline   Reply With Quote
Old 04-07-2002, 03:11 PM   #19
White01
Member#: 1913
Question, I see from the pics that you have to put that piece on the end of the BOV so the hose will fit on. If you want to make it 100% vent do you just need to pull that hose off or do you need to take out that metal piece?
Also if that metal piece is kept on, does the sound change when it is 100% vent to the atmosphere?
Thanks!
White01 is offline   Reply With Quote
Old 04-07-2002, 03:29 PM   #20
2OHOH2WRX
Member#: 11888
To change the BOV from a recirc back to a vent you would need to:
- pop off the hose
- close up the hose (stopper, cork, plug, whatever)
Although I haven't timed myself doing this, I'd say it takes less than a minute to do, going either way.
The sound is deeper. It still whistles, but the whistle is not nearly as high-pitched as with the other piece being in. It's a nicer, even more unique sound
Old 05-11-2002, 02:09 PM   #21
Code-7
Member#: 5077
'97 e39 540i6
Just a few questions:
There are two hoses that connect to the stock BOV. There's one under the intercooler that's about an 1" in diameter which clamps on, than the small 1/4" hose which slides into the side.
Now, with the recirculation fitting, what more do I need to buy?
Do I need to attach a hose to the rc fitting and connect it to the big hose under the intercooler?
Code-7 is offline   Reply With Quote
Old 05-11-2002, 04:09 PM   #22
2OHOH2WRX
Member#: 11888
You need to get a hose (or an adapter fitting to use the stock hose) to go from the recirc fitting back to where the OEM hose goes.
Old 06-10-2002, 12:21 AM   #23
jbdadog
Member#: 12820
Default pix?
Amy pic of the recirculatory hose that ya made. I have been sitting here trying to figure a way to make it recirculatory for hours. I have hoses just they end up bending to much. Thanks so much!
jbdadog is offline   Reply With Quote
Old 06-10-2002, 05:01 PM   #24
2OHOH2WRX
Member#: 11888
I'll have some up in a day or so.
I used a combination of stock hose, hose adapter, and a length of hose that I got from Home Depot for a few bucks. Surprisingly enough, a lot of the BOV noise is still there, which I consider a plus - not only does is recirc, it also sounds much better than stock while doing it
Old 06-10-2002, 05:13 PM   #25
jbdadog
Member#: 12820
Default thanks
thanks so much!!
FS:noVA: HKS Super SQV BOV Ceez3607 MAIC Private Classifieds 22 05-20-2008 12:38 PM
FS:noVA: HKS Super SQV BOV Ceez3607 Engine/Power/Exhaust 19 05-07-2008 08:32 PM
WTS: HKS Super SQV BOV irascible SWIC Private Classifieds 6 12-29-2007 09:50 PM
WTS: HKS Super SQV BOV irascible Engine/Power/Exhaust 0 12-24-2007 04:23 PM
HKS Super SQV BOV ill_nometry Engine/Power/Exhaust 0 04-04-2007 01:05 AM
