Old 03-25-2002, 11:24 PM   #1
Bighurt1
Member#: 6952
2002 A sedona Blur..
1FSTBXR4(w/fubared clutch
Default can running TOO rich for too long throw a CEL?
I got my VF30, FP and STI injectors in last week, and (according to Phil at TXS) I got a bad chip, which won't let me hold boost (~10psi) and is making me run SUPER rich, my car backfires about every 10 minutes. I was driving home tonight from the gym, not going fast or anything and I notice my CEL finally comes on. I've never had one before. My car has about 13,800 miles on it.
would this be the problem?
-Brett
Bighurt1 is offline   Reply With Quote
Old 03-26-2002, 09:27 AM   #2
Bighurt1
Member#: 6952
no help? has NO ONE had this problem?
Old 03-26-2002, 10:58 AM   #3
titsataki
Member#: 4402
although I do not have your set up.
I had a wacked out unichip that made the car run super rich. My garage with the Garage door open would smell gas and my plugs would be completely black. Car would run for a minute or two and then die out. It would throw a CEL MAF too high (I forget the code number now...). would start right away with no unichip and miss because of the fouled up plugs... I cleaned them and the car would run fine.
Hope I helped a bit.
Cheers
T.
titsataki is offline   Reply With Quote
Old 03-26-2002, 11:41 AM   #4
SubaruStu
Member#: 8972
2003 WRX Wagon
I would also guess that running too rich "could" also end up
triggering a P0420 - Cat Inefficiency. The reason being that
running too rich translates into using all available oxygen for
combustion, and not leaving enough extra in the exhaust stream
for the catalytic convertor.
Hope you don't get any CELs!
Stu
SubaruStu is offline   Reply With Quote
Old 03-26-2002, 03:40 PM   #5
S-1
Member#: 10842
07 2.5i Wagon
i think i may be running to rich because my exhaust backfire quite a bit (mostly at low rpm shifts)
my mods are txs stag.2, vishnu up-pipe
S-1 is offline   Reply With Quote
Old 03-26-2002, 04:48 PM   #6
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
get some odb2 software and find out what the CEL is.
kenshiro is offline   Reply With Quote
Old 03-26-2002, 04:49 PM   #7
kenshiro
Member#: 15917
2002 teh FastAR rex
Black like my soul
Default Re: can running TOO rich for too long throw a CEL?
What do you mean by "bad chip" ? The factory ECM? If you're talking about some aftermarket chip being bad, return that **** and get another one.
-Brett
Old 03-26-2002, 04:57 PM   #8
scooby
Member#: 13085
i am had a similar problem after i installed the injectors as well some 10psi of boost max, and it is running soo rich i cant even get above around 3000 rpms without bogging out, i would imagine it could throw a cel it threw one on my stock ecu when i drove around right after i put the injectors and fp in. however i chose not to go with the unichip so good luck.
scooby is offline   Reply With Quote
How do I know if I'm running too lean or too rich? Something Cool Here Newbies & FAQs 18 04-20-2010 10:55 PM
Running the turbo for a long time gthing Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 11-22-2006 01:58 AM
CEL - System too Rich (front O2 sensor) gpfan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-27-2005 10:27 PM
CEL for running to rich.... dan avoN7 Engine Management & Tuning 2 10-05-2005 04:12 AM
Too Rich or Too lean 187 Engine Management & Tuning 5 01-15-2004 07:03 AM
